I think my SD card got trashed and that’s why my Nano A02 isn’t booting. Could someone take a look at this log and tell me if this is the expect serial console log when the SD card is missing? I see a bunch of errors, but I want to make sure they’re from the bootloader trying to boot the SD card and failing because it’s missing.
[0000.131] Processing in cold boot mode Bootloader 2
[0000.135] A02 Bootrom Patch rev = 1023
[0000.139] Power-up reason: pmc por
[0000.142] No Battery Present
[0000.145] pmic max77620 reset reason
[0000.148] pmic max77620 NVERC : 0x40
[0000.151] RamCode = 0
[0000.154] Platform has DDR4 type RAM
[0000.157] max77620 disabling SD1 Remote Sense
[0000.161] Setting DDR voltage to 1125mv
[0000.165] Serial Number of Pmic Max77663: 0xe13c4
[0000.173] Entering ramdump check
[0000.176] Get RamDumpCarveOut = 0x0
[0000.179] RamDumpCarveOut=0x0, RamDumperFlag=0xe59ff3f8
[0000.184] Last reboot was clean, booting normally!
[0000.189] Sdram initialization is successful
[0000.193] SecureOs Carveout Base=0x00000000ff800000 Size=0x00800000
[0000.199] Lp0 Carveout Base=0x00000000ff780000 Size=0x00001000
[0000.205] BpmpFw Carveout Base=0x00000000ff700000 Size=0x00080000
[0000.211] GSC1 Carveout Base=0x00000000ff600000 Size=0x00100000
[0000.216] GSC2 Carveout Base=0x00000000ff500000 Size=0x00100000
[0000.222] GSC4 Carveout Base=0x00000000ff400000 Size=0x00100000
[0000.228] GSC5 Carveout Base=0x00000000ff300000 Size=0x00100000
[0000.234] GSC3 Carveout Base=0x000000017f300000 Size=0x00d00000
[0000.250] RamDump Carveout Base=0x00000000ff280000 Size=0x00080000
[0000.256] Platform-DebugCarveout: 0
[0000.259] Nck Carveout Base=0x00000000ff080000 Size=0x00200000
[0000.265] Non secure mode, and RB not enabled.
[0000.269] Read GPT from (4:0)
[0000.553] Csd NumOfBlocks=125042688
[0000.558] Set High speed to 1
[0000.561] Error mask set in wait for cmd complete with error 0x3 in HwSdmmcWaitForCommandComplete
[0000.571] Command complete wait failed with error 0x3 Interrupt 0x18000
[0000.577] Number of retries left 4
[0000.581] Error mask set in wait for cmd complete with error 0x3 in HwSdmmcWaitForCommandComplete
[0000.591] Command complete wait failed with error 0x3 Interrupt 0x18000
[0000.597] Number of retries left 3
[0000.601] Error mask set in wait for cmd complete with error 0x3 in HwSdmmcWaitForCommandComplete
[0000.611] Command complete wait failed with error 0x3 Interrupt 0x18000
[0000.617] Number of retries left 2
[0000.621] Error mask set in wait for cmd complete with error 0x3 in HwSdmmcWaitForCommandComplete
[0000.631] Command complete wait failed with error 0x3 Interrupt 0x18000
[0000.637] Number of retries left 1
[0000.641] Error mask set in wait for cmd complete with error 0x3 in HwSdmmcWaitForCommandComplete
[0000.651] Command complete wait failed with error 0x3 Interrupt 0x18000
[0000.657] Number of retries left 0
[0000.660] Send command failed with 0x3
[0000.664] Switch Command send failure with error 0x3 in EmmcSendSwitchCommand func at 880 line
[0000.672] Sending switch command failed with 0x3
[0000.677] failed to switch to high speed with error 0x3 in SdEnableHighSpeed func at 1205 line
[0000.685] SdEnableHighSpeed Failed with error 0x3
[0000.695] Using GPT Primary to query partitions
[0000.700] Loading Tboot-CPU binary
[0000.709] Verifying TBC in OdmNonSecureSBK mode
[0000.719] Bootloader load address is 0xa0000000, entry address is 0xa0000258
[0000.726] Bootloader downloaded successfully.
