Teresa, Thanks.
no issues pinging developer.nvidia.com
The command used bazel build ...
(Trying to build everything)
running bazel build //packages/detect_net/apps:detect_net_inference_app
works
Interesting, if I run: bazel test ... --jobs=1
I get the similar errors (different packages):
INFO: Build option --features has changed, discarding analysis cache.
WARNING: /home/tarik-deeplearning/Projects/isaac/packages/map/BUILD:23:1: in linkstatic attribute of cc_library rule //packages/map:public_headers: setting 'linkstatic=1' is recommended if there are no object files
INFO: Call stack for the definition of repository 'libtorch_x86_64' which is a http_archive (rule definition at /home/tarik-deeplearning/.cache/bazel/_bazel_tarik-deeplearning/6b9f28e8dbc305f1b40ae17b8215ce62/external/bazel_tools/tools/build_defs/repo/http.bzl:296:16):
- <builtin>
- /home/tarik-deeplearning/Projects/isaac/engine/build/isaac.bzl:425:9
- /home/tarik-deeplearning/Projects/isaac/engine/build/isaac.bzl:432:5
- /home/tarik-deeplearning/Projects/isaac/third_party/packages.bzl:340:5
- /home/tarik-deeplearning/Projects/isaac/WORKSPACE:21:1
INFO: Call stack for the definition of repository 'tlt_parser' which is a http_archive (rule definition at /home/tarik-deeplearning/.cache/bazel/_bazel_tarik-deeplearning/6b9f28e8dbc305f1b40ae17b8215ce62/external/bazel_tools/tools/build_defs/repo/http.bzl:296:16):
- <builtin>
- /home/tarik-deeplearning/Projects/isaac/third_party/packages.bzl:561:5
INFO: Call stack for the definition of repository 'path_segmentation_logs' which is a http_archive (rule definition at /home/tarik-deeplearning/.cache/bazel/_bazel_tarik-deeplearning/6b9f28e8dbc305f1b40ae17b8215ce62/external/bazel_tools/tools/build_defs/repo/http.bzl:296:16):
- <builtin>
- /home/tarik-deeplearning/Projects/isaac/third_party/packages.bzl:512:5
INFO: Call stack for the definition of repository 'torch_inference_test_assets' which is a http_archive (rule definition at /home/tarik-deeplearning/.cache/bazel/_bazel_tarik-deeplearning/6b9f28e8dbc305f1b40ae17b8215ce62/external/bazel_tools/tools/build_defs/repo/http.bzl:296:16):
- <builtin>
- /home/tarik-deeplearning/Projects/isaac/third_party/packages.bzl:83:5
INFO: Call stack for the definition of repository 'lcm' which is a http_archive (rule definition at /home/tarik-deeplearning/.cache/bazel/_bazel_tarik-deeplearning/6b9f28e8dbc305f1b40ae17b8215ce62/external/bazel_tools/tools/build_defs/repo/http.bzl:296:16):
- <builtin>
- /home/tarik-deeplearning/Projects/isaac/third_party/packages.bzl:642:5
WARNING: Download from https://developer.nvidia.com/isaac/download/third_party/path_segmentation_logs_2019_11_14-tar-xz failed: class com.google.devtools.build.lib.bazel.repository.downloader.UnrecoverableHttpException Unknown host: developer.nvidia.com
WARNING: Download from https://developer.nvidia.com/isaac/download/third_party/libtorch_x86_64_1-1-0-v2-tar-xz failed: class com.google.devtools.build.lib.bazel.repository.downloader.UnrecoverableHttpException Unknown host: developer.nvidia.com
ERROR: An error occurred during the fetch of repository 'libtorch_x86_64':
java.io.IOException: Error downloading [https://developer.nvidia.com/isaac/download/third_party/libtorch_x86_64_1-1-0-v2-tar-xz] to /home/tarik-deeplearning/.cache/bazel/_bazel_tarik-deeplearning/6b9f28e8dbc305f1b40ae17b8215ce62/external/libtorch_x86_64/libtorch_x86_64_1-1-0-v2-tar-xz.tar.xz: Unknown host: developer.nvidia.com
WARNING: Download from https://developer.nvidia.com/isaac/download/third_party/torch_inference_test_assets-v2-tar-gz failed: class com.google.devtools.build.lib.bazel.repository.downloader.UnrecoverableHttpException Unknown host: developer.nvidia.com
WARNING: Download from https://developer.nvidia.com/isaac/download/third_party/tlt_parser_20191121-zip failed: class com.google.devtools.build.lib.bazel.repository.downloader.UnrecoverableHttpException Unknown host: developer.nvidia.com
WARNING: Download from https://developer.nvidia.com/isaac/download/third_party/lcm-1-4-0-tar-xz failed: class com.google.devtools.build.lib.bazel.repository.downloader.UnrecoverableHttpException Unknown host: developer.nvidia.com
ERROR: An error occurred during the fetch of repository 'tlt_parser':
java.io.IOException: Error downloading [https://developer.nvidia.com/isaac/download/third_party/tlt_parser_20191121-zip] to /home/tarik-deeplearning/.cache/bazel/_bazel_tarik-deeplearning/6b9f28e8dbc305f1b40ae17b8215ce62/external/tlt_parser/tlt_parser_20191121-zip.zip: Unknown host: developer.nvidia.com
ERROR: An error occurred during the fetch of repository 'torch_inference_test_assets':
java.io.IOException: Error downloading [https://developer.nvidia.com/isaac/download/third_party/torch_inference_test_assets-v2-tar-gz] to /home/tarik-deeplearning/.cache/bazel/_bazel_tarik-deeplearning/6b9f28e8dbc305f1b40ae17b8215ce62/external/torch_inference_test_assets/torch_inference_test_assets-v2-tar-gz.tar.gz: Unknown host: developer.nvidia.com
ERROR: An error occurred during the fetch of repository 'path_segmentation_logs':
java.io.IOException: Error downloading [https://developer.nvidia.com/isaac/download/third_party/path_segmentation_logs_2019_11_14-tar-xz] to /home/tarik-deeplearning/.cache/bazel/_bazel_tarik-deeplearning/6b9f28e8dbc305f1b40ae17b8215ce62/external/path_segmentation_logs/path_segmentation_logs_2019_11_14-tar-xz.tar.xz: Unknown host: developer.nvidia.com
ERROR: An error occurred during the fetch of repository 'lcm':
java.io.IOException: Error downloading [https://developer.nvidia.com/isaac/download/third_party/lcm-1-4-0-tar-xz] to /home/tarik-deeplearning/.cache/bazel/_bazel_tarik-deeplearning/6b9f28e8dbc305f1b40ae17b8215ce62/external/lcm/lcm-1-4-0-tar-xz.tar.xz: Unknown host: developer.nvidia.com
