I’ve faced with the issue that CUDA atomic API do not have atomicLoad function.
After searching on stackoverflow, I’ve found the following implementation of CUDA atomicLoad
But looks like this function is failed to work in following example:
#include <cassert>
#include <iostream>
#include <cuda_runtime_api.h>
template <typename T>
__device__ T atomicLoad(const T* addr) {
const volatile T* vaddr = addr; // To bypass cache
__threadfence(); // for seq_cst loads. Remove for acquire semantics.
const T value = *vaddr;
// fence to ensure that dependent reads are correctly ordered
__threadfence();
return value;
__global__ void initAtomic(unsigned& count, const unsigned initValue) {
count = initValue;
__global__ void addVerify(unsigned& count, const unsigned biasAtomicValue) {
atomicAdd(&count, 1);
// NOTE: When uncomment the following while loop the addVerify is stuck,
// it cannot read last proper value in variable count
// while (atomicLoad(&count) != (1024 * 1024 + biasAtomicValue)) {
// printf("count = %u\n", atomicLoad(&count));
int main() {
std::cout << "Hello, CUDA atomics!" << std::endl;
const auto atomicSize = sizeof(unsigned);
unsigned* datomic = nullptr;
cudaMalloc(&datomic, atomicSize);
cudaStream_t stream;
cudaStreamCreate(&stream);
constexpr unsigned biasAtomicValue = 11;
initAtomic<<<1, 1, 0, stream>>>(*datomic, biasAtomicValue);
addVerify<<<1024, 1024, 0, stream>>>(*datomic, biasAtomicValue);
cudaStreamSynchronize(stream);
unsigned countHost = 0;
cudaMemcpyAsync(&countHost, datomic, atomicSize, cudaMemcpyDeviceToHost, stream);
assert(countHost == 1024 * 1024 + biasAtomicValue);
cudaStreamDestroy(stream);
return 0;
If you will uncomment the section with atomicLoad then application will stuck …
Maybe I missed something ? Is there a proper way to load variable modified atomically ?
P.S.: I know there exists cuda::atomic
implementation, but this API is not supported by my hardware
This question is duplicate of the following gpu atomics - Is there proper CUDA atomicLoad function? - Stack Overflow
