Hi again, I now can view the first image of my camera on isaac sight viewer but only the first, any idea why ?
Here is my code :
"name": "odov1",
"modules": [
"deepstream",
"sight",
"viewers"
"graph": {
"nodes": [
"name": "camera",
"components": [
"name": "message_ledger",
"type": "isaac::alice::MessageLedger"
"name": "pipeline",
"type": "isaac::deepstream::Pipeline"
"name": "viewer",
"type": "isaac::viewers::ColorCameraViewer"
"name": "viewer_widget",
"type": "isaac::sight::SightWidget"
"edges": [
"source": "camera/pipeline/image",
"target": "camera/viewer/color_listener"
"config": {
"camera": {
"pipeline": {
"pipeline": "v4l2src device=/dev/video0 ! avdec_mjpeg ! videoconvert ! video/x-raw,format=RGB,height=240,framerate=60/1 ! appsink name=image"
"viewer_widget": {
"title": "Viewer: Rolling Stereo",
"type": "2d",
"channels": [
"name": "camera/viewer/Color"
And here is terminal log :
thoth@thoth-BIG:~/Desktop/isaac$ bazel run apps/myodo/odov1
WARNING: /home/thoth/Desktop/isaac/packages/viewers/BUILD:14:12: in srcs attribute of cc_binary rule //packages/viewers:libviewers_module.so: please do not import '//packages_x86_64/viewers:libviewers_module.so' directly. You should either move the file to this package or depend on an appropriate rule there
INFO: Analysed target //apps/myodo:odov1 (0 packages loaded, 0 targets configured).
INFO: Found 1 target...
Target //apps/myodo:odov1 up-to-date:
bazel-genfiles/apps/myodo/run_odov1
bazel-bin/apps/myodo/odov1
INFO: Elapsed time: 0.152s, Critical Path: 0.00s, Remote (0.00% of the time): [queue: 0.00%, setup: 0.00%, process: 0.00%]
INFO: 0 processes.
INFO: Build completed successfully, 1 total action
2020-05-06 13:16:04.126 INFO engine/alice/tools/websight.cpp@166: Loading websight...
2020-05-06 13:16:04.127 WARN engine/alice/backend/application_json_loader.cpp@171: This application does not have an explicit scheduler configuration. One will be autogenerated to the best of the system's abilities if possible.
2020-05-06 13:16:04.127 WARN engine/alice/backend/backend.cpp@183: This application does not have an execution group configuration. One will be autogenerated to the best of the systems abilities if possible.
2020-05-06 13:16:04.127 WARN engine/gems/scheduler/scheduler.cpp@337: No default execution groups specified. Attempting to create scheduler configuration for 4 remaining cores. This may be non optimal for the system and application.
2020-05-06 13:16:04.127 INFO engine/gems/scheduler/scheduler.cpp@290: Scheduler execution groups are:
2020-05-06 13:16:04.127 INFO engine/gems/scheduler/scheduler.cpp@299: __BlockerGroup__: Cores = [3], Workers = No
2020-05-06 13:16:04.127 INFO engine/gems/scheduler/scheduler.cpp@299: __WorkerGroup__: Cores = [0, 1, 2], Workers = Yes
2020-05-06 13:16:04.133 INFO engine/alice/backend/modules.cpp@226: Loaded module 'packages/deepstream/libdeepstream_module.so': Now has 47 components total
2020-05-06 13:16:04.139 INFO engine/alice/backend/modules.cpp@226: Loaded module 'packages/sight/libsight_module.so': Now has 49 components total
2020-05-06 13:16:04.147 INFO engine/alice/backend/modules.cpp@226: Loaded module 'packages/viewers/libviewers_module.so': Now has 78 components total