ERROR: /home/tarik-deeplearning/.cache/bazel/_bazel_tarik-deeplearning/6b9f28e8dbc305f1b40ae17b8215ce62/external/laikago_sdk/BUILD.bazel:17:1: @laikago_sdk//:laikago_sdk depends on @lcm//:lcm in repository @lcm which failed to fetch. no such package '@lcm//': java.io.IOException: Error downloading [https://developer.nvidia.com/isaac/download/third_party/lcm-1-4-0-tar-xz] to /home/tarik-deeplearning/.cache/bazel/_bazel_tarik-deeplearning/6b9f28e8dbc305f1b40ae17b8215ce62/external/lcm/lcm-1-4-0-tar-xz.tar.xz: Unknown host: developer.nvidia.com
ERROR: /home/tarik-deeplearning/Projects/isaac/third_party/BUILD:43:1: //third_party:libtorch depends on @libtorch_x86_64//:libtorch_x86_64 in repository @libtorch_x86_64 which failed to fetch. no such package '@libtorch_x86_64//': java.io.IOException: Error downloading [https://developer.nvidia.com/isaac/download/third_party/libtorch_x86_64_1-1-0-v2-tar-xz] to /home/tarik-deeplearning/.cache/bazel/_bazel_tarik-deeplearning/6b9f28e8dbc305f1b40ae17b8215ce62/external/libtorch_x86_64/libtorch_x86_64_1-1-0-v2-tar-xz.tar.xz: Unknown host: developer.nvidia.com
INFO: Call stack for the definition of repository 'opencv_x86_64' which is a http_archive (rule definition at /home/tarik-deeplearning/.cache/bazel/_bazel_tarik-deeplearning/6b9f28e8dbc305f1b40ae17b8215ce62/external/bazel_tools/tools/build_defs/repo/http.bzl:296:16):
- <builtin>
- /home/tarik-deeplearning/Projects/isaac/third_party/packages.bzl:303:5
WARNING: Download from https://developer.nvidia.com/isaac/download/third_party/opencv-3-3-1-x86_64-18-20190327c-tgz failed: class com.google.devtools.build.lib.bazel.repository.downloader.UnrecoverableHttpException Unknown host: developer.nvidia.com
ERROR: An error occurred during the fetch of repository 'opencv_x86_64':
java.io.IOException: Error downloading [https://developer.nvidia.com/isaac/download/third_party/opencv-3-3-1-x86_64-18-20190327c-tgz] to /home/tarik-deeplearning/.cache/bazel/_bazel_tarik-deeplearning/6b9f28e8dbc305f1b40ae17b8215ce62/external/opencv_x86_64/opencv-3-3-1-x86_64-18-20190327c-tgz.tgz: Unknown host: developer.nvidia.com
INFO: Call stack for the definition of repository 'isaac_ros_bridge_x86_64' which is a http_archive (rule definition at /home/tarik-deeplearning/.cache/bazel/_bazel_tarik-deeplearning/6b9f28e8dbc305f1b40ae17b8215ce62/external/bazel_tools/tools/build_defs/repo/http.bzl:296:16):
- <builtin>
- /home/tarik-deeplearning/Projects/isaac/third_party/ros.bzl:18:5
- /home/tarik-deeplearning/Projects/isaac/WORKSPACE:23:1
WARNING: Download from https://developer.nvidia.com/isaac/download/third_party/ros_melodic_x86_64-20190809-tar-gz failed: class com.google.devtools.build.lib.bazel.repository.downloader.UnrecoverableHttpException Unknown host: developer.nvidia.com
ERROR: An error occurred during the fetch of repository 'isaac_ros_bridge_x86_64':
java.io.IOException: Error downloading [https://developer.nvidia.com/isaac/download/third_party/ros_melodic_x86_64-20190809-tar-gz] to /home/tarik-deeplearning/.cache/bazel/_bazel_tarik-deeplearning/6b9f28e8dbc305f1b40ae17b8215ce62/external/isaac_ros_bridge_x86_64/ros_melodic_x86_64-20190809-tar-gz.tar.gz: Unknown host: developer.nvidia.com
ERROR: /home/tarik-deeplearning/Projects/isaac/third_party/BUILD:70:1: //third_party:opencv depends on @opencv_x86_64//:opencv_x86_64 in repository @opencv_x86_64 which failed to fetch. no such package '@opencv_x86_64//': java.io.IOException: Error downloading [https://developer.nvidia.com/isaac/download/third_party/opencv-3-3-1-x86_64-18-20190327c-tgz] to /home/tarik-deeplearning/.cache/bazel/_bazel_tarik-deeplearning/6b9f28e8dbc305f1b40ae17b8215ce62/external/opencv_x86_64/opencv-3-3-1-x86_64-18-20190327c-tgz.tgz: Unknown host: developer.nvidia.com
ERROR: /home/tarik-deeplearning/Projects/isaac/third_party/BUILD:61:1: //third_party:ros depends on @isaac_ros_bridge_x86_64//:isaac_ros_bridge_x86_64 in repository @isaac_ros_bridge_x86_64 which failed to fetch. no such package '@isaac_ros_bridge_x86_64//': java.io.IOException: Error downloading [https://developer.nvidia.com/isaac/download/third_party/ros_melodic_x86_64-20190809-tar-gz] to /home/tarik-deeplearning/.cache/bazel/_bazel_tarik-deeplearning/6b9f28e8dbc305f1b40ae17b8215ce62/external/isaac_ros_bridge_x86_64/ros_melodic_x86_64-20190809-tar-gz.tar.gz: Unknown host: developer.nvidia.com
ERROR: /home/tarik-deeplearning/Projects/isaac/packages/ml/BUILD:29:1: //packages/ml:libtensorrt_module.so depends on @tlt_parser//:tlt_parser in repository @tlt_parser which failed to fetch. no such package '@tlt_parser//': java.io.IOException: Error downloading [https://developer.nvidia.com/isaac/download/third_party/tlt_parser_20191121-zip] to /home/tarik-deeplearning/.cache/bazel/_bazel_tarik-deeplearning/6b9f28e8dbc305f1b40ae17b8215ce62/external/tlt_parser/tlt_parser_20191121-zip.zip: Unknown host: developer.nvidia.com
ERROR: /home/tarik-deeplearning/Projects/isaac/packages/ml/apps/torch_inference/BUILD:25:1: //packages/ml/apps/torch_inference:_torch_inference_check_json depends on @torch_inference_test_assets//:torch_inference_test_assets in repository @torch_inference_test_assets which failed to fetch. no such package '@torch_inference_test_assets//': java.io.IOException: Error downloading [https://developer.nvidia.com/isaac/download/third_party/torch_inference_test_assets-v2-tar-gz] to /home/tarik-deeplearning/.cache/bazel/_bazel_tarik-deeplearning/6b9f28e8dbc305f1b40ae17b8215ce62/external/torch_inference_test_assets/torch_inference_test_assets-v2-tar-gz.tar.gz: Unknown host: developer.nvidia.com
ERROR: /home/tarik-deeplearning/Projects/isaac/packages/ml/apps/torch_inference/BUILD:25:1: //packages/ml/apps/torch_inference:torch_inference depends on @torch_inference_test_assets//:torch_inference_test_assets in repository @torch_inference_test_assets which failed to fetch. no such package '@torch_inference_test_assets//': java.io.IOException: Error downloading [https://developer.nvidia.com/isaac/download/third_party/torch_inference_test_assets-v2-tar-gz] to /home/tarik-deeplearning/.cache/bazel/_bazel_tarik-deeplearning/6b9f28e8dbc305f1b40ae17b8215ce62/external/torch_inference_test_assets/torch_inference_test_assets-v2-tar-gz.tar.gz: Unknown host: developer.nvidia.com
