Is there difference between ISP0 and ISP1?
Software Version
DRIVE OS Linux 5.2.6
DRIVE OS Linux 5.2.0
other DRIVE OS version
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.6.1.8175
1.6.0.8170
other
Host Machine Version
native Ubuntu 18.04
other
Are ISP0 and ISP1 exactly same or they have some internal difference. I did some benchmarks ISP0 and ISP1 using same output surface settings:
surface format:
NVM_SURF_FMT_SET_ATTR_RGBA(mformatAttr, RGBA, UINT, 8, PL);
color surface type:
NVM_SURF_ATTR_COLOR_STD_SRGB
the inputs is from raw frame file, and are also identical.
But there is slight difference in single frame processing time on ISP. Is there internal difference between ISP0 and ISP1 that cause this difference?
Please provide everything (patch for our sample application, input file, command, etc.) for us to observe the difference. Thanks.
Sorry I can’t provide the patch based on my test code, it is too different from the original sample now.
Just to confirm if two ISPs are identical hardware components, thanks.
Xavier has only one ISP HW engine. ISP0 & ISP1 are two simultaneous outputs of the single ISP HW engine. Thanks!
Dear @leqiang.wang,
Could you check What is the difference between ISP0 and ISP1 on nvsipl_camera? and DRIVE AGX Xavier ISP units doubts if it helps?