[0000.730] Downloaded Tboot-CPU binary to 0xa0000258
[0000.735] MAX77620_GPIO5 co�[0000.125] [L4T TegraBoot] (version 00.00.2018.01-l4t-80a468da)
[0000.273] Error mask set in wait for cmd complete with error 0x3 in HwSdmmcWaitForCommandComplete
[0000.283] Command complete wait failed with error 0x3 Interrupt 0x18000
[0000.289] Number of retries left 4
[0000.293] Error mask set in wait for cmd complete with error 0x3 in HwSdmmcWaitForCommandComplete
[0000.303] Command complete wait failed with error 0x3 Interrupt 0x18001
[0000.309] Number of retries left 3
[0000.313] Error mask set in wait for cmd complete with error 0x3 in HwSdmmcWaitForCommandComplete
[0000.323] Command complete wait failed with error 0x3 Interrupt 0x18001
[0000.329] Number of retries left 2
[0000.333] Error mask set in wait for cmd complete with error 0x3 in HwSdmmcWaitForCommandComplete
[0000.343] Command complete wait failed with error 0x3 Interrupt 0x18000
[0000.349] Number of retries left 1
[0000.353] Error mask set in wait for cmd complete with error 0x3 in HwSdmmcWaitForCommandComplete
[0000.363] Command complete wait failed with error 0x3 Interrupt 0x18001
[0000.369] Number of retries left 0
[0000.373] Send command failed with 0x3
[0000.376] CMD8 send failed. Retrying CMD0/CMD8 (2)…
[0000.381] Error mask set in wait for cmd complete with error 0x3 in HwSdmmcWaitForCommandComplete
[0000.391] Command complete wait failed with error 0x3 Interrupt 0x18000
[0000.398] Number of retries left 4
[0000.401] Error mask set in wait for cmd complete with error 0x3 in HwSdmmcWaitForCommandComplete
[0000.411] Command complete wait failed with error 0x3 Interrupt 0x18001
[0000.418] Number of retries left 3
[0000.421] Error mask set in wait for cmd complete with error 0x3 in HwSdmmcWaitForCommandComplete
[0000.431] Command complete wait failed with error 0x3 Interrupt 0x18000
[0000.438] Number of retries left 2
[0000.441] Error mask set in wait for cmd complete with error 0x3 in HwSdmmcWaitForCommandComplete
[0000.451] Command complete wait failed with error 0x3 Interrupt 0x18000
[0000.458] Number of retries left 1
[0000.461] Error mask set in wait for cmd complete with error 0x3 in HwSdmmcWaitForCommandComplete
[0000.471] Command complete wait failed with error 0x3 Interrupt 0x18000
[0000.478] Number of retries left 0
[0000.481] Send command failed with 0x3
[0000.485] CMD8 send failed. Retrying CMD0/CMD8 (1)…
[0000.490] Error mask set in wait for cmd complete with error 0x3 in HwSdmmcWaitForCommandComplete
[0000.500] Command complete wait failed with error 0x3 Interrupt 0x18000
[0000.506] Number of retries left 4
[0000.510] Error mask set in wait for cmd complete with error 0x3 in HwSdmmcWaitForCommandComplete
[0000.520] Command complete wait failed with error 0x3 Interrupt 0x18000
[0000.526] Number of retries left 3
[0000.530] Error mask set in wait for cmd complete with error 0x3 in HwSdmmcWaitForCommandComplete
[0000.540] Command complete wait failed with error 0x3 Interrupt 0x18000
[0000.546] Number of retries left 2
[0000.550] Error mask set in wait for cmd complete with error 0x3 in HwSdmmcWaitForCommandComplete
[0000.560] Command complete wait failed with error 0x3 Interrupt 0x18000
[0000.566] Number of retries left 1
[0000.570] Error mask set in wait for cmd complete with error 0x3 in HwSdmmcWaitForCommandComplete
[0000.580] Command complete wait failed with error 0x3 Interrupt 0x18000
[0000.586] Number of retries left 0
[0000.589] Send command failed with 0x3
[0000.593] CMD8 send failed. Retrying CMD0/CMD8 (0)…
[0000.598] Error mask set in wait for cmd complete with error 0x3 in HwSdmmcWaitForCommandComplete
[0000.608] Command complete wait failed with error 0x3 Interrupt 0x18000
