hello,
I use AppEncCuda, a encoder sample code from Video_Codec_SDK_9.0.20, and found that the max number of encoder threads is 2.
and when I create 3 encoder threads, it crashed in NvEncoder.cpp:
NVENC_API_CALL(m_nvenc.nvEncOpenEncodeSessionEx(&encodeSessionExParams, &hEncoder));
someone can help me?
NVENC LICENSING POLICY
There is no change in licensing policy in the current SDK in comparison to the earlier SDKs. The licensing policy is as follows:
As far as NVENC hardware encoding is concerned, NVIDIA GPUs are classified into two categories: “qualified” and “non-qualified”. On qualified GPUs, the number of concurrent encode sessions is limited by available system resources (encoder capacity, system memory, video memory etc.). On non-qualified GPUs, the number of concurrent encode sessions is limited to 2 per system. This limit of 2 concurrent sessions per system applies to the combined number of encoding sessions executed on all non-qualified cards present in the system.
For a complete list of qualified and non-qualified GPUs, refer to NVIDIA VIDEO CODEC SDK | NVIDIA Developer.
For example, on a system with one Quadro K4000 card (which is a qualified GPU) and three GeForce cards (which are non-qualified GPUs), the application can run N simultaneous encode sessions on Quadro K4000 card (where N is defined by the encoder/memory/hardware limitations) and two sessions on all the three GeForce cards combined. Thus, the limit on the number of simultaneous encode sessions for such a system is N + 2.
