Ubuntu 18.04
bazel 3.2.0
Isaac Sim SDK 2020.1
bazel run packages/cart_delivery/apps:cart_delivery
Starting local Bazel server and connecting to it…
INFO: Analyzed target //packages/cart_delivery/apps:cart_delivery (131 packages loaded, 6079 targets configured).
INFO: Found 1 target…
INFO: Deleting stale sandbox base /home/huangwei/.cache/bazel/_bazel_huangwei/2896d33b7554825b9a7cf05d55b4838b/sandbox
Target //packages/cart_delivery/apps:cart_delivery up-to-date:
bazel-bin/packages/cart_delivery/apps/cart_delivery
INFO: Elapsed time: 39.709s, Critical Path: 24.52s
INFO: 7 processes: 7 linux-sandbox.
INFO: Build completed successfully, 8 total actions
2020-06-02 09:28:02.644 INFO engine/alice/tools/websight.cpp@166: Loading websight…
2020-06-02 09:28:02.645 WARN engine/alice/backend/application_json_loader.cpp@174: This application does not have an explicit scheduler configuration. One will be autogenerated to the best of the system’s abilities if possible.
2020-06-02 09:28:02.646 INFO engine/alice/backend/application_json_loader.cpp@344: Modules requested by subgraph ‘delivery’: (behavior_tree), message_generators, navigation, utils,
2020-06-02 09:28:02.652 INFO engine/alice/backend/application_json_loader.cpp@344: Modules requested by subgraph ‘navigation’: (map), (navigation), planner, (sight),
2020-06-02 09:28:02.652 INFO engine/alice/backend/application_json_loader.cpp@344: Modules requested by subgraph ‘local_map’: (navigation),
2020-06-02 09:28:02.652 INFO engine/alice/backend/application_json_loader.cpp@344: Modules requested by subgraph ‘go_to’: (behavior_tree), (navigation), viewers,
2020-06-02 09:28:02.653 INFO engine/alice/backend/application_json_loader.cpp@344: Modules requested by subgraph ‘planner’: (behavior_tree), (navigation), (planner),
2020-06-02 09:28:02.653 INFO engine/alice/backend/application_json_loader.cpp@344: Modules requested by subgraph ‘control’: (behavior_tree), (message_generators), (navigation), (planner),
2020-06-02 09:28:02.653 INFO engine/alice/backend/application_json_loader.cpp@344: Modules requested by subgraph ‘localization’: (behavior_tree), flatscan_localization, (navigation), (utils), (viewers),
2020-06-02 09:28:02.654 INFO engine/alice/backend/application_json_loader.cpp@344: Modules requested by subgraph ‘imu_odometry’: imu, (navigation),
2020-06-02 09:28:02.654 INFO engine/alice/backend/application_json_loader.cpp@344: Modules requested by subgraph ‘detection_pose_estimation’: (sight), (utils), (viewers),
2020-06-02 09:28:02.654 INFO engine/alice/backend/application_json_loader.cpp@344: Modules requested by subgraph ‘object_detection’: detect_net, ml, perception, (sight), (viewers),
2020-06-02 09:28:02.655 INFO engine/alice/backend/application_json_loader.cpp@344: Modules requested by subgraph ‘object_pose_estimation’: (ml), object_pose_estimation,
2020-06-02 09:28:02.655 INFO engine/alice/backend/application_json_loader.cpp@344: Modules requested by subgraph ‘simulation’: (imu), navsim, (utils),
2020-06-02 09:28:02.656 INFO engine/alice/backend/application_json_loader.cpp@344: Modules requested by subgraph ‘noisy_flatscan_1’: (perception), flatsim,
2020-06-02 09:28:02.656 INFO engine/alice/backend/application_json_loader.cpp@344: Modules requested by subgraph ‘noisy_flatscan_2’: (perception), (flatsim),
2020-06-02 09:28:02.663 INFO engine/alice/backend/redis_backend.cpp@40: Successfully connected to Redis server.
2020-06-02 09:28:02.663 WARN engine/alice/backend/backend.cpp@201: This application does not have an execution group configuration. One will be autogenerated to the best of the systems abilities if possible.
2020-06-02 09:28:02.663 WARN engine/gems/scheduler/scheduler.cpp@337: No default execution groups specified. Attempting to create scheduler configuration for 12 remaining cores. This may be non optimal for the system and application.