ERROR: /home/tarik-deeplearning/Projects/isaac/packages/freespace_dnn/apps/BUILD:68:1: //packages/freespace_dnn/apps:freespace_dnn_inference_replay depends on @path_segmentation_logs//:path_segmentation_logs in repository @path_segmentation_logs which failed to fetch. no such package '@path_segmentation_logs//': java.io.IOException: Error downloading [https://developer.nvidia.com/isaac/download/third_party/path_segmentation_logs_2019_11_14-tar-xz] to /home/tarik-deeplearning/.cache/bazel/_bazel_tarik-deeplearning/6b9f28e8dbc305f1b40ae17b8215ce62/external/path_segmentation_logs/path_segmentation_logs_2019_11_14-tar-xz.tar.xz: Unknown host: developer.nvidia.com
ERROR: /home/tarik-deeplearning/Projects/isaac/packages/freespace_dnn/apps/BUILD:68:1: //packages/freespace_dnn/apps:_freespace_dnn_inference_replay_check_json depends on @path_segmentation_logs//:path_segmentation_logs in repository @path_segmentation_logs which failed to fetch. no such package '@path_segmentation_logs//': java.io.IOException: Error downloading [https://developer.nvidia.com/isaac/download/third_party/path_segmentation_logs_2019_11_14-tar-xz] to /home/tarik-deeplearning/.cache/bazel/_bazel_tarik-deeplearning/6b9f28e8dbc305f1b40ae17b8215ce62/external/path_segmentation_logs/path_segmentation_logs_2019_11_14-tar-xz.tar.xz: Unknown host: developer.nvidia.com
WARNING: errors encountered while analyzing target '//packages/skeleton_pose_estimation/apps/openpose:trt_pose_inference': it will not be built
WARNING: errors encountered while analyzing target '//third_party:opencv': it will not be built
WARNING: errors encountered while analyzing target '//apps/samples/voice_command_detection:_voice_command_detection_check_json': it will not be built
WARNING: errors encountered while analyzing target '//apps/samples/audio_capture:_audio_capture_check_json': it will not be built
WARNING: errors encountered while analyzing target '//apps/samples/text_to_speech:_text_to_speech_check_json': it will not be built
WARNING: errors encountered while analyzing target '//apps/tutorials/opencv_edge_detection:libedge_detector_module.so': it will not be built
WARNING: errors encountered while analyzing target '//packages/skeleton_pose_estimation/apps/openpose:_openpose_inference_check_json': it will not be built
WARNING: errors encountered while analyzing target '//packages/freespace_dnn/apps:_freespace_dnn_inference_replay_check_json': it will not be built
WARNING: errors encountered while analyzing target '//packages/ml/apps/torch_inference:_torch_inference_check_json': it will not be built
WARNING: errors encountered while analyzing target '//apps/tutorials/opencv_edge_detection:_modlib_edge_detector': it will not be built
WARNING: errors encountered while analyzing target '//apps/tutorials/opencv_edge_detection:_opencv_unity3d_check_json': it will not be built
WARNING: errors encountered while analyzing target '//packages/skeleton_pose_estimation/apps/openpose:openpose_inference': it will not be built
WARNING: errors encountered while analyzing target '//apps/samples/sound_source_localization:_sound_source_localization_check_json': it will not be built
WARNING: errors encountered while analyzing target '//apps/tutorials/opencv_edge_detection:_opencv_edge_detection_check_json': it will not be built
WARNING: errors encountered while analyzing target '//apps/samples/voice_command_detection:voice_command_detection': it will not be built
WARNING: errors encountered while analyzing target '//apps/samples/audio_capture:audio_capture': it will not be built
WARNING: errors encountered while analyzing target '//packages/freespace_dnn/apps:freespace_dnn_inference_replay': it will not be built
WARNING: errors encountered while analyzing target '//apps/samples/sound_source_localization:sound_source_localization': it will not be built
WARNING: errors encountered while analyzing target '//apps/tutorials/opencv_edge_detection:opencv_unity3d': it will not be built
WARNING: errors encountered while analyzing target '//apps/samples/text_to_speech:text_to_speech': it will not be built
WARNING: errors encountered while analyzing target '//apps/tutorials/opencv_edge_detection:opencv_edge_detection': it will not be built
WARNING: errors encountered while analyzing target '//third_party:ros': it will not be built
WARNING: errors encountered while analyzing target '//packages/skeleton_pose_estimation/apps/openpose:_trt_pose_inference_check_json': it will not be built
WARNING: errors encountered while analyzing target '//packages/laikago/components:laikago_driver': it will not be built
WARNING: errors encountered while analyzing target '//third_party:libtorch': it will not be built
WARNING: errors encountered while analyzing target '//packages/ml/apps/torch_inference:torch_inference': it will not be built
INFO: Analysis succeeded for only 1625 of 1651 top-level targets
INFO: Analyzed 1651 targets (315 packages loaded, 11382 targets configured).
INFO: Found 1382 targets and 243 test targets...
INFO: From Executing genrule //packages/composite/tests:composite_atlas_generator_gen:
2020-05-29 11:38:23.266 INFO engine/gems/cask/cask.cpp@58: Creating new log 'waypoints/kv' for writing
FAIL: //engine/alice/tests:throttle (see /home/tarik-deeplearning/.cache/bazel/_bazel_tarik-deeplearning/6b9f28e8dbc305f1b40ae17b8215ce62/execroot/com_nvidia_isaac/bazel-out/k8-opt/testlogs/engine/alice/tests/throttle/test.log)
INFO: From Testing //engine/alice/tests:throttle:
==================== Test output for //engine/alice/tests:throttle:
Running main() from gtest_main.cc
[==========] Running 2 tests from 1 test case.
