Is your GB10 stuck in low-power mode? A free 45-second check, healthy vs stuck numbers, and the power-drain fix
Two of the eight GB10s in our cluster spent days running at less than half speed with no error, no log entry and no throttle reason. If your Spark (or GX10, or any GB10) suddenly feels slower than everyone else’s numbers, this 45-second check tells you whether it’s this.
The signature: under full load the GPU sits around 500-850 MHz and ~20 W instead of ~2,300 MHz and ~90 W, utilization still reads ~96%, and no throttle reason is reported. A normal reboot doesn’t clear it, and nvidia-smi -lgc is accepted and ignored.
1. Run the check (about a minute)
Stop anything else using the GPU first (model servers, training, ComfyUI); a busy GPU gives a falsely low score.
Save the script below as gb10_clockcheck.py (click to expand), then:
python3 -c "import torch; print(torch.cuda.is_available())"
python3 gb10_clockcheck.py
If the PyTorch line prints an error or False, run it inside the container you already use for vLLM or PyTorch:
docker run --rm --gpus all --entrypoint python3 -v "$PWD":/w YOUR_IMAGE /w/gb10_clockcheck.py
gb10_clockcheck.py (162 lines, click to expand)
#!/usr/bin/env python3
gb10_clockcheck.py — is this GB10 (DGX Spark / ASUS Ascent GX10 / other GB10) stuck in a low-power state?
Runs a 45-second bf16 matrix-multiply burn on the GPU, measures real throughput (TFLOP/s) and samples the
SM clock, power and throttle reasons while it runs. Read-only: it changes no settings.
PRIVACY: this script makes NO network connections, sends nothing anywhere, collects nothing and writes no
files. It only runs a matmul on your GPU and reads nvidia-smi locally. It's ~160 lines; read it before you
run it. (We verified it with a Python audit hook and strace: zero network connections.)
BEFORE YOU RUN IT: stop anything else using the GPU (model servers, training, ComfyUI...). A busy GPU gives a
falsely low score.
Needs: Python 3 + PyTorch with CUDA (any recent NGC / vLLM / PyTorch container works), and nvidia-smi.
    python3 gb10_clockcheck.py            # 45 s test
    python3 gb10_clockcheck.py --seconds 60
By Anantus. Free to use and share. MIT license.
import argparse, shutil, subprocess, sys, threading, time
# Reference results from our own 8-node GB10 cluster (same test: 8192^3 bf16, 45 s, ~96% utilization).
# Other chassis (Dell, HP, MSI, Gigabyte, Lenovo...) may differ; please send us yours.
REFERENCE = [
    ("ASUS Ascent GX10, healthy (7 units)", "88.8 - 93.7 TFLOP/s", "2275 - 2333 MHz", "~89 - 92 W"),
    ("NVIDIA DGX Spark, healthy (1 unit)",  "~77 TFLOP/s",         "lower power envelope", ""),
    ("ASUS Ascent GX10, STUCK (2 units)",   "42.5 TFLOP/s",        "851 MHz",          "20.7 W"),
STUCK_TFLOPS = 60.0   # well below every healthy unit we have seen
STUCK_MHZ = 1400      # median SM clock under full load below this = suspicious
def smi_sample():
    """One nvidia-smi sample: (sm_clock_MHz, power_W, temp_C, throttle_reasons_hex) or None."""
    if not shutil.which("nvidia-smi"):
        return None
    q = "clocks.sm,power.draw,temperature.gpu,clocks_throttle_reasons.active"
    try:
        out = subprocess.run(["nvidia-smi", f"--query-gpu={q}", "--format=csv,noheader,nounits"],
                             capture_output=True, text=True, timeout=10).stdout.strip().splitlines()[0]
        f = [x.strip() for x in out.split(",")]
        num = lambda s: float(s) if s.replace(".", "", 1).isdigit() else None
        return num(f[0]), num(f[1]), num(f[2]), f[3]
    except Exception:
        return None
def other_gpu_processes():
        return []
    try:
        out = subprocess.run(["nvidia-smi", "--query-compute-apps=pid,process_name", "--format=csv,noheader"],
        return [l for l in out.splitlines() if l.strip()]
    except Exception:
        return []
def main():
    ap = argparse.ArgumentParser(description=__doc__.split("\n")[1])
    ap.add_argument("--seconds", type=float, default=45.0)
    ap.add_argument("--size", type=int, default=8192)
    a = ap.parse_args()
    try:
        import torch
    except ImportError:
        sys.exit("PyTorch not found. Run this inside a PyTorch/NGC/vLLM container, or: pip install torch")
    if not torch.cuda.is_available():
        sys.exit("CUDA is not available to PyTorch here (inside Docker, did you pass --gpus all?)")
    busy = other_gpu_processes()
    if busy:
        print("WARNING: other processes are using the GPU; the score will be low for that reason, not a fault:")
        for l in busy:
            print("   ", l)
        print("Stop them and re-run for a valid result.\n")
    n = a.size
    dev = torch.cuda.get_device_name(0)
    print(f"GPU: {dev}  |  test: {n}x{n} bf16 matmul for {a.seconds:.0f} s  (warming up...)")