2020-05-06 13:16:04.147 INFO engine/alice/application.cpp@282: Loaded 78 components: isaac::alice::Behavior, isaac::alice::ChannelMonitor, isaac::alice::Config, isaac::alice::ConfigBridge, isaac::alice::Failsafe, isaac::alice::FailsafeHeartbeat, isaac::alice::InteractiveMarkersBridge, isaac::alice::JsonToProto, isaac::alice::MessageLedger, isaac::alice::NodeStatistics, isaac::alice::Pose, isaac::alice::Pose2Comparer, isaac::alice::PoseInitializer, isaac::alice::PoseMessageInjector, isaac::alice::PoseToMessage, isaac::alice::PoseTree, isaac::alice::PoseTreeJsonBridge, isaac::alice::ProtoToJson, isaac::alice::PyCodelet, isaac::alice::Random, isaac::alice::Recorder, isaac::alice::RecorderBridge, isaac::alice::Replay, isaac::alice::ReplayBridge, isaac::alice::Scheduling, isaac::alice::Sight, isaac::alice::SightChannelStatus, isaac::alice::Subgraph, isaac::alice::Subprocess, isaac::alice::TcpPublisher, isaac::alice::TcpSubscriber, isaac::alice::Throttle, isaac::alice::TimeOffset, isaac::alice::TimeSynchronizer, isaac::alice::UdpPublisher, isaac::alice::UdpSubscriber, isaac::alice::behaviors::Behavior, isaac::alice::behaviors::MemorySelectorBehavior, isaac::alice::behaviors::MemorySequenceBehavior, isaac::alice::behaviors::NodeGroup, isaac::alice::behaviors::ParallelBehavior, isaac::alice::behaviors::SwitchBehavior, isaac::alice::behaviors::TimerBehavior, isaac::deepstream::Pipeline, isaac::map::Map, isaac::map::ObstacleAtlas, isaac::map::OccupancyGridMapLayer, isaac::map::PolygonMapLayer, isaac::map::WaypointMapLayer, isaac::ml::SampleAccumulator, isaac::navigation::DistanceMap, isaac::navigation::GroupSelectorBehavior, isaac::navigation::NavigationMap, isaac::navigation::RangeScanModelClassic, isaac::navigation::RangeScanModelFlatloc, isaac::navigation::SelectorBehavior, isaac::planner::DifferentialBaseModel, isaac::sight::AliceSight, isaac::sight::SightWidget, isaac::sight::WebsightServer, isaac::viewers::BinaryMapViewer, isaac::viewers::ColorCameraViewer, isaac::viewers::DepthCameraViewer, isaac::viewers::Detections3Viewer, isaac::viewers::DetectionsViewer, isaac::viewers::FiducialsViewer, isaac::viewers::FlatscanViewer, isaac::viewers::GoalViewer, isaac::viewers::LidarViewer, isaac::viewers::MosaicViewer, isaac::viewers::OccupancyMapViewer, isaac::viewers::PointCloudViewer, isaac::viewers::SampleAccumulatorViewer, isaac::viewers::SegmentationCameraViewer, isaac::viewers::SegmentationViewer, isaac::viewers::SkeletonViewer, isaac::viewers::TensorListViewer, isaac::viewers::TrajectoryListViewer,
2020-05-06 13:16:04.147 DEBUG engine/alice/backend/node_backend.cpp@58: Creating node 'websight'
2020-05-06 13:16:04.148 DEBUG engine/alice/backend/node_backend.cpp@58: Creating node '_config_bridge'
2020-05-06 13:16:04.148 DEBUG engine/alice/backend/node_backend.cpp@58: Creating node '_statistics'
2020-05-06 13:16:04.148 DEBUG engine/alice/backend/node_backend.cpp@58: Creating node '_pose_tree_bridge'
2020-05-06 13:16:04.148 DEBUG engine/alice/backend/node_backend.cpp@58: Creating node '_interactive_markers_bridge'
2020-05-06 13:16:04.148 DEBUG engine/alice/backend/node_backend.cpp@58: Creating node 'camera'
2020-05-06 13:16:04.148 WARN engine/alice/application.cpp@160: The function Application::findComponentByName is deprecated. Please use `getNodeComponentOrNull` instead. Note that the new method requires a node name instead of a component name. (argument: 'websight/isaac.sight.AliceSight')
2020-05-06 13:16:04.148 INFO engine/alice/application.cpp@209: Starting application 'odov1' (instance UUID: 'f96ede9e-8f8a-11ea-8500-856d41cfd367') ...
