Is UART4 Function Available on Jetson Thor UART4_TX/UART4_RX Pins?
The pins are named UART4_TX and UART4_RX in the Jetson Thor pin description. However, UART4 is not listed in the Design Guide, and I cannot find any UART function for these pins in the pinmux spreadsheet.
Can these pins be configured as UART4 and used as a standard UART interface, or are they reserved for internal use only?
Hi jeonghong0.lee,
Are you using the devkit or custom board for Thor?
UART4 is not supported for customer/application use on Jetson Thor.
Although the pins are named UART4_TX/RX, they are not available as a standard UART4 interface and can only be used as GPIOs (PV.02, PV.03, PV.04, PV.05).
In the latest pinmux sheet, these pins are marked as unused, and some are reserved for CSI I/F connection.
We are using a Jetson Thor T5000 custom carrier board with JetPack 7.1. Does the availability of UART4 as a UART interface depend on the JetPack version? If so, can UART4 be used as a UART interface with a different JetPack release?
No. UART4 availability is not a JetPack-version feature; on Jetson Thor it is not supported for customer/application use, and only the UART channels defined in the Design Guide / pinmux are supported.
So using a different JetPack release would not make UART4 a supported standard UART interface.