[0000.615] Number of retries left 4
[0000.618] Error mask set in wait for cmd complete with error 0x3 in HwSdmmcWaitForCommandComplete
[0000.628] Command complete wait failed with error 0x3 Interrupt 0x18000
[0000.635] Number of retries left 3
[0000.638] Error mask set in wait for cmd complete with error 0x3 in HwSdmmcWaitForCommandComplete
[0000.648] Command complete wait failed with error 0x3 Interrupt 0x18000
[0000.655] Number of retries left 2
[0000.658] Error mask set in wait for cmd complete with error 0x3 in HwSdmmcWaitForCommandComplete
[0000.668] Command complete wait failed with error 0x3 Interrupt 0x18000
[0000.675] Number of retries left 1
[0000.678] Error mask set in wait for cmd complete with error 0x3 in HwSdmmcWaitForCommandComplete
[0000.688] Command complete wait failed with error 0x3 Interrupt 0x18000
[0000.695] Number of retries left 0
[0000.698] Send command failed with 0x3
[0000.701] CMD55 send failed with error 0x3 in SdIdentifyCard func at 1870 line
[0000.708] SD Identify card failed with 0x3
[0000.712] SdIdentifyCard has failed with error 0x3 in NvTbootSdmmcInit func at 87 line
[0000.720] Sdmmc Init failed with 0x3 error
[0000.724] Read PT from (2:0)
[0000.739] Using BFS PT to query partitions
[0000.743] PT: Partition TBC NOT found !
[0000.747] Warning: Find Partition via PT Failed
[0000.751] failed to load NvTbootTbootCpu from (4:0)
[0000.756] re-load NvTbootTbootCpu from (2:0)
[0000.760] Read GPT from (4:0)
[0000.763] Error mask set in wait for cmd complete with error 0x3 in HwSdmmcWaitForCommandComplete
[0000.773] Command complete wait failed with error 0x3 Interrupt 0x18001
[0000.780] Number of retries left 4
[0000.783] Error mask set in wait for cmd complete with error 0x3 in HwSdmmcWaitForCommandComplete
[0000.793] Command complete wait failed with error 0x3 Interrupt 0x18001
[0000.800] Number of retries left 3
[0000.803] Error mask set in wait for cmd complete with error 0x3 in HwSdmmcWaitForCommandComplete
[0000.813] Command complete wait failed with error 0x3 Interrupt 0x18000
[0000.820] Number of retries left 2
[0000.823] Error mask set in wait for cmd complete with error 0x3 in HwSdmmcWaitForCommandComplete
[0000.833] Command complete wait failed with error 0x3 Interrupt 0x18000
[0000.840] Number of retries left 1
[0000.843] Error mask set in wait for cmd complete with error 0x3 in HwSdmmcWaitForCommandComplete
[0000.853] Command complete wait failed with error 0x3 Interrupt 0x18000
[0000.860] Number of retries left 0
[0000.863] Send command failed with 0x3
[0000.867] CMD8 send failed. Retrying CMD0/CMD8 (2)…
[0000.872] Error mask set in wait for cmd complete with error 0x3 in HwSdmmcWaitForCommandComplete
[0000.882] Command complete wait failed with error 0x3 Interrupt 0x18000
[0000.888] Number of retries left 4
[0000.892] Error mask set in wait for cmd complete with error 0x3 in HwSdmmcWaitForCommandComplete
[0000.902] Command complete wait failed with error 0x3 Interrupt 0x18001
[0000.908] Number of retries left 3
[0000.912] Error mask set in wait for cmd complete with error 0x3 in HwSdmmcWaitForCommandComplete
[0000.922] Command complete wait failed with error 0x3 Interrupt 0x18001
[0000.928] Number of retries left 2
[0000.932] Error mask set in wait for cmd complete with error 0x3 in HwSdmmcWaitForCommandComplete
[0000.942] Command complete wait failed with error 0x3 Interrupt 0x18000
[0000.948] Number of retries left 1
[0000.952] Error mask set in wait for cmd complete with error 0x3 in HwSdmmcWaitForCommandComplete
[0000.962] Command complete wait failed with error 0x3 Interrupt 0x18000
[0000.968] Number of retries left 0
[0000.972] Send command failed with 0x3
[0000.975] CMD8 send failed. Retrying CMD0/CMD8 (1)…