2020-05-06 13:16:04.148 DEBUG engine/gems/scheduler/execution_groups.cpp@489: Launching 0 pre-start job(s)
2020-05-06 13:16:04.148 DEBUG engine/gems/scheduler/execution_groups.cpp@498: Replaying 0 pre-start event(s)
2020-05-06 13:16:04.148 INFO engine/alice/backend/asio_backend.cpp@33: Starting ASIO service
2020-05-06 13:16:04.148 DEBUG engine/alice/backend/node_backend.cpp@58: Creating node 'backend'
2020-05-06 13:16:04.148 DEBUG engine/alice/backend/node_backend.cpp@325: Starting node 'websight'
2020-05-06 13:16:04.148 DEBUG engine/alice/backend/codelet_backend.cpp@61: Starting codelet 'websight/WebsightServer' ...
2020-05-06 13:16:04.149 INFO packages/sight/WebsightServer.cpp@200: Sight webserver is loaded
2020-05-06 13:16:04.149 INFO packages/sight/WebsightServer.cpp@201: Please open Chrome Browser and navigate to http://<ip address>:3000
2020-05-06 13:16:04.149 DEBUG engine/alice/backend/codelet_backend.cpp@72: Starting codelet 'websight/WebsightServer' DONE
2020-05-06 13:16:04.149 DEBUG engine/alice/backend/codelet_backend.cpp@287: Starting job for codelet 'websight/WebsightServer'
2020-05-06 13:16:04.149 DEBUG engine/alice/backend/codelet_backend.cpp@61: Starting codelet 'websight/isaac.sight.AliceSight' ...
2020-05-06 13:16:04.149 DEBUG engine/alice/backend/codelet_backend.cpp@72: Starting codelet 'websight/isaac.sight.AliceSight' DONE
2020-05-06 13:16:04.149 WARN engine/alice/backend/codelet_backend.cpp@277: Codelet 'websight/isaac.sight.AliceSight' was not added to scheduler because no tick method is specified.
2020-05-06 13:16:04.149 DEBUG engine/alice/backend/node_backend.cpp@325: Starting node '_config_bridge'
2020-05-06 13:16:04.149 DEBUG engine/alice/backend/codelet_backend.cpp@61: Starting codelet '_config_bridge/isaac.alice.ConfigBridge' ...
2020-05-06 13:16:04.149 DEBUG engine/alice/backend/codelet_backend.cpp@72: Starting codelet '_config_bridge/isaac.alice.ConfigBridge' DONE
2020-05-06 13:16:04.149 DEBUG engine/alice/backend/codelet_backend.cpp@287: Starting job for codelet '_config_bridge/isaac.alice.ConfigBridge'
2020-05-06 13:16:04.149 DEBUG engine/alice/backend/node_backend.cpp@325: Starting node '_statistics'
2020-05-06 13:16:04.149 DEBUG engine/alice/backend/codelet_backend.cpp@61: Starting codelet '_statistics/NodeStatistics' ...
2020-05-06 13:16:04.149 DEBUG engine/alice/backend/codelet_backend.cpp@72: Starting codelet '_statistics/NodeStatistics' DONE
2020-05-06 13:16:04.149 DEBUG engine/alice/backend/codelet_backend.cpp@287: Starting job for codelet '_statistics/NodeStatistics'
2020-05-06 13:16:04.149 DEBUG engine/alice/backend/node_backend.cpp@325: Starting node '_pose_tree_bridge'
2020-05-06 13:16:04.149 DEBUG engine/alice/backend/codelet_backend.cpp@61: Starting codelet '_pose_tree_bridge/PoseTreeJsonBridge' ...