[----------] Global test environment set-up.
[----------] 2 tests from Alice
[ RUN ] Alice.ThrottleBySignal
2020-05-29 18:57:34.066 WARN engine/alice/backend/application_json_loader.cpp@174: This application does not have an explicit scheduler configuration. One will be autogenerated to the best of the system's abilities if possible.
2020-05-29 18:57:34.066 WARN engine/alice/backend/application_json_loader.cpp@261: The Isaac app file did not contain any modules, config, or graph.
2020-05-29 18:57:34.066 INFO engine/alice/backend/redis_backend.cpp@40: Successfully connected to Redis server.
2020-05-29 18:57:34.067 WARN engine/alice/backend/backend.cpp@201: This application does not have an execution group configuration. One will be autogenerated to the best of the systems abilities if possible.
2020-05-29 18:57:34.067 WARN engine/gems/scheduler/scheduler.cpp@337: No default execution groups specified. Attempting to create scheduler configuration for 12 remaining cores. This may be non optimal for the system and application.
2020-05-29 18:57:34.067 INFO engine/gems/scheduler/scheduler.cpp@290: Scheduler execution groups are:
2020-05-29 18:57:34.067 INFO engine/gems/scheduler/scheduler.cpp@299: __BlockerGroup__: Cores = [9, 10, 11], Workers = No
2020-05-29 18:57:34.067 INFO engine/gems/scheduler/scheduler.cpp@299: __WorkerGroup__: Cores = [0, 1, 2, 3, 4, 5, 6, 7, 8], Workers = Yes
2020-05-29 18:57:34.067 DEBUG engine/alice/application.cpp@348: Loaded 46 components: isaac::alice::BufferAllocatorReport, isaac::alice::ChannelMonitor, isaac::alice::CheckJetsonPerformanceModel, isaac::alice::CheckOperatingSystem, isaac::alice::Config, isaac::alice::ConfigBridge, isaac::alice::ConfigLoader, isaac::alice::Failsafe, isaac::alice::FailsafeHeartbeat, isaac::alice::FooReceiver, isaac::alice::FooTransmitter, isaac::alice::InteractiveMarkersBridge, isaac::alice::JsonToProto, isaac::alice::LifecycleReport, isaac::alice::MessageLedger, isaac::alice::MessagePassingReport, isaac::alice::NodeStatistics, isaac::alice::Pose, isaac::alice::Pose2Comparer, isaac::alice::PoseFromFile, isaac::alice::PoseInitializer, isaac::alice::PoseMessageInjector, isaac::alice::PoseToFile, isaac::alice::PoseToMessage, isaac::alice::PoseTree, isaac::alice::PoseTreeJsonBridge, isaac::alice::PoseTreeRelink, isaac::alice::ProtoToJson, isaac::alice::PyCodelet, isaac::alice::Random, isaac::alice::Recorder, isaac::alice::RecorderBridge, isaac::alice::Replay, isaac::alice::ReplayBridge, isaac::alice::Scheduling, isaac::alice::Sight, isaac::alice::SightChannelStatus, isaac::alice::Subgraph, isaac::alice::Subprocess, isaac::alice::TcpPublisher, isaac::alice::TcpSubscriber, isaac::alice::Throttle, isaac::alice::TimeOffset, isaac::alice::TimeSynchronizer, isaac::alice::UdpPublisher, isaac::alice::UdpSubscriber,
2020-05-29 18:57:34.068 INFO engine/alice/application.cpp@255: Starting application '416c8100-a1de-11ea-a7b6-719b07a95a26' (instance UUID: '416c8556-a1de-11ea-a7b6-719b07a95a26') ...
2020-05-29 18:57:34.068 DEBUG engine/gems/scheduler/execution_groups.cpp@476: Launching 0 pre-start job(s)
2020-05-29 18:57:34.068 DEBUG engine/gems/scheduler/execution_groups.cpp@485: Replaying 0 pre-start event(s)
2020-05-29 18:57:34.068 INFO engine/alice/backend/asio_backend.cpp@33: Starting ASIO service
2020-05-29 18:57:34.069 WARN engine/alice/components/Codelet.cpp@53: Function deprecated. Set tick_period to the desired tick paramater
2020-05-29 18:57:34.069 WARN engine/alice/backend/codelet_canister.cpp@225: Codelet '_check_operating_system/isaac.alice.CheckOperatingSystem' was not added to scheduler because no tick method is specified.
2020-05-29 18:57:34.619 INFO engine/alice/application.cpp@274: Stopping application '416c8100-a1de-11ea-a7b6-719b07a95a26' (instance UUID: '416c8556-a1de-11ea-a7b6-719b07a95a26') ...
2020-05-29 18:57:34.619 INFO engine/alice/backend/backend.cpp@134: Backend is shutting down...
engine/alice/tests/foo_transmission.cpp:76: Failure
The difference between getTickCount() and *expected_tick_count is 2, which exceeds get_expected_tick_count_tolerance(), where
getTickCount() evaluates to 4,
*expected_tick_count evaluates to 6, and
get_expected_tick_count_tolerance() evaluates to 1.
2020-05-29 18:57:34.629 INFO engine/alice/backend/asio_backend.cpp@49: Stopping ASIO service
2020-05-29 18:57:34.639 DEBUG engine/gems/scheduler/execution_groups.cpp@505: Stopping all threads for execution group __BlockerGroup__...
2020-05-29 18:57:34.639 DEBUG engine/gems/scheduler/execution_groups.cpp@509: Stopping all threads DONE
2020-05-29 18:57:34.639 DEBUG engine/gems/scheduler/execution_groups.cpp@505: Stopping all threads for execution group __WorkerGroup__...
2020-05-29 18:57:34.640 DEBUG engine/gems/scheduler/execution_groups.cpp@509: Stopping all threads DONE
2020-05-29 18:57:34.640 INFO engine/alice/backend/backend.cpp@149: Backend is shutting down... DONE
2020-05-29 18:57:34.640 INFO engine/alice/backend/backend.cpp@153: codelets:
| Job Statistics Report (regular) |
| Name | Count | Time (Median - 90% - Max) [ms] | Load (%) | Late (%) |
| isaac.alice.BufferAllocatorReport | 1 | 0.01 | 0.01 | 0.01 | 0.1 % | 0.0 % |
| isaac.alice.LifecycleReport | 3 | 1.89 | 1.89 | 2.55 | 47.0 % | 0.0 % |
| isaac.alice.MessagePassingReport | 1 | 3.05 | 3.05 | 3.05 | 32.3 % | 0.0 % |
| isaac.alice.FooTransmitter | 56 | 0.03 | 0.04 | 0.07 | 16.9 % | 0.0 % |
| isaac.alice.FooTransmitter | 6 | 0.05 | 0.07 | 0.08 | 3.4 % | 0.0 % |
| isaac.alice.FooReceiver | 4 | 0.01 | 0.01 | 0.01 | 0.4 % | 0.0 % |
[ FAILED ] Alice.ThrottleBySignal (574 ms)
[ RUN ] Alice.ThrottleByTimer
2020-05-29 18:57:34.640 WARN engine/alice/backend/application_json_loader.cpp@174: This application does not have an explicit scheduler configuration. One will be autogenerated to the best of the system's abilities if possible.