2020-06-02 09:28:02.663 INFO engine/gems/scheduler/scheduler.cpp@290: Scheduler execution groups are:
2020-06-02 09:28:02.663 INFO engine/gems/scheduler/scheduler.cpp@299: BlockerGroup: Cores = [9, 10, 11], Workers = No
2020-06-02 09:28:02.663 INFO engine/gems/scheduler/scheduler.cpp@299: WorkerGroup: Cores = [0, 1, 2, 3, 4, 5, 6, 7, 8], Workers = Yes
2020-06-02 09:28:02.663 INFO engine/alice/backend/modules.cpp@241: libraries name ‘packages/behavior_tree/libbehavior_tree_module.so’
2020-06-02 09:28:02.666 INFO engine/alice/backend/modules.cpp@226: Loaded module ‘packages/behavior_tree/libbehavior_tree_module.so’: Now has 58 components total
2020-06-02 09:28:02.666 INFO engine/alice/backend/modules.cpp@241: libraries name ‘packages/detect_net/libdetect_net_module.so’
2020-06-02 09:28:02.669 INFO engine/alice/backend/modules.cpp@226: Loaded module ‘packages/detect_net/libdetect_net_module.so’: Now has 59 components total
2020-06-02 09:28:02.669 INFO engine/alice/backend/modules.cpp@241: libraries name ‘packages/flatscan_localization/libflatscan_localization_module.so’
2020-06-02 09:28:02.673 INFO engine/alice/backend/modules.cpp@226: Loaded module ‘packages/flatscan_localization/libflatscan_localization_module.so’: Now has 73 components total
2020-06-02 09:28:02.673 INFO engine/alice/backend/modules.cpp@241: libraries name ‘packages/flatsim/libflatsim_module.so’
2020-06-02 09:28:02.677 INFO engine/alice/backend/modules.cpp@226: Loaded module ‘packages/flatsim/libflatsim_module.so’: Now has 79 components total
2020-06-02 09:28:02.677 INFO engine/alice/backend/modules.cpp@241: libraries name ‘packages/imu/libimu_module.so’
2020-06-02 09:28:02.682 INFO engine/alice/backend/modules.cpp@226: Loaded module ‘packages/imu/libimu_module.so’: Now has 83 components total
2020-06-02 09:28:02.682 INFO engine/alice/backend/modules.cpp@241: libraries name ‘packages/map/libmap_module.so’
2020-06-02 09:28:02.687 INFO engine/alice/backend/modules.cpp@226: Loaded module ‘packages/map/libmap_module.so’: Now has 92 components total
2020-06-02 09:28:02.687 INFO engine/alice/backend/modules.cpp@241: libraries name ‘packages/message_generators/libmessage_generators_module.so’
2020-06-02 09:28:02.692 INFO engine/alice/backend/modules.cpp@226: Loaded module ‘packages/message_generators/libmessage_generators_module.so’: Now has 110 components total
2020-06-02 09:28:02.692 INFO engine/alice/backend/modules.cpp@241: libraries name ‘packages/ml/libml_module.so’
2020-06-02 09:28:02.914 INFO engine/alice/backend/modules.cpp@241: libraries name ‘packages/navigation/libnavigation_module.so’
2020-06-02 09:28:02.946 INFO engine/alice/backend/modules.cpp@226: Loaded module ‘packages/navigation/libnavigation_module.so’: Now has 142 components total
2020-06-02 09:28:02.946 INFO engine/alice/backend/modules.cpp@241: libraries name ‘packages/navsim/libnavsim_module.so’
2020-06-02 09:28:03.054 INFO engine/alice/backend/modules.cpp@226: Loaded module ‘packages/navsim/libnavsim_module.so’: Now has 144 components total
2020-06-02 09:28:03.054 INFO engine/alice/backend/modules.cpp@241: libraries name ‘packages/object_pose_estimation/libobject_pose_estimation_module.so’
2020-06-02 09:28:03.112 INFO engine/alice/backend/modules.cpp@226: Loaded module ‘packages/object_pose_estimation/libobject_pose_estimation_module.so’: Now has 152 components total
2020-06-02 09:28:03.112 INFO engine/alice/backend/modules.cpp@241: libraries name ‘packages/perception/libperception_module.so’
2020-06-02 09:28:03.285 INFO engine/alice/backend/modules.cpp@241: libraries name ‘packages/planner/libplanner_module.so’
2020-06-02 09:28:03.349 INFO engine/alice/backend/modules.cpp@226: Loaded module ‘packages/planner/libplanner_module.so’: Now has 165 components total
