I upgraded my host machine to an RTX 3090 from a 1070Ti and after trying to execute the graph I get hit with “CUDA error: no kernel image is available for execution on the device”. The target device is an AGX Xavier so visionworks is fine for that, but I want to do the bulk of work on my primary machine. Is this just a case of forced migration to VPI or can you release compatible binaries for newer GPUs? (preferably not bundled with SDK manager, for example VPI can be downloaded separately).
This is my own application which currently uses VisionWorks for image pre-processing before inference, so I guess I cannot do any work on my host machine?
Will VPI be built with 11.0 for its 1.0 release or is it going to stay 10.2 since Jetpack is still 10.2 (with no mention of upgrading on the roadmap).
For Visionworks does /usr/share/visionworks/sources contain all the source code that I need to rebuild for sm_86?
To get CUDA 11.1 release for Visionworks or VPI is under planning, not that quick to be introduced in recent JetPack release. The VPI will go to stay CUDA 10.2 at coming JetPack relese.