2020-05-29 18:57:34.640 WARN engine/alice/backend/application_json_loader.cpp@261: The Isaac app file did not contain any modules, config, or graph.
2020-05-29 18:57:34.640 INFO engine/alice/backend/redis_backend.cpp@40: Successfully connected to Redis server.
2020-05-29 18:57:34.641 WARN engine/alice/backend/backend.cpp@201: This application does not have an execution group configuration. One will be autogenerated to the best of the systems abilities if possible.
2020-05-29 18:57:34.641 WARN engine/gems/scheduler/scheduler.cpp@337: No default execution groups specified. Attempting to create scheduler configuration for 12 remaining cores. This may be non optimal for the system and application.
2020-05-29 18:57:34.641 INFO engine/gems/scheduler/scheduler.cpp@290: Scheduler execution groups are:
2020-05-29 18:57:34.641 INFO engine/gems/scheduler/scheduler.cpp@299: __BlockerGroup__: Cores = [9, 10, 11], Workers = No
2020-05-29 18:57:34.641 INFO engine/gems/scheduler/scheduler.cpp@299: __WorkerGroup__: Cores = [0, 1, 2, 3, 4, 5, 6, 7, 8], Workers = Yes
2020-05-29 18:57:34.641 DEBUG engine/alice/application.cpp@348: Loaded 46 components: isaac::alice::BufferAllocatorReport, isaac::alice::ChannelMonitor, isaac::alice::CheckJetsonPerformanceModel, isaac::alice::CheckOperatingSystem, isaac::alice::Config, isaac::alice::ConfigBridge, isaac::alice::ConfigLoader, isaac::alice::Failsafe, isaac::alice::FailsafeHeartbeat, isaac::alice::FooReceiver, isaac::alice::FooTransmitter, isaac::alice::InteractiveMarkersBridge, isaac::alice::JsonToProto, isaac::alice::LifecycleReport, isaac::alice::MessageLedger, isaac::alice::MessagePassingReport, isaac::alice::NodeStatistics, isaac::alice::Pose, isaac::alice::Pose2Comparer, isaac::alice::PoseFromFile, isaac::alice::PoseInitializer, isaac::alice::PoseMessageInjector, isaac::alice::PoseToFile, isaac::alice::PoseToMessage, isaac::alice::PoseTree, isaac::alice::PoseTreeJsonBridge, isaac::alice::PoseTreeRelink, isaac::alice::ProtoToJson, isaac::alice::PyCodelet, isaac::alice::Random, isaac::alice::Recorder, isaac::alice::RecorderBridge, isaac::alice::Replay, isaac::alice::ReplayBridge, isaac::alice::Scheduling, isaac::alice::Sight, isaac::alice::SightChannelStatus, isaac::alice::Subgraph, isaac::alice::Subprocess, isaac::alice::TcpPublisher, isaac::alice::TcpSubscriber, isaac::alice::Throttle, isaac::alice::TimeOffset, isaac::alice::TimeSynchronizer, isaac::alice::UdpPublisher, isaac::alice::UdpSubscriber,
2020-05-29 18:57:34.641 INFO engine/alice/application.cpp@255: Starting application '41c4214e-a1de-11ea-a7b6-719b07a95a26' (instance UUID: '41c42522-a1de-11ea-a7b6-719b07a95a26') ...
2020-05-29 18:57:34.642 DEBUG engine/gems/scheduler/execution_groups.cpp@476: Launching 0 pre-start job(s)
2020-05-29 18:57:34.642 DEBUG engine/gems/scheduler/execution_groups.cpp@485: Replaying 0 pre-start event(s)
2020-05-29 18:57:34.642 INFO engine/alice/backend/asio_backend.cpp@33: Starting ASIO service
2020-05-29 18:57:34.642 WARN engine/alice/components/Codelet.cpp@53: Function deprecated. Set tick_period to the desired tick paramater
2020-05-29 18:57:34.643 WARN engine/alice/backend/codelet_canister.cpp@225: Codelet '_check_operating_system/isaac.alice.CheckOperatingSystem' was not added to scheduler because no tick method is specified.
2020-05-29 18:57:34.643 WARN engine/alice/components/Codelet.cpp@53: Function deprecated. Set tick_period to the desired tick paramater
2020-05-29 18:57:35.193 INFO engine/alice/application.cpp@274: Stopping application '41c4214e-a1de-11ea-a7b6-719b07a95a26' (instance UUID: '41c42522-a1de-11ea-a7b6-719b07a95a26') ...
2020-05-29 18:57:35.193 INFO engine/alice/backend/backend.cpp@134: Backend is shutting down...
2020-05-29 18:57:35.203 INFO engine/alice/backend/asio_backend.cpp@49: Stopping ASIO service
2020-05-29 18:57:35.213 DEBUG engine/gems/scheduler/execution_groups.cpp@505: Stopping all threads for execution group __BlockerGroup__...
2020-05-29 18:57:35.213 DEBUG engine/gems/scheduler/execution_groups.cpp@509: Stopping all threads DONE
2020-05-29 18:57:35.213 DEBUG engine/gems/scheduler/execution_groups.cpp@505: Stopping all threads for execution group __WorkerGroup__...
2020-05-29 18:57:35.213 INFO engine/alice/backend/backend.cpp@149: Backend is shutting down... DONE
2020-05-29 18:57:35.213 INFO engine/alice/backend/backend.cpp@153: codelets:
| isaac.alice.LifecycleReport | 3 | 1.66 | 1.66 | 2.70 | 49.4 % | 0.0 % |
| isaac.alice.MessagePassingReport | 1 | 3.06 | 3.06 | 3.06 | 34.6 % | 0.0 % |
| isaac.alice.FooTransmitter | 55 | 0.02 | 0.03 | 0.06 | 15.4 % | 0.0 % |
| isaac.alice.FooReceiver | 5 | 0.01 | 0.01 | 0.01 | 0.5 % | 0.0 % |
[ OK ] Alice.ThrottleByTimer (574 ms)
[----------] 2 tests from Alice (1148 ms total)
[----------] Global test environment tear-down
[==========] 2 tests from 1 test case ran. (1148 ms total)
[ PASSED ] 1 test.