    x = torch.randn(n, n, device="cuda", dtype=torch.bfloat16)
    y = torch.randn(n, n, device="cuda", dtype=torch.bfloat16)
    for _ in range(10):
        torch.mm(x, y)
    torch.cuda.synchronize()
    samples, stop = [], threading.Event()
    def sampler():
        time.sleep(3)  # let clocks ramp under load first
        while not stop.is_set():
            s = smi_sample()
            if s:
                samples.append(s)
            stop.wait(2)
    th = threading.Thread(target=sampler, daemon=True)
    th.start()
    t0, iters = time.time(), 0
    while time.time() - t0 < a.seconds:
        for _ in range(20):
            torch.mm(x, y)
        iters += 20
    dt = time.time() - t0
    stop.set()
    th.join(timeout=5)
    tflops = 2 * n ** 3 * iters / dt / 1e12
    clocks = sorted(s[0] for s in samples if s[0] is not None)
    powers = sorted(s[1] for s in samples if s[1] is not None)
    temps = [s[2] for s in samples if s[2] is not None]
    reasons = sorted({s[3] for s in samples})
    med = lambda v: v[len(v) // 2] if v else None
    mhz, watts = med(clocks), med(powers)
    print("\n=== RESULT ===")
    print(f"Throughput : {tflops:6.1f} TFLOP/s   ({iters} matmuls in {dt:.1f} s)")
    if mhz is not None:
        print(f"SM clock   : {mhz:6.0f} MHz (median under load)")
    if watts is not None:
        print(f"GPU power  : {watts:6.1f} W   (median under load)")
    if temps:
        print(f"GPU temp   : {max(temps):6.0f} C (max)")
    if reasons:
        print(f"Throttle   : {', '.join(reasons)}  (0x0000000000000000 = none reported)")
    print("\nReference (our cluster, same test):")
    for name, tf, clk, pw in REFERENCE:
        print(f"  {name:40s} {tf:22s} {clk:22s} {pw}")
    no_throttle = all(r.endswith("0000000000000000") or r in ("0x0", "0") for r in reasons) if reasons else True
    low_clock = mhz is not None and mhz < STUCK_MHZ
    print()
    if busy:
        print("VERDICT: NOT VALID - other GPU processes were running. Stop them and re-run.")
    elif tflops < STUCK_TFLOPS and (low_clock or mhz is None) and no_throttle:
        print("VERDICT: LIKELY STUCK in the low-power state (low throughput, low clock, no throttle reason).")
        print("FIX (a reboot will NOT clear it; nvidia-smi -lgc is ignored):")
        print("  1. Shut the unit down completely.")
        print("  2. Unplug the power cord from the wall outlet, unplug it from the power brick,")
        print("     and unplug the brick's cable from the back of the unit. (Also unplug USB devices.)")
        print("  3. Leave everything disconnected for at least 5 minutes.")
        print("  4. Reconnect in this order: cord into the wall outlet -> cord into the power brick ->")
        print("     brick cable into the back of the unit.  Then power on.")
        print("  5. Re-run this check. If it is still stuck, contact your vendor and add your numbers to:")
        print("     https://forums.developer.nvidia.com/t/386060")
    elif tflops < STUCK_TFLOPS:
        print("VERDICT: LOW, but not the classic stuck signature (a throttle reason is active or the clock is high).")
        print("Check cooling/airflow and the throttle reason above, then re-run with nothing else on the GPU.")
    elif tflops < 80:
        print("VERDICT: OK. In the range of lower-power chassis (e.g. NVIDIA DGX Spark ~77). Not stuck.")
    else:
        print("VERDICT: HEALTHY.")
    print("\nPlease share your result + your unit's brand/model so the reference table can grow:")
    print("  https://forums.developer.nvidia.com/t/387029")
if __name__ == "__main__":
    main()
Privacy: it runs entirely on your machine. It makes no network connections, sends nothing to anyone, and writes no files: a bf16 matmul for 45 s plus local nvidia-smi reads. It’s all right there above; read it before you run it. We checked it with a Python audit hook and strace (zero connections).
2. Compare your numbers (same 45 s bf16 8192³ test, our units)
unit throughput clock under load power
ASUS Ascent GX10, healthy (7 units) 88.8-93.7 TFLOP/s 2,275-2,333 MHz ~89-92 W
NVIDIA DGX Spark, healthy (1 unit) ~77 TFLOP/s lower chassis power envelope
ASUS Ascent GX10, stuck (2 units) 42.5 TFLOP/s 851 MHz 20.7 W
Other brands may sit a bit higher or lower when healthy, like the DGX Spark does. The stuck state is far below all of them: well under ~60 TFLOP/s with a low clock and no throttle reason means stuck.
3. The fix: a full power drain, in this exact order
A reboot leaves the power hardware energized, so the state survives it.
  2. Unplug everything: the cord from the wall outlet, the cord from the power brick (the little converter box), and the brick’s cable from the back of the unit. Unplug USB devices too.
  4. Reconnect in this order: cord into the wall outlet first, then into the power brick, then the brick’s cable into the back of the unit last.
  5. Power on and run the check again.
The order matters: in our experience, if the unit gets reconnected before the brick has fully reset, the brick doesn’t reset. This sequence brought our two units back to 93.5 and 95.3 TFLOP/s (~2.2 GHz, ~88 W), and both were still healthy in a full-cluster test ten days later.
4. Still stuck?
Some owners report needing much longer drains, and a few units haven’t recovered. Contact your vendor, and add your numbers to the thread where an NVIDIA moderator is collecting cases: Stuck GPU clock on GB10 (500–800 MHz, zero throttle reasons): a measured case on a Gigabyte AI TOP ATOM, a detector, and a heat side-effect. Credit to @lcasarin, whose report there and open-source blackbox toolkit (it has its own stuck-clock detector) got this documented. This is just a standalone one-file check plus our reference numbers.
Please reply here with your result and your unit’s brand/model, so the reference table covers more machines and the next owner knows what “healthy” looks like for theirs.
