• Hardware :- v100
• Network Type Yolo_v4
• TLT Version :- toolkit_version: 3.22.05
• Training spec file :- I’m using recommended parameters only
• How to reproduce the issue ? (This is for errors. Please share the command line and the detailed log here.)
Is there any way to implement weight decay using tao-toolkit for training yolo_v4 ?
Thank you. but there is an issue with adam & L2 regularization which is not able to achieve proper results like SGD with L2. A more detailed explanation is mentioned in the mentioned article.