[ FAILED ] 1 test, listed below:
1 FAILED TEST
ERROR: command succeeded, but there were loading phase errors
INFO: Elapsed time: 2865.741s, Critical Path: 67.41s
INFO: 2005 processes: 1964 linux-sandbox, 41 local.
FAILED: Build did NOT complete successfully
//apps/carter:_carter_check_json PASSED in 0.2s
//apps/carter/autonomous_data_collection:_carter_data_collection_check_json PASSED in 0.3s
//apps/carter/carter_delivery:_carter_delivery_check_json PASSED in 0.2s
//apps/carter/carter_delivery:_carter_delivery_flatsim_check_json PASSED in 0.2s
//apps/carter/carter_sim:_carter_sim_check_json PASSED in 0.2s
//apps/carter/carter_sim:_carter_sim_joystick_check_json PASSED in 0.1s
//apps/carter/carter_sim:_carter_sim_mapping_check_json PASSED in 0.2s
//apps/carter/gmapping:_gmapping_check_json PASSED in 0.1s
//apps/carter/log_cartographer:_log_cartographer_check_json PASSED in 0.1s
//apps/carter/log_gmapping:_log_gmapping_check_json PASSED in 0.1s
//apps/carter/replay:_replay_check_json PASSED in 0.1s
//apps/carter/slackbot:_slackbot_check_json PASSED in 0.2s
//apps/kaya:_follow_me_check_json PASSED in 0.2s
//apps/kaya:_gmapping_distributed_host_check_json PASSED in 0.1s
//apps/kaya:_gmapping_distributed_kaya_check_json PASSED in 0.1s
//apps/kaya:_joystick_check_json PASSED in 0.1s
//apps/kaya:_navigate_check_json PASSED in 0.2s
//apps/kaya:_object_detection_check_json PASSED in 0.2s
//apps/map_editor:_map_editor_check_json PASSED in 0.1s
//apps/navsim:_navsim_gmapping_check_json PASSED in 0.1s
//apps/navsim/multirobot:_mosaic_check_json PASSED in 0.1s
//apps/navsim/multirobot:_navsim_client_check_json PASSED in 0.1s
//apps/navsim/multirobot:_navsim_navigate_check_json PASSED in 0.2s
//apps/navsim/multirobot:_navsim_server_check_json PASSED in 0.1s
//apps/samples/april_tags:_april_tags_check_json PASSED in 0.1s
//apps/samples/follow_me:_follow_me_check_json PASSED in 0.2s
//apps/samples/hgmm_matching:_hgmm_matching_check_json PASSED in 0.1s
//apps/samples/image_undistortion:_image_undistortion_check_json PASSED in 0.1s
//apps/samples/imu:_imu_check_json PASSED in 0.1s
//apps/samples/imu_calibration:_imu_calibration_check_json PASSED in 0.1s
//apps/samples/imu_sim:_imu_sim_check_json PASSED in 0.1s
//apps/samples/interactive_markers:_interactive_markers_check_json PASSED in 0.1s
//apps/samples/proto_to_json:_proto_to_json_check_json PASSED in 0.1s
//apps/samples/pwm:_pwm_check_json PASSED in 0.1s
//apps/samples/realsense_camera:_realsense_camera_check_json PASSED in 0.1s
//apps/samples/realsense_camera:_realsense_multicam_check_json PASSED in 0.1s
//apps/samples/stereo_depth_dnn:_stereo_depth_dnn_check_json PASSED in 0.1s
//apps/samples/stereo_dummy:_stereo_dummy_check_json PASSED in 0.1s
//apps/samples/stereo_matching_depth:_stereo_matching_depth_check_json PASSED in 0.1s
//apps/samples/stereo_rectification:_stereo_rectification_check_json PASSED in 0.1s
//apps/samples/stereo_vo:_stereo_vo_check_json PASSED in 0.1s
//apps/samples/subprocess:_subprocess_check_json PASSED in 0.1s
//apps/samples/teleport_sim:_teleport_sim_check_json PASSED in 0.1s
//apps/samples/v4l2_camera:_v4l2_camera_check_json PASSED in 0.1s
//apps/samples/zed_camera:_zed_camera_check_json PASSED in 0.1s
//apps/tutorials/cuda_ping_pong:_cuda_ping_pong_check_json PASSED in 0.1s
//apps/tutorials/ping:_ping_check_json PASSED in 0.1s
//apps/tutorials/ping_net:_ping_check_json PASSED in 0.1s
//apps/tutorials/ping_net:_pong_check_json PASSED in 0.1s
//apps/tutorials/ping_pong:_ping_pong_check_json PASSED in 0.1s
//apps/tutorials/proportional_control_cpp:_proportional_control_cpp_check_json PASSED in 0.1s
//apps/tutorials/simple_robot:_simple_robot_check_json PASSED in 0.1s
//apps/tutorials/webinar_1:_goal_generator_navsim_check_json PASSED in 0.2s
//apps/tutorials/webinar_1:_goal_generator_real_check_json PASSED in 0.2s
//apps/tutorials/webinar_1:_goal_generator_sim_check_json PASSED in 0.2s
//apps/tutorials/webinar_1:_goal_generator_test_check_json PASSED in 0.1s
//apps/tutorials/webinar_1:_my_goal_generator_test_check_json PASSED in 0.1s
//engine/alice/c_api/tests:application_test PASSED in 3.2s
//engine/alice/c_api/tests:message_test PASSED in 0.8s
//engine/alice/c_api/tests:thread PASSED in 6.2s
//engine/alice/tests:app_load PASSED in 0.6s
//engine/alice/tests:capnproto PASSED in 0.1s
//engine/alice/tests:codelet_lifecycle PASSED in 0.2s
//engine/alice/tests:codelet_registry PASSED in 0.1s
//engine/alice/tests:codelet_start_if_no_trigger PASSED in 0.1s
//engine/alice/tests:codelet_tick_period PASSED in 2.1s
//engine/alice/tests:config_immutability PASSED in 2.2s
//engine/alice/tests:config_parallel PASSED in 1.2s
//engine/alice/tests:config_test PASSED in 0.8s
//engine/alice/tests:connect_in_start PASSED in 0.4s
//engine/alice/tests:crashdump_sh PASSED in 0.3s
//engine/alice/tests:create PASSED in 1.4s
//engine/alice/tests:destroy_node PASSED in 0.3s
//engine/alice/tests:dynamic_ping PASSED in 2.4s
//engine/alice/tests:event_overload PASSED in 3.1s
//engine/alice/tests:jammer PASSED in 1.1s
//engine/alice/tests:live_node_creation PASSED in 1.6s
//engine/alice/tests:message_hop PASSED in 2.1s
//engine/alice/tests:message_images PASSED in 0.7s
