Is there any way to flash the Orin Nano developer kit?
I’ve tried everything, using the SDK manager, including Jetpack 6, Jetpack 5.13, and Jetpack 5.12. None of this works. It simply cannot detect the microSD. I get:
11:10:25.335 - info: NV_L4T_FLASH_JETSON_LINUX_COMP@JETSON_ORIN_NANO_TARGETS: Waiting for device to expose ssh ...RTNETLINK answers: File exists
11:10:25.354 - info: NV_L4T_FLASH_JETSON_LINUX_COMP@JETSON_ORIN_NANO_TARGETS: RTNETLINK answers: File exists
11:10:25.356 - info: NV_L4T_FLASH_JETSON_LINUX_COMP@JETSON_ORIN_NANO_TARGETS: Waiting for device to expose ssh ...Run command: flash on fc00:1:1:0::2
11:10:25.561 - info: NV_L4T_FLASH_JETSON_LINUX_COMP@JETSON_ORIN_NANO_TARGETS: SSH ready
11:10:26.308 - info: NV_L4T_FLASH_JETSON_LINUX_COMP@JETSON_ORIN_NANO_TARGETS: blockdev: cannot open /dev/mmcblk0boot0: No such file or directory
11:10:26.331 - info: NV_L4T_FLASH_JETSON_LINUX_COMP@JETSON_ORIN_NANO_TARGETS: [ 0]: l4t_flash_from_kernel: Starting to create gpt for emmc
11:10:26.331 - info: NV_L4T_FLASH_JETSON_LINUX_COMP@JETSON_ORIN_NANO_TARGETS: Active index file is /mnt/internal/flash.idx
11:10:26.332 - info: NV_L4T_FLASH_JETSON_LINUX_COMP@JETSON_ORIN_NANO_TARGETS: Number of lines is 58
11:10:26.332 - info: NV_L4T_FLASH_JETSON_LINUX_COMP@JETSON_ORIN_NANO_TARGETS: max_index=57
11:10:27.801 - info: NV_L4T_FLASH_JETSON_LINUX_COMP@JETSON_ORIN_NANO_TARGETS: [ 1]: l4t_flash_from_kernel: Successfully create gpt for emmc
11:10:27.820 - info: NV_L4T_FLASH_JETSON_LINUX_COMP@JETSON_ORIN_NANO_TARGETS: [ 1]: l4t_flash_from_kernel: Starting to create gpt for external device
11:10:27.821 - info: NV_L4T_FLASH_JETSON_LINUX_COMP@JETSON_ORIN_NANO_TARGETS: Active index file is /mnt/external/flash.idx
11:10:27.821 - info: NV_L4T_FLASH_JETSON_LINUX_COMP@JETSON_ORIN_NANO_TARGETS: Number of lines is 18
11:10:27.821 - info: NV_L4T_FLASH_JETSON_LINUX_COMP@JETSON_ORIN_NANO_TARGETS: max_index=17
11:10:27.857 - info: NV_L4T_FLASH_JETSON_LINUX_COMP@JETSON_ORIN_NANO_TARGETS: writing item=1, 9:0:primary_gpt, 512, 19968, gpt_primary_9_0.bin, 16896, fixed-<reserved>-0, 3043a840a8a327b62bcba1ad97f929d2e220a4af
11:10:27.989 - error: NV_L4T_FLASH_JETSON_LINUX_COMP@JETSON_ORIN_NANO_TARGETS: Error: Could not stat device /dev/mmcblk1 - No such file or directory.
11:10:27.989 - info: Event: NV_L4T_FLASH_JETSON_LINUX_COMP@JETSON_ORIN_NANO_TARGETS - error is: Error: Could not stat device /dev/mmcblk1 - No such file or directory.
11:10:28.008 - info: NV_L4T_FLASH_JETSON_LINUX_COMP@JETSON_ORIN_NANO_TARGETS: Flash failure
11:10:28.008 - info: NV_L4T_FLASH_JETSON_LINUX_COMP@JETSON_ORIN_NANO_TARGETS: Cleaning up...
One thing that is weird is that this device is a 945-13766-0000-000, and that doesn’t match any of the device options available in SDK Manager. That’s why I’m wondering, is this an authentic NVidia device, or does NVidia support it, or what? What’s the magic combination of version numbers of SDK Manager, JetPack and Ubuntu host do I need to make it detect the device, if it’s possible at all?
I’ve spent an entire week trying to get this to flash, desperate for any assistance. I have successfully flashed many many NVidia devices, such as TX1s and TX2s before, but this device seems out of reach.
Thank you
SOLVED!
DO NOT USE A 32GB MICROSD!
I switched to a fresh 128gb and it worked. I believe a 64gb would also work. 32gb absolutely does not work. That was painful.
