Is Ubuntu 22.04.4 compatible with r36.3?
Hi, I want to use Ubuntu LTS (22.04.4) but I see that the sample-rootfs provided is based on 22.04.2. Are there any inherit incompatibilities that would be an issue if I re-built the rootfs with 22.04.4 base using $L4T_DIR/tools/samplefs/nv_build_samplefs.sh?
Ideally it should fine. You may give it a try. If you hit some issue, may contact Canonical to get help.
