Is this the correct way to have index x and index y + z?
I need to have something like:
dim3 grid(66212, 50000,39);
dim3 blocks(32, 4,  1);
Where index x = 32x66212 and index y = 4x50000x39.
Is this the correct way of getting that?
unsigned int x = threadIdx.x + blockDim.x * blockIdx.x;
unsigned int blockId = blockIdx.z * gridDim.y + blockIdx.y;
unsigned int y = blockId * blockDim.y + threadIdx.y;
If I understand your question correctly, it should be as simple as
unsigned int y = threadIdx.y + blockDim.y * blockIdx.y;
Check out slide 7 at http://harmanani.github.io/classes/csc447/Notes/Lecture15.pdf
No, you did not understand the question.
I do not want the single x, single y, and single z, I want single x, and y+z because I run out of index using only y.
In my example:
If I do:
I only get x from 32x66212 which is what I want, but for y I only get 4x50000 = 200000, which I do not want since I need more, so that is why I need the index for 4 x 50000 x 39 = 7,800,000.
[s]Here’s a recent question that seems similar:
https://docs.nvidia.com/cuda/cuda-installation-guide-linux/index.html
it may give you some ideas.[/s]
Installation guide, is it the wrong link?
yes, sorry
https://devtalk.nvidia.com/default/topic/1069121/cuda-programming-and-performance/3d-grid-and-3d-block-thread-indexing-for-2-nested-for-loops/
Ok so I guess the first option you gave there is what I am looking for:
int idy = threadIdx.y+blockIdx.y*blockDim.y+blockIdx.z*gridDim.y*blockDim.y;
but…,isn’t it equivalent to the following?
int idy = blockId * blockDim.y + threadIdx.y;
I didn’t mean to suggest that anything you have is wrong. I haven’t really studied your question.
So are they both correct?
They look the same to me.
However, they are not the same, yours has two blockDim.y, so I guess is over-calculated.