2020-05-06 13:16:04.149 DEBUG engine/alice/backend/codelet_backend.cpp@72: Starting codelet '_pose_tree_bridge/PoseTreeJsonBridge' DONE
2020-05-06 13:16:04.149 DEBUG engine/alice/backend/codelet_backend.cpp@287: Starting job for codelet '_pose_tree_bridge/PoseTreeJsonBridge'
2020-05-06 13:16:04.149 DEBUG engine/alice/backend/node_backend.cpp@325: Starting node '_interactive_markers_bridge'
2020-05-06 13:16:04.149 DEBUG engine/alice/backend/codelet_backend.cpp@61: Starting codelet '_interactive_markers_bridge/InteractiveMarkersBridge' ...
2020-05-06 13:16:04.149 DEBUG engine/alice/backend/codelet_backend.cpp@72: Starting codelet '_interactive_markers_bridge/InteractiveMarkersBridge' DONE
2020-05-06 13:16:04.149 DEBUG engine/alice/backend/codelet_backend.cpp@287: Starting job for codelet '_interactive_markers_bridge/InteractiveMarkersBridge'
2020-05-06 13:16:04.149 DEBUG engine/alice/backend/node_backend.cpp@325: Starting node 'camera'
2020-05-06 13:16:04.149 DEBUG engine/alice/backend/codelet_backend.cpp@61: Starting codelet 'camera/pipeline' ...
2020-05-06 13:16:04.215 DEBUG engine/alice/backend/codelet_backend.cpp@72: Starting codelet 'camera/pipeline' DONE
2020-05-06 13:16:04.215 WARN engine/alice/backend/codelet_backend.cpp@277: Codelet 'camera/pipeline' was not added to scheduler because no tick method is specified.
2020-05-06 13:16:04.215 DEBUG engine/alice/backend/codelet_backend.cpp@61: Starting codelet 'camera/viewer' ...
2020-05-06 13:16:04.215 DEBUG engine/alice/backend/codelet_backend.cpp@72: Starting codelet 'camera/viewer' DONE
2020-05-06 13:16:04.215 DEBUG engine/alice/backend/codelet_backend.cpp@287: Starting job for codelet 'camera/viewer'
2020-05-06 13:16:04.215 DEBUG engine/alice/backend/node_backend.cpp@325: Starting node 'backend'
2020-05-06 13:16:04.215 DEBUG engine/alice/backend/event_manager.cpp@37: Stopping node 'backend' because it reached status 'SUCCESS'
2020-05-06 13:16:04.215 DEBUG engine/alice/backend/node_backend.cpp@350: Stopping node 'backend'
2020-05-06 13:16:08.356 INFO packages/sight/WebsightServer.cpp@107: Server connected / 1
2020-05-06 13:16:14.148 INFO engine/alice/backend/allocator_backend.cpp@56: Optimized memory CPU allocator.
2020-05-06 13:16:14.148 INFO engine/alice/backend/allocator_backend.cpp@65: Optimized memory CUDA allocator.
^C2020-05-06 13:16:24.476 INFO engine/alice/application.cpp@221: Stopping application 'odov1' (instance UUID: 'f96ede9e-8f8a-11ea-8500-856d41cfd367') ...
2020-05-06 13:16:24.476 INFO engine/alice/backend/backend.cpp@129: Backend is shutting down...
2020-05-06 13:16:24.476 DEBUG engine/alice/backend/node_backend.cpp@350: Stopping node 'camera'
2020-05-06 13:16:24.476 DEBUG engine/alice/backend/codelet_backend.cpp@95: Stopping codelet 'camera/viewer' ...
2020-05-06 13:16:24.476 DEBUG engine/alice/backend/codelet_backend.cpp@104: Stopping codelet 'camera/viewer' DONE
2020-05-06 13:16:24.476 DEBUG engine/alice/backend/codelet_backend.cpp@95: Stopping codelet 'camera/pipeline' ...
