ISAAC argus camera intrinsics
I use Leopard Imaging Owl GMSL cameras on Jetson Orin (Jetpack 5.1.2) with isaac_ros_argus_camera. The isaac_ros_argus_camera driver publishes ROS2 sensor_msgs/Image messages, but corresponding sensor_msgs/CameraInfo topics are filled with zeros.
Is it possible to get intrinsic camera calibration?
I’ve tried to run argus_syncstereo script from jetson_multimedia_api but have the following errors:
Executing Argus Sample: argus_syncstereo
Argus Version: 0.99.3.3 (multi-process)
getSensorPlacement for sensor 0 is SENSOR_PLACEMENT_REAR_OR_BOTTOM
Found : OWL1
getSensorPlacement for sensor 1 is SENSOR_PLACEMENT_BOTTOM_RIGHT
Found : OWL2
getSensorPlacement for sensor 2 is SENSOR_PLACEMENT_FRONT_OR_TOP_O
Found : OWL3
getSensorPlacement for sensor 3 is SENSOR_PLACEMENT_CENTER_OR_CENT
Found : OWL4
getSensorPlacement for sensor 4 is SENSOR_PLACEMENT_REAR_OR_BOTTOM
Found : OWL5
getSensorPlacement for sensor 5 is SENSOR_PLACEMENT_BOTTOM_RIGHT
Found : OWL6
getSensorPlacement for sensor 6 is SENSOR_PLACEMENT_FRONT_OR_TOP_O
Found : OWL7
getSensorPlacement for sensor 7 is SENSOR_PLACEMENT_CENTER_OR_CENT
Found : OWL8
Total Module Count is 8
Identified stereo camera module OWL1 with the following 1 sensors connected:
0
Identified stereo camera module OWL2 with the following 1 sensors connected:
1
Identified stereo camera module OWL3 with the following 1 sensors connected:
2
Identified stereo camera module OWL4 with the following 1 sensors connected:
3
Identified stereo camera module OWL5 with the following 1 sensors connected:
4
Identified stereo camera module OWL6 with the following 1 sensors connected:
5
Identified stereo camera module OWL7 with the following 1 sensors connected:
6
Identified stereo camera module OWL8 with the following 1 sensors connected:
7
Session[0] : add camera device 0
Error generated. /usr/src/jetson_multimedia_api/argus/samples/syncStereo/main.cpp, execute:593 Failed to get capture session interface
Error generated. /usr/src/jetson_multimedia_api/argus/samples/utils/EGLGlobal.cpp, cleanup:150 eglTerminate failed (error 0x3008)
I’ve also tried to skip capturing sessions for cameras with IDs from 0 to 3 (I have 4 cameras, not 8) by rebuilding of syncstereo app, but without any result.
My setup:
  • Jetson AGX Orin 64GB (Jetpack 5.1.2)
  • LI-JAG-ADP-GMSL2-8CH (P3762_A03 version)
  • 4 x LI OWL cameras
Hi @pavel.butov
The engineering team at NVIDIA is currently working on your issue and will provide an update as soon as possible.
Thank you in advance,
Raffaello
Hi Pavel,
Thank you for your patience.
Looking at your log, the isaac_ros_argus_camera properly loads the intrinsic parameters on the EEPROM camera from the Leopard Imaging Owl GMSL cameras, but the intrinsic reads are all 0.
The isaac_ros_argus_camera exported from EEPROM are loaded on the sensor_msgs/CameraInfo message
I suggest contacting the camera vendor to get the required drivers or update the camera firmware.