2020-06-02 09:28:03.349 INFO engine/alice/backend/modules.cpp@241: libraries name ‘packages/sight/libsight_module.so’
2020-06-02 09:28:03.398 INFO engine/alice/backend/modules.cpp@226: Loaded module ‘packages/sight/libsight_module.so’: Now has 167 components total
2020-06-02 09:28:03.398 INFO engine/alice/backend/modules.cpp@241: libraries name ‘packages/utils/libutils_module.so’
2020-06-02 09:28:03.421 INFO engine/alice/backend/modules.cpp@226: Loaded module ‘packages/utils/libutils_module.so’: Now has 184 components total
2020-06-02 09:28:03.421 INFO engine/alice/backend/modules.cpp@241: libraries name ‘packages/viewers/libviewers_module.so’
2020-06-02 09:28:03.434 INFO engine/alice/backend/modules.cpp@226: Loaded module ‘packages/viewers/libviewers_module.so’: Now has 204 components total
2020-06-02 09:28:03.434 INFO engine/alice/backend/modules.cpp@241: libraries name ‘packages/ml/libml_module.so’
2020-06-02 09:28:03.434 INFO engine/alice/backend/modules.cpp@241: libraries name ‘packages/perception/libperception_module.so’
2020-06-02 09:28:03.434 ERROR engine/alice/backend/modules.cpp@251: packages/ml/libml_module.so: /home/huangwei/.cache/bazel/_bazel_huangwei/2896d33b7554825b9a7cf05d55b4838b/execroot/com_nvidia_isaac/bazel-out/k8-opt/bin/packages/cart_delivery/apps/cart_delivery.runfiles/com_nvidia_isaac//packages/ml/libml_module.so: undefined symbol: IsaacGatherComponentInfo
2020-06-02 09:28:03.434 ERROR engine/alice/backend/modules.cpp@251: packages/perception/libperception_module.so: /home/huangwei/.cache/bazel/_bazel_huangwei/2896d33b7554825b9a7cf05d55b4838b/execroot/com_nvidia_isaac/bazel-out/k8-opt/bin/packages/cart_delivery/apps/cart_delivery.runfiles/com_nvidia_isaac//packages/perception/libperception_module.so: undefined symbol: IsaacGatherComponentInfo
2020-06-02 09:28:03.434 PANIC engine/alice/backend/modules.cpp@253: Could not load all required modules for application
| Isaac application terminated unexpectedly |
#01 /home/huangwei/.cache/bazel/_bazel_huangwei/2896d33b7554825b9a7cf05d55b4838b/execroot/com_nvidia_isaac/bazel-out/k8-opt/bin/packages/cart_delivery/apps/cart_delivery.runfiles/com_nvidia_isaac/engine/pyalice/bindings.so(+0x1a7c3a) [0x7f1f5bd4cc3a]
#02 google_breakpad::ExceptionHandler::GenerateDump(google_breakpad::ExceptionHandler::CrashContext*) /home/huangwei/.cache/bazel/_bazel_huangwei/2896d33b7554825b9a7cf05d55b4838b/execroot/com_nvidia_isaac/bazel-out/k8-opt/bin/packages/cart_delivery/apps/cart_delivery.runfiles/com_nvidia_isaac/engine/pyalice/bindings.so(_ZN15google_breakpad16ExceptionHandler12GenerateDumpEPNS0_12CrashContextE+0x3f0) [0x7f1f5be72090]
#03 google_breakpad::ExceptionHandler::SignalHandler(int, siginfo_t*, void*) /home/huangwei/.cache/bazel/_bazel_huangwei/2896d33b7554825b9a7cf05d55b4838b/execroot/com_nvidia_isaac/bazel-out/k8-opt/bin/packages/cart_delivery/apps/cart_delivery.runfiles/com_nvidia_isaac/engine/pyalice/bindings.so(_ZN15google_breakpad16ExceptionHandler13SignalHandlerEiP9siginfo_tPv+0xc0) [0x7f1f5be72400]
#04 /lib/x86_64-linux-gnu/libc.so.6(+0x3ef20) [0x7f1f80066f20]
#05 /lib/x86_64-linux-gnu/libc.so.6(gsignal+0xc7) [0x7f1f80066e97]
#06 /lib/x86_64-linux-gnu/libc.so.6(abort+0x141) [0x7f1f80068801]
#07 isaac::alice::ModuleManager::loadModules(std::vector<std::__cxx11::basic_string<char, std::char_traits, std::allocator >, std::allocator<std::__cxx11::basic_string<char, std::char_traits, std::allocator > > > const&) /home/huangwei/.cache/bazel/_bazel_huangwei/2896d33b7554825b9a7cf05d55b4838b/execroot/com_nvidia_isaac/bazel-out/k8-opt/bin/packages/cart_delivery/apps/cart_delivery.runfiles/com_nvidia_isaac/engine/pyalice/bindings.so(_ZN5isaac5alice13ModuleManager11loadModulesERKSt6vectorINSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEEESaIS8_EE+0x7de) [0x7f1f5bd5983e]
