Is there any internal resistor on CAM0_RST(H3) that I can control?
hello Kei_Ko,
you may toggle the pin high/low via kernel layer or sysnode, but… may I know what’s the real use-case?
hello @JerryChang
When AGX CAM0_RST is switched to 0, the module’s RST (default high) drops to 1.8 → 1.3 instead of 0. I want to know if it’s a problem due to internal resistance.
Are you testing on devkit or your custom board? CAM0_RST is a general GPIO without “internal resistance” need to control.