2020-05-06 13:16:24.493 DEBUG engine/alice/backend/codelet_backend.cpp@104: Stopping codelet 'camera/pipeline' DONE
2020-05-06 13:16:24.493 DEBUG engine/alice/backend/node_backend.cpp@350: Stopping node '_interactive_markers_bridge'
2020-05-06 13:16:24.493 DEBUG engine/alice/backend/codelet_backend.cpp@95: Stopping codelet '_interactive_markers_bridge/InteractiveMarkersBridge' ...
2020-05-06 13:16:24.493 DEBUG engine/alice/backend/codelet_backend.cpp@104: Stopping codelet '_interactive_markers_bridge/InteractiveMarkersBridge' DONE
2020-05-06 13:16:24.493 DEBUG engine/alice/backend/node_backend.cpp@350: Stopping node '_pose_tree_bridge'
2020-05-06 13:16:24.493 DEBUG engine/alice/backend/codelet_backend.cpp@95: Stopping codelet '_pose_tree_bridge/PoseTreeJsonBridge' ...
2020-05-06 13:16:24.493 DEBUG engine/alice/backend/codelet_backend.cpp@104: Stopping codelet '_pose_tree_bridge/PoseTreeJsonBridge' DONE
2020-05-06 13:16:24.493 DEBUG engine/alice/backend/node_backend.cpp@350: Stopping node '_statistics'
2020-05-06 13:16:24.493 DEBUG engine/alice/backend/codelet_backend.cpp@95: Stopping codelet '_statistics/NodeStatistics' ...
2020-05-06 13:16:24.493 DEBUG engine/alice/backend/codelet_backend.cpp@104: Stopping codelet '_statistics/NodeStatistics' DONE
2020-05-06 13:16:24.493 DEBUG engine/alice/backend/node_backend.cpp@350: Stopping node '_config_bridge'
2020-05-06 13:16:24.493 DEBUG engine/alice/backend/codelet_backend.cpp@95: Stopping codelet '_config_bridge/isaac.alice.ConfigBridge' ...
2020-05-06 13:16:24.493 DEBUG engine/alice/backend/codelet_backend.cpp@104: Stopping codelet '_config_bridge/isaac.alice.ConfigBridge' DONE
2020-05-06 13:16:24.493 DEBUG engine/alice/backend/node_backend.cpp@350: Stopping node 'websight'
2020-05-06 13:16:24.493 DEBUG engine/alice/backend/codelet_backend.cpp@95: Stopping codelet 'websight/isaac.sight.AliceSight' ...
2020-05-06 13:16:24.493 DEBUG engine/alice/backend/codelet_backend.cpp@104: Stopping codelet 'websight/isaac.sight.AliceSight' DONE
2020-05-06 13:16:24.503 DEBUG engine/alice/backend/codelet_backend.cpp@95: Stopping codelet 'websight/WebsightServer' ...
2020-05-06 13:16:24.503 INFO packages/sight/WebsightServer.cpp@118: Disconnected
2020-05-06 13:16:24.503 INFO packages/sight/WebsightServer.cpp@406: =====================================================================================
2020-05-06 13:16:24.503 INFO packages/sight/WebsightServer.cpp@407: | Websight Statistics Report |
2020-05-06 13:16:24.503 INFO packages/sight/WebsightServer.cpp@408: =====================================================================================
2020-05-06 13:16:24.503 INFO packages/sight/WebsightServer.cpp@409: | Name | Bandwidth | Total | Count |
2020-05-06 13:16:24.503 INFO packages/sight/WebsightServer.cpp@410: -------------------------------------------------------------------------------------
2020-05-06 13:16:24.503 INFO packages/sight/WebsightServer.cpp@429: =====================================================================================
2020-05-06 13:16:24.503 DEBUG engine/alice/backend/codelet_backend.cpp@104: Stopping codelet 'websight/WebsightServer' DONE
2020-05-06 13:16:24.506 INFO engine/alice/backend/asio_backend.cpp@49: Stopping ASIO service
2020-05-06 13:16:24.517 DEBUG engine/gems/scheduler/execution_groups.cpp@518: Stopping all threads for execution group __BlockerGroup__...