//engine/alice/tests:message_loop PASSED in 2.1s
//engine/alice/tests:modules PASSED in 0.1s
//engine/alice/tests:network_images_tcp PASSED in 3.6s
//engine/alice/tests:network_large_blobs PASSED in 8.6s
//engine/alice/tests:network_ping PASSED in 5.6s
//engine/alice/tests:path_utils PASSED in 0.1s
//engine/alice/tests:pose PASSED in 0.6s
//engine/alice/tests:pose_to_message PASSED in 0.4s
//engine/alice/tests:pose_tree PASSED in 0.1s
//engine/alice/tests:proto_json PASSED in 1.1s
//engine/alice/tests:proto_ping PASSED in 0.7s
//engine/alice/tests:raw_ping PASSED in 0.6s
//engine/alice/tests:record_replay_images PASSED in 9.3s
//engine/alice/tests:record_replay_loop PASSED in 1.9s
//engine/alice/tests:save_load_app PASSED in 1.1s
//engine/alice/tests:stacktrace PASSED in 0.2s
//engine/alice/tests:stresstest_ping PASSED in 10.1s
//engine/alice/tests:subgraphs PASSED in 2.9s
//engine/alice/tests:synchronize PASSED in 8.3s
//engine/alice/tests:the_fall PASSED in 0.5s
//engine/alice/tests:tick_tock PASSED in 0.7s
//engine/alice/tests:time_offset PASSED in 0.6s
//engine/alice/tests:variables PASSED in 0.4s
//engine/core/allocator/tests:allocator PASSED in 0.2s
//engine/core/array/tests:cpu_array PASSED in 1.5s
//engine/core/array/tests:cpu_array_view PASSED in 0.1s
//engine/core/buffers/tests:algorithm PASSED in 0.4s
//engine/core/buffers/tests:buffer PASSED in 0.1s
//engine/core/buffers/tests:shared_buffer PASSED in 0.4s
//engine/core/image/tests:image PASSED in 0.4s
//engine/core/math/tests:tests PASSED in 0.1s
//engine/core/tensor/tests:element_type PASSED in 0.1s
//engine/core/tensor/tests:sample_cloud PASSED in 0.1s
//engine/core/tensor/tests:tensor PASSED in 0.1s
//engine/core/tensor/tests:universal_tensor PASSED in 0.1s
//engine/core/tests:assert PASSED in 0.6s
//engine/core/tests:constants PASSED in 0.1s
//engine/core/tests:epsilon PASSED in 0.1s
//engine/core/tests:logger PASSED in 0.1s
//engine/core/tests:singleton PASSED in 0.1s
//engine/core/tests:string_literal PASSED in 0.1s
//engine/core/tests:time PASSED in 2.0s
//engine/gems/algorithm/tests:tests PASSED in 0.5s
//engine/gems/composite/test:typelist_composite_basics PASSED in 0.1s
//engine/gems/composite/test:typelist_composite_nested PASSED in 0.1s
//engine/gems/composite/test:typelist_composite_thorough PASSED in 0.1s
//engine/gems/geometry/tests:convex_hull PASSED in 0.5s
//engine/gems/geometry/tests:line_utils PASSED in 0.1s
//engine/gems/geometry/tests:pinhole PASSED in 0.1s
//engine/gems/geometry/tests:plane_utils PASSED in 0.2s
//engine/gems/geometry/tests:polygon PASSED in 0.1s
//engine/gems/geometry/tests:transform_to_plane PASSED in 0.5s
//engine/gems/geometry/tests:types PASSED in 0.1s
//engine/gems/graph/tests:djikstra PASSED in 0.1s
//engine/gems/image/tests:color PASSED in 0.1s
//engine/gems/image/tests:conversions PASSED in 0.7s
//engine/gems/image/tests:cuda_utils PASSED in 0.9s
//engine/gems/image/tests:distance_map PASSED in 1.5s
//engine/gems/image/tests:io PASSED in 0.1s
//engine/gems/image/tests:utils PASSED in 0.2s
//engine/gems/interpolation/tests:tests PASSED in 0.2s
//engine/gems/kinematic_tree/tests:json_loader PASSED in 0.1s
//engine/gems/kinematic_tree/tests:kinematic PASSED in 3.0s
//engine/gems/math/tests:activations PASSED in 0.1s
//engine/gems/math/tests:bezier PASSED in 0.1s
//engine/gems/math/tests:catmull_rom PASSED in 0.1s
//engine/gems/math/tests:exponential_moving_average PASSED in 0.1s
//engine/gems/math/tests:fast_running_median PASSED in 0.1s
//engine/gems/math/tests:float16 PASSED in 0.1s
//engine/gems/math/tests:icosphere_sampling PASSED in 0.1s
//engine/gems/math/tests:pose_average PASSED in 0.1s
//engine/gems/math/tests:pose_utils PASSED in 0.1s
//engine/gems/ml/tests:cosine_similarity_tests PASSED in 0.9s
//engine/gems/ml/tests:object_detection_utils_tests PASSED in 0.1s
//engine/gems/optimization/tests:gradient_descent PASSED in 0.1s
//engine/gems/optimization/tests:pso_ackley PASSED in 0.1s
//engine/gems/partitions/tests:gridmap PASSED in 0.1s
//engine/gems/partitions/tests:plane_partition PASSED in 0.1s
//engine/gems/partitions/tests:polar_partition PASSED in 0.1s
//engine/gems/partitions/tests:regular_interval_partition PASSED in 0.1s
//engine/gems/partitions/tests:regular_partition PASSED in 0.1s
//engine/gems/partitions/tests:ring_partition PASSED in 0.1s
//engine/gems/pose_tree/tests:tests PASSED in 0.1s
//engine/gems/scheduler/tests:tests PASSED in 5.6s
//engine/gems/serialization/tests:tests PASSED in 0.1s
//engine/gems/sight/tests:json_key_truncation PASSED in 0.1s
//engine/gems/sight/tests:kinematic_json_test PASSED in 0.1s
//engine/gems/sight/tests:sop_from_file PASSED in 0.1s
//engine/gems/state/test:io PASSED in 0.1s
//engine/gems/state/test:state PASSED in 0.1s
//engine/gems/state_machine/tests:tests PASSED in 0.1s
//engine/gems/tensor/tests:copy PASSED in 3.8s
//engine/gems/tensor/tests:transpose PASSED in 0.4s
//engine/gems/uuid/tests:tests PASSED in 0.2s
//engine/pyalice/tests:application_test PASSED in 4.7s
//engine/pyalice/tests:buffer_test PASSED in 3.0s
//engine/pyalice/tests:cask_test PASSED in 1.0s
//engine/pyalice/tests:component_test PASSED in 0.9s