[0000.980] Error mask set in wait for cmd complete with error 0x3 in HwSdmmcWaitForCommandComplete
[0000.990] Command complete wait failed with error 0x3 Interrupt 0x18000
[0000.997] Number of retries left 4
[0001.000] Error mask set in wait for cmd complete with error 0x3 in HwSdmmcWaitForCommandComplete
[0001.010] Command complete wait failed with error 0x3 Interrupt 0x18001
[0001.017] Number of retries left 3
[0001.020] Error mask set in wait for cmd complete with error 0x3 in HwSdmmcWaitForCommandComplete
[0001.030] Command complete wait failed with error 0x3 Interrupt 0x18000
[0001.037] Number of retries left 2
[0001.040] Error mask set in wait for cmd complete with error 0x3 in HwSdmmcWaitForCommandComplete
[0001.050] Command complete wait failed with error 0x3 Interrupt 0x18001
[0001.057] Number of retries left 1
[0001.060] Error mask set in wait for cmd complete with error 0x3 in HwSdmmcWaitForCommandComplete
[0001.070] Command complete wait failed with error 0x3 Interrupt 0x18000
[0001.077] Number of retries left 0
[0001.080] Send command failed with 0x3
[0001.084] CMD8 send failed. Retrying CMD0/CMD8 (0)…
[0001.089] Error mask set in wait for cmd complete with error 0x3 in HwSdmmcWaitForCommandComplete
[0001.099] Command complete wait failed with error 0x3 Interrupt 0x18000
[0001.105] Number of retries left 4
[0001.109] Error mask set in wait for cmd complete with error 0x3 in HwSdmmcWaitForCommandComplete
[0001.119] Command complete wait failed with error 0x3 Interrupt 0x18000
[0001.125] Number of retries left 3
[0001.129] Error mask set in wait for cmd complete with error 0x3 in HwSdmmcWaitForCommandComplete
[0001.139] Command complete wait failed with error 0x3 Interrupt 0x18000
[0001.145] Number of retries left 2
[0001.149] Error mask set in wait for cmd complete with error 0x3 in HwSdmmcWaitForCommandComplete
[0001.159] Command complete wait failed with error 0x3 Interrupt 0x18000
[0001.165] Number of retries left 1
[0001.169] Error mask set in wait for cmd complete with error 0x3 in HwSdmmcWaitForCommandComplete
[0001.179] Command complete wait failed with error 0x3 Interrupt 0x18000
[0001.185] Number of retries left 0
[0001.189] Send command failed with 0x3
[0001.192] CMD55 send failed with error 0x3 in SdIdentifyCard func at 1870 line
[0001.199] SD Identify card failed with 0x3
[0001.203] SdIdentifyCard has failed with error 0x3 in NvTbootSdmmcInit func at 87 line
[0001.211] Sdmmc Init failed with 0x3 error
[0001.215] PT: Partition TBC NOT found !
[0001.218] Warning: Find Partition via PT Failed
[0001.223] Read GPT from (4:0)
[0001.226] Error mask set in wait for cmd complete with error 0x3 in HwSdmmcWaitForCommandComplete
[0001.236] Command complete wait failed with error 0x3 Interrupt 0x18000
[0001.243] Number of retries left 4
[0001.246] Error mask set in wait for cmd complete with error 0x3 in HwSdmmcWaitForCommandComplete
[0001.256] Command complete wait failed with error 0x3 Interrupt 0x18000
[0001.263] Number of retries left 3
[0001.266] Error mask set in wait for cmd complete with error 0x3 in HwSdmmcWaitForCommandComplete
[0001.276] Command complete wait failed with error 0x3 Interrupt 0x18000
[0001.283] Number of retries left 2
[0001.286] Error mask set in wait for cmd complete with error 0x3 in HwSdmmcWaitForCommandComplete
[0001.296] Command complete wait failed with error 0x3 Interrupt 0x18001
[0001.303] Number of retries left 1
[0001.306] Error mask set in wait for cmd complete with error 0x3 in HwSdmmcWaitForCommandComplete
[0001.316] Command complete wait failed with error 0x3 Interrupt 0x18000
[0001.323] Number of retries left 0
[0001.326] Send command failed with 0x3
[0001.329] CMD8 send failed. Retrying CMD0/CMD8 (2)…
