I’m trying to build isaac sdk sample (stereo_dummy) with bazel and this is the error I get:
$TEST_TMPDIR defined: output root default is ‘/mnt/nvme/.cache/bazel’ and max_idle_secs default is ‘15’.
Extracting Bazel installation…
Starting local Bazel server and connecting to it…
WARNING: ignoring LD_PRELOAD in environment.
WARNING: Download from https://mirror.bazel.build/github.com/grpc/grpc/archive/v1.19.1.tar.gz failed: class com.google.devtools.build.lib.bazel.repository.downloader.UnrecoverableHttpException GET returned 404 Not Found
ERROR: /mnt/nvme/isaac-sdk-20210609-e336b5195/sdk/packages/viewers/BUILD:10:1: Illegal ambiguous match on configurable attribute “data” in //packages/viewers:libviewers_module.so:
@com_nvidia_isaac_engine//engine/build:platform_x86_64
@com_nvidia_isaac_engine//engine/build:cpu_aarch64
Multiple matches are not allowed unless one is unambiguously more specialized.
INFO: SHA256 (https://developer.nvidia.com/isaac/download/third_party/isaac_assets-zip) = 032d56b65d17acf360cab1145e57cdeb0a0d2e25814624a90d44766e624e40f1
DEBUG: Rule ‘isaac_assets’ indicated that a canonical reproducible form can be obtained by modifying arguments sha256 = “032d56b65d17acf360cab1145e57cdeb0a0d2e25814624a90d44766e624e40f1”
DEBUG: Repository isaac_assets instantiated at:
no stack (–record_rule_instantiation_callstack not enabled)
Repository rule http_archive defined at:
/mnt/nvme/.cache/bazel/_bazel_dev/2126d18d64efd26d737eeb94a805fb1d/external/bazel_tools/tools/build_defs/repo/http.bzl:336:16: in
DEBUG: Rule ‘org_tuxfamily_eigen’ indicated that a canonical reproducible form can be obtained by modifying arguments shallow_since = “1544551075 +0100”
DEBUG: Repository org_tuxfamily_eigen instantiated at:
Repository rule new_git_repository defined at:
/mnt/nvme/.cache/bazel/_bazel_dev/2126d18d64efd26d737eeb94a805fb1d/external/bazel_tools/tools/build_defs/repo/git.bzl:182:22: in
WARNING: errors encountered while analyzing target ‘//apps/samples/stereo_dummy:stereo_dummy’: it will not be built
INFO: Analyzed target //apps/samples/stereo_dummy:stereo_dummy (80 packages loaded, 4986 targets configured).
INFO: Found 0 targets…
ERROR: command succeeded, but not all targets were analyzed
INFO: Elapsed time: 334.277s, Critical Path: 0.04s
INFO: 0 processes.
FAILED: Build did NOT complete successfully
I’m using jetson AGX with jetpack4.6, ubuntu18
How can I solve this issue please?
Thanks in advance