#08 isaac::alice::Application::createMore(isaac::alice::ApplicationJsonLoader const&) /home/huangwei/.cache/bazel/_bazel_huangwei/2896d33b7554825b9a7cf05d55b4838b/execroot/com_nvidia_isaac/bazel-out/k8-opt/bin/packages/cart_delivery/apps/cart_delivery.runfiles/com_nvidia_isaac/engine/pyalice/bindings.so(_ZN5isaac5alice11Application10createMoreERKNS0_21ApplicationJsonLoaderE+0x65) [0x7f1f5bd0f225]
#09 isaac::alice::Application::createApplication(isaac::alice::ApplicationJsonLoader const&) /home/huangwei/.cache/bazel/_bazel_huangwei/2896d33b7554825b9a7cf05d55b4838b/execroot/com_nvidia_isaac/bazel-out/k8-opt/bin/packages/cart_delivery/apps/cart_delivery.runfiles/com_nvidia_isaac/engine/pyalice/bindings.so(_ZN5isaac5alice11Application17createApplicationERKNS0_21ApplicationJsonLoaderE+0x2d2) [0x7f1f5bd11ab2]
#10 isaac::alice::Application::Application(isaac::alice::ApplicationJsonLoader const&) /home/huangwei/.cache/bazel/_bazel_huangwei/2896d33b7554825b9a7cf05d55b4838b/execroot/com_nvidia_isaac/bazel-out/k8-opt/bin/packages/cart_delivery/apps/cart_delivery.runfiles/com_nvidia_isaac/engine/pyalice/bindings.so(_ZN5isaac5alice11ApplicationC1ERKNS0_21ApplicationJsonLoaderE+0x10d) [0x7f1f5bd11e1d]
#11 isaac::alice::PybindApplication::PybindApplication(std::__cxx11::basic_string<char, std::char_traits, std::allocator > const&, std::__cxx11::basic_string<char, std::char_traits, std::allocator > const&, std::__cxx11::basic_string<char, std::char_traits, std::allocator > const&) /home/huangwei/.cache/bazel/_bazel_huangwei/2896d33b7554825b9a7cf05d55b4838b/execroot/com_nvidia_isaac/bazel-out/k8-opt/bin/packages/cart_delivery/apps/cart_delivery.runfiles/com_nvidia_isaac/engine/pyalice/bindings.so(ZN5isaac5alice17PybindApplicationC1ERKNSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEEES9_S9+0x1ca) [0x7f1f5bce695a]
#12 /home/huangwei/.cache/bazel/_bazel_huangwei/2896d33b7554825b9a7cf05d55b4838b/execroot/com_nvidia_isaac/bazel-out/k8-opt/bin/packages/cart_delivery/apps/cart_delivery.runfiles/com_nvidia_isaac/engine/pyalice/bindings.so(+0x141db6) [0x7f1f5bce6db6]
#13 /home/huangwei/.cache/bazel/_bazel_huangwei/2896d33b7554825b9a7cf05d55b4838b/execroot/com_nvidia_isaac/bazel-out/k8-opt/bin/packages/cart_delivery/apps/cart_delivery.runfiles/com_nvidia_isaac/engine/pyalice/bindings.so(+0x130e04) [0x7f1f5bcd5e04]
#14 /usr/bin/python3(_PyCFunction_FastCallDict+0x35c) [0x5669ac]
#15 /usr/bin/python3() [0x5949a1]
#16 /usr/bin/python3() [0x54a005]
#17 /usr/bin/python3() [0x5513d1]
#18 /usr/bin/python3(_PyObject_FastCallKeywords+0x19c) [0x5a9cbc]
#19 /usr/bin/python3() [0x50a5c3]
#20 /usr/bin/python3(_PyEval_EvalFrameDefault+0x444) [0x50bfb4]
#21 /usr/bin/python3() [0x507d64]
#22 /usr/bin/python3(_PyFunction_FastCallDict+0x2e2) [0x509042]
#23 /usr/bin/python3() [0x594931]
#24 /usr/bin/python3() [0x549e5f]
#25 /usr/bin/python3() [0x5513d1]
#26 /usr/bin/python3(_PyObject_FastCallKeywords+0x19c) [0x5a9cbc]
#27 /usr/bin/python3() [0x50a5c3]
#28 /usr/bin/python3(_PyEval_EvalFrameDefault+0x1226) [0x50cd96]
#29 /usr/bin/python3() [0x507d64]
#30 /usr/bin/python3(PyEval_EvalCode+0x23) [0x50ae13]
#31 /usr/bin/python3() [0x634c82]
#32 /usr/bin/python3(PyRun_FileExFlags+0x97) [0x634d37]
#33 /usr/bin/python3(PyRun_SimpleFileExFlags+0x17f) [0x6384ef]
#34 /usr/bin/python3(Py_Main+0x591) [0x639091]
#35 /usr/bin/python3(main+0xe0) [0x4b0d00]
#36 /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xe7) [0x7f1f80049b97]
#37 /usr/bin/python3(_start+0x2a) [0x5b250a]
Minidump written to: /tmp/9d7a66b7-a492-4da0-d71eeba6-05a42d49.dmp
