Is this memory allocation fine?
struct MyStr
int a;
int* iPtr;
long l;
float* fPtr
void HostFun( MyStr* str )
cudaMalloc( (void**)&str->iPtr, str->a );
cudaMalloc( (void**)&str->fPtr, str->l );
global void GloFun( int* iPtr, float* fPtr )
// I’m doing something here…
main()
MyStr str;
str.a = 10;
str.l = 10;
HostFun( &str );
GloFun<<<1,1>>>( str.iPtr, str.fPtr )
cudaFree( str.iPtr);
cudaFree( str.fPtr);
see the above code. and please answer
  • I’m declaring a structure variable (str) in main(). so str is in host memory. Is it Right or not?
  • I’m allocating the device memory for the members of str in host function HostFun(). but str is in host memory. Is this fine or not?
  • I’m passing the pointers in global function as arguments. when I’m accessing or doing something using those pointers will do anything? or it just works fine?
  • I’m freeing the memory in main() [ host ] function. Is this fine?
    yes, its host memory.
    yes. You get a pointer to device mem and you can hold it on host mem. However your function should look like this
void HostFun( MyStr* str ) {
cudaMalloc( (void**)&str->iPtr, str->a * sizeof(int));
cudaMalloc( (void**)&str->fPtr, str->l * sizeof(float));
    works fine, but you should pass also the dimensions.
    yes. Should be there.
Great Thanks Noel :)
