• Hardware Platform (Jetson / GPU): any
• DeepStream Version: any
• JetPack Version (valid for Jetson only): na
• TensorRT Version: any
• NVIDIA GPU Driver Version (valid for GPU only): any
• Issue Type( questions, new requirements, bugs): questions
Gst-nvinfer File Configuration Specifications has the following properties:
gie-unique-id
operate-on-gie-id
operate-on-class-ids
filter-out-class-ids
Gst properties has the following properties:
unique-id
infer-on-gie-id
The document says:
- Gst properties
infer-on-gie-id
overridesoperate-on-gie-id
in the configuration file - Gst properties
overridesoperate-on-class-ids
overridesfilter-out-class-ids
Does Gst properties unique-id
overrides gie-unique-id
in the configuration file? If setting unique-id
doesn’t overrides gie-unique-id
, then:
- what’s the difference between
unique-id
andgie-unique-id
? - does that mean there is no way to set
gie-unique-id
programmatically?