2020-05-06 13:16:24.517 DEBUG engine/gems/scheduler/execution_groups.cpp@522: Stopping all threads DONE
2020-05-06 13:16:24.517 INFO engine/gems/scheduler/execution_groups.cpp@594:
| Job Statistics Report (blocking) |
| Name | Job Mode | Count | Time (Median - 90% - Max) [ms] |
| DeepStream Service | Blocking One Shot | 1 | 20268.24 | 20268.24 | 20268.24 |
| websight/WebsightServer | Blocking | 4002 | 5.07 | 5.09 | 14.97 |
| ASIO Service | Blocking | 1 | 20345.47 | 20345.47 | 20345.47 |
| NodeBackend start/stop queue | Blocking One Shot | 1 | 20355.06 | 20355.06 | 20355.06 |
2020-05-06 13:16:24.517 DEBUG engine/gems/scheduler/execution_groups.cpp@518: Stopping all threads for execution group __WorkerGroup__...
2020-05-06 13:16:24.517 INFO engine/gems/scheduler/execution_groups.cpp@656:
| Job Statistics Report (regular) |
| Name | Job Mode | Count | Time (Median - 90% - Max) [ms] | Rl Load | Overrun | Overrun | Exec Delay |
| camera/viewer | Event | 1108 | 0.01 | 0.01 | 1.64 | 42.8 % | 0.0 % | 0.00 ms | 37.2 mus |
| _pose_tree_bridge/PoseTreeJsonBridge | Periodic | 408 | 0.02 | 0.03 | 0.08 | 33.1 % | 0.0 % | 0.00 ms | -44.2 mus |
| ..eractive_markers_bridge/InteractiveMarkersBridge | Periodic | 408 | 0.01 | 0.02 | 0.04 | 11.5 % | 0.0 % | 0.00 ms | -90.4 mus |
| _statistics/NodeStatistics | Periodic | 21 | 0.09 | 0.13 | 0.18 | 6.3 % | 0.0 % | 0.00 ms | -37.8 mus |
| FailsafeHeartBeat | Periodic | 2037 | 0.00 | 0.00 | 0.05 | 5.8 % | 0.0 % | 0.00 ms | -35.4 mus |
| AllocatorBackend | One Shot | 1 | 0.08 | 0.08 | 0.08 | 0.2 % | 0.0 % | 0.00 ms | -36.6 mus |
| _config_bridge/isaac.alice.ConfigBridge | Event | 1 | 0.08 | 0.08 | 0.08 | 0.2 % | 0.0 % | 0.00 ms | 27.7 mus |
2020-05-06 13:16:24.517 INFO engine/alice/backend/allocator_backend.cpp@120:
| Big Data Memory Allocation Statistics |
| CPU |
| Duration | 20.4 s |
| Rate | 54.4 1/s |
| Count (Total) | 1109 |
| Request Rate | 23.9 MB/s |
| Requested (Total) | 487 MB |
| Allocated (Total) | 231 MB |
| Deallocated (Total) | 227 MB |
| Potentially Lost | 4608000 B |
| Efficiency | 52.5 % |
| CUDA |
| Duration | 20.4 s |
| Rate | 0.0 1/s |
| Count (Total) | 0 |
| Request Rate | 0.0 MB/s |
| Requested (Total) | 0 MB |
| Allocated (Total) | 0 MB |
| Deallocated (Total) | 0 MB |
| Potentially Lost | 0 B |
| Efficiency | 100.0 % |
2020-05-06 13:16:24.517 INFO engine/alice/backend/backend.cpp@142: Backend is shutting down... DONE
Thank you very much
