My question is same as the topic : Is there any way I can extract my files from SD card that I used in my jetson nano b01?
My board is not working currently but I want to get my files and codes from the SD card.
Hi @joyjosephdrums, if you plug your SD card into a Linux PC, you should just be able to access the files from the PC.
On Windows you would need to install a tool like ext2fsd which allows Windows to read EXT2/EXT3/EXT4 partitions.
Thanks dusty
I will try it and then mark this as a solution.
I tried it with Linux and it works.
Thankyou Dusty