[0001.335] Error mask set in wait for cmd complete with error 0x3 in HwSdmmcWaitForCommandComplete
[0001.345] Command complete wait failed with error 0x3 Interrupt 0x18001
[0001.351] Number of retries left 4
[0001.355] Error mask set in wait for cmd complete with error 0x3 in HwSdmmcWaitForCommandComplete
[0001.365] Command complete wait failed with error 0x3 Interrupt 0x18000
[0001.371] Number of retries left 3
[0001.375] Error mask set in wait for cmd complete with error 0x3 in HwSdmmcWaitForCommandComplete
[0001.385] Command complete wait failed with error 0x3 Interrupt 0x18000
[0001.391] Number of retries left 2
[0001.395] Error mask set in wait for cmd complete with error 0x3 in HwSdmmcWaitForCommandComplete
[0001.405] Command complete wait failed with error 0x3 Interrupt 0x18000
[0001.411] Number of retries left 1
[0001.415] Error mask set in wait for cmd complete with error 0x3 in HwSdmmcWaitForCommandComplete
[0001.425] Command complete wait failed with error 0x3 Interrupt 0x18000
[0001.431] Number of retries left 0
[0001.434] Send command failed with 0x3
[0001.438] CMD8 send failed. Retrying CMD0/CMD8 (1)…
[0001.443] Error mask set in wait for cmd complete with error 0x3 in HwSdmmcWaitForCommandComplete
[0001.453] Command complete wait failed with error 0x3 Interrupt 0x18000
[0001.460] Number of retries left 4
[0001.463] Error mask set in wait for cmd complete with error 0x3 in HwSdmmcWaitForCommandComplete
[0001.473] Command complete wait failed with error 0x3 Interrupt 0x18000
[0001.480] Number of retries left 3
[0001.483] Error mask set in wait for cmd complete with error 0x3 in HwSdmmcWaitForCommandComplete
[0001.493] Command complete wait failed with error 0x3 Interrupt 0x18000
[0001.500] Number of retries left 2
[0001.503] Error mask set in wait for cmd complete with error 0x3 in HwSdmmcWaitForCommandComplete
[0001.513] Command complete wait failed with error 0x3 Interrupt 0x18000
[0001.520] Number of retries left 1
[0001.523] Error mask set in wait for cmd complete with error 0x3 in HwSdmmcWaitForCommandComplete
[0001.533] Command complete wait failed with error 0x3 Interrupt 0x18000
[0001.540] Number of retries left 0
[0001.543] Send command failed with 0x3
[0001.547] CMD8 send failed. Retrying CMD0/CMD8 (0)…
[0001.552] Error mask set in wait for cmd complete with error 0x3 in HwSdmmcWaitForCommandComplete
[0001.562] Command complete wait failed with error 0x3 Interrupt 0x18000
[0001.568] Number of retries left 4
[0001.572] Error mask set in wait for cmd complete with error 0x3 in HwSdmmcWaitForCommandComplete
[0001.582] Command complete wait failed with error 0x3 Interrupt 0x18000
[0001.588] Number of retries left 3
[0001.592] Error mask set in wait for cmd complete with error 0x3 in HwSdmmcWaitForCommandComplete
[0001.602] Command complete wait failed with error 0x3 Interrupt 0x18000
[0001.608] Number of retries left 2
[0001.612] Error mask set in wait for cmd complete with error 0x3 in HwSdmmcWaitForCommandComplete
[0001.622] Command complete wait failed with error 0x3 Interrupt 0x18000
[0001.628] Number of retries left 1
[0001.632] Error mask set in wait for cmd complete with error 0x3 in HwSdmmcWaitForCommandComplete
[0001.642] Command complete wait failed with error 0x3 Interrupt 0x18000
[0001.648] Number of retries left 0
[0001.651] Send command failed with 0x3
[0001.655] CMD55 send failed with error 0x3 in SdIdentifyCard func at 1870 line
[0001.662] SD Identify card failed with 0x3
[0001.666] SdIdentifyCard has failed with error 0x3 in NvTbootSdmmcInit func at 87 line
[0001.674] Sdmmc Init failed with 0x3 error
[0001.678] PT: Partition TBC NOT found !
[0001.681] Warning: Find Partition via PT Failed
[0001.686] Error is 1