//engine/pyalice/tests:composite_test PASSED in 0.9s
//engine/pyalice/tests:pyapp_config_test PASSED in 0.9s
//engine/pyalice/tests:pycodelet_test PASSED in 6.6s
//engine/pyalice/tests:pymessage_test PASSED in 1.7s
//engine/pyalice/tests:pynode_test PASSED in 2.1s
//engine/pyalice/tests:status_test PASSED in 1.9s
//messages/tests:tensor PASSED in 0.1s
//packages/behavior_tree/apps:_missions_missions.graph.json_check_json PASSED in 0.1s
//packages/behavior_tree/tests:combined PASSED in 21.1s
//packages/behavior_tree/tests:repeat PASSED in 3.1s
//packages/behavior_tree/tests:small PASSED in 5.7s
//packages/cart_delivery/apps:_cart_delivery_json_check_json PASSED in 0.2s
//packages/cart_delivery/apps:_gmapping_check_json PASSED in 0.1s
//packages/cart_delivery/apps:_navigate_check_json PASSED in 0.2s
//packages/cart_delivery/apps:_perception_check_json PASSED in 0.2s
//packages/composite/gems/tests:composite_writer PASSED in 0.1s
//packages/composite/tests:composite_metric PASSED in 1.1s
//packages/composite/tests:composite_publisher PASSED in 1.2s
//packages/composite/tests:follow_path PASSED in 1.8s
//packages/deepstream/apps:_gstreamer_pipeline_check_json PASSED in 0.1s
//packages/deepstream/apps:_gstreamer_pipeline_distributed_a_check_json PASSED in 0.1s
//packages/deepstream/apps:_gstreamer_pipeline_distributed_b_check_json PASSED in 0.1s
//packages/deepstream/apps:_gstreamer_pipeline_external_check_json PASSED in 0.1s
//packages/deepstream/apps:_gstreamer_pipeline_multi_check_json PASSED in 0.1s
//packages/deepstream/apps:_logitech_c920pro_cpu_check_json PASSED in 0.1s
//packages/deepstream/apps:_philips_spc1330nc_check_json PASSED in 0.1s
//packages/deepstream/apps:_sony_snchmx70_check_json PASSED in 0.1s
//packages/dynamixel/apps:_dynamixel_test_check_json PASSED in 0.1s
//packages/flatsim/apps:_2d_differential_base_simulation_subgraph_2d_differential_base_simulation.subgraph.json_check_json PASSED in 0.1s
//packages/flatsim/apps:_demo_1_demo_1.json_check_json PASSED in 0.1s
//packages/flatsim/apps:_demo_2_demo_2.json_check_json PASSED in 0.1s
//packages/flatsim/apps:_demo_3_demo_3.json_check_json PASSED in 0.1s
//packages/flatsim/apps:_demo_4_demo_4.json_check_json PASSED in 0.1s
//packages/flatsim/apps:_demo_5_demo_5.json_check_json PASSED in 0.1s
//packages/flatsim/apps:_flatsim_subgraph_flatsim.subgraph.json_check_json PASSED in 0.2s
//packages/freespace_dnn/apps:_freespace_dnn_inference_image_check_json PASSED in 0.2s
//packages/freespace_dnn/apps:_freespace_dnn_inference_unity3d_check_json PASSED in 0.2s
//packages/freespace_dnn/apps:_freespace_dnn_inference_v4l2_check_json PASSED in 0.2s
//packages/lidar_slam/apps:_differential_base_cartographer_subgraph_differential_base_cartographer.subgraph.json_check_json PASSED in 0.1s
//packages/lidar_slam/apps:_differential_base_gmapping_subgraph_differential_base_gmapping.subgraph.json_check_json PASSED in 0.1s
//packages/livox/apps/livox_lidar_visualization:_livox_lidar_visualization_check_json PASSED in 0.1s
//packages/message_generators/tests:flatscan_consumption PASSED in 60.1s
//packages/message_generators/tests:image_loader PASSED in 1.2s
//packages/ml/apps/generate_kitti_dataset:_generate_kitti_dataset_check_json PASSED in 0.1s
//packages/navsim/apps:_navsim_check_json PASSED in 0.1s
//packages/navsim/apps:_navsim_viewer_tcp_check_json PASSED in 0.1s
//packages/object_pose_estimation/apps/autoencoder:_codebook_generation_check_json PASSED in 0.1s
//packages/object_pose_estimation/apps/autoencoder:_pose_estimation_inference_camerafeed_check_json PASSED in 0.2s
//packages/object_pose_estimation/apps/autoencoder:_pose_estimation_inference_imagefeeder_check_json PASSED in 0.1s
//packages/object_pose_estimation/apps/autoencoder:_pose_estimation_inference_replay_check_json PASSED in 0.1s
//packages/object_pose_estimation/apps/autoencoder:_pose_estimation_inference_sim_check_json PASSED in 0.1s
//packages/object_pose_refinement/apps:_pose_refinement_camerafeed_check_json PASSED in 0.2s
//packages/object_pose_refinement/apps:_pose_refinement_imagefeed_check_json PASSED in 0.2s
//packages/object_pose_refinement/apps:_pose_refinement_replay_check_json PASSED in 0.2s
//packages/orb/apps/orb_demo:_orb_demo_check_json PASSED in 0.1s
//packages/perception/apps:_warp_equirectangular_check_json PASSED in 0.1s
//packages/planner/apps:_pose2_graph_builder_check_json PASSED in 0.1s
//packages/planner/apps:_pose2_graph_builder_subgraph_pose2_graph_builder.subgraph.json_check_json PASSED in 0.1s
//packages/rgbd_processing/apps:_image_points_edges_normals_check_json PASSED in 0.1s
//packages/rl/apps/dolly_navigation/py_components:_dolly_demo_sim_check_json PASSED in 0.3s
//packages/superpixels/apps:_image_superpixels_check_json PASSED in 0.1s
//packages/superpixels/apps:_live_superpixels_check_json PASSED in 0.1s
//packages/velodyne_lidar/apps:_vlp16_sample_check_json PASSED in 0.1s
//packages/ydlidar/apps:_ydlidar_sample_check_json PASSED in 0.1s
//packages/zed/gems/test:time_offset_calculator PASSED in 0.1s
//engine/alice/tests:throttle FAILED in 1.2s
Executed 243 out of 243 tests: 242 tests pass and 1 fails locally.
