hello.
Is this a safe to resize a vector?
int* a;
int* b;
cudaMalloc((void**)(&a), aSize);
cudaMemcpy(a, 1, aSize);
cudaMalloc((void**)(&b), bSize);
cudaMalloc((void**)(&a), aSize + expandSize);
hello.
int* a;
int* b;
It’s a memory leak. It’s not a good practice. Before you do the 2nd cudaMalloc
on a
, do a cudaFree
on it. and of course this means you lose the previous contents.
If you want serious vector style behavior, you’re not going to get it with 3 lines of code.
Thank you.
I will edit code like this. Is this OK?
int* a;
int* a_tmp;
int* b;
cudaMalloc((void**)(&a_tmp), aSize);
cudaMemset(a, 1, aSize);
cudaMemcpy(a_tmp, a, aSize);
cudaFree(a);
cudaMemcpy(a,a_tmp,aSize);
Yes, I think that would work. It’s not actually compliant code (e.g. cudaMemcpy
takes 4 arguments) but the idea seems correct. You might be able to simplify:
int *a;
int *a_tmp;
cudaMalloc(&a, aSize);
cudaMalloc(&a_tmp, aSize + expandSize);
cudaMemcpy(a_tmp, a, aSize, cudaMemcpyDeviceToDevice);
cudaFree(a);
a = a_tmp;
This still doesn’t perfectly mimic std::vector
behavior. For example, a vector will initialize its elements. We’re not doing that carefully here.
Thank you.
I want to put this process in a loop and make it work the same way as std::vector or thrust::xxxx_vector resize.
Is this the fastest code? The size of “a” is not reduced.
int *a;
int *a_tmp;
while(1){
// I understand that this code is wrong...
cudaFree(a);
a = a_tmp;
if (condition) break;
Oh, Sorry. I forgot to mention that the version is CUDA 10.2.
sorry. You lost me. I have no idea what you are trying to do.
Sorry for my cheap English. I needed to explain more details.
I would like to resize array in while loop like std::vector::resize.
// I want this process in CUDA...
std::vector<int> a(10,1);
while(1){
// set n and k
a.resize(n, k);
if(condition) break;
