GPU
• DeepStream Version
6.1.1
• TensorRT Version
8.4
525.60.13
questions
I’m reading deepstream’s source code. In function reset_source_pipeline
in file deepstream_source_bin.c
, there is a piece of code as follows:
if (src_bin->parser != NULL) {
if (!gst_element_send_event (GST_ELEMENT(src_bin->parser),
gst_nvevent_new_stream_reset(0)))
GST_ERROR_OBJECT (src_bin->parser, "Interrupted, Reconnection event not sent");
function gst_nvevent_new_stream_reset
defines in gst-nvevent.h
* Creates a "custom reset" event for the specified source.
* @param[in] source_id Source ID of the stream for which reset is to be sent;
* also the pad ID of the sinkpad of the
* Gst-nvstreammux plugin for which
* the source is configured.
* @return A pointer to the event corresponding to request if sucxessful,
* or NULL otherwise.
GstEvent * gst_nvevent_new_stream_reset (guint source_id);
My question is, is it a BUG to pass 0
as argument to gst_nvevent_new_stream_reset
in reset_source_pipeline
? Should it be the pad index of streammux which current rtsp source linked to?
Thanks for answering!
