Is there any examples of config file in deepstream-5.1 yoloV3?
Hi. I’m trying to run yoloV3 example on AGX Xavier (jetpack 4.5.1 and deepstream-5.1).
but some error occured.
I read README file, and followed the way.
I downloaded yolo config and weight files by using ./prebuild.sh
And i did this command : deepstream-app -c deepstream_app_config_yoloV3.txt
Then it occured error like below.
So i searched google many times, but i couldn’t find proper solution about nvdsinfer.
If you have solution or and suggestion please let me know. Thanks.
stupid question.
I thought i have yolov3 weights, yolov3 cfg file.
because there was no error message when i command prebuild.h…
Please noted that you will need root authority to write a file into /opt/nvidia/deepstream/.
So please run the script like this:
$ sudo ./prebuild.sh
Hi
Yes. I retried command with sudo and solved the problem.
Thanks AastaLLL.
