As far as I understood NMSPlugin has two outputs:
- object parameters table - calss, confidence, box and so on
- number of actual items in object parameters table
Second output has the only integer value, and it`s supposed to be so always.
So when I set network precision in FT32 - everything is fine, but with same input data in FT16 mode - second output contains garbage. nevertheless first input contains correct parameters table.
Checked on TensorRT 5.0 GA and 5.1 RC
