I am trying to build a custom RL task in Isaac Gym using a Kuka IIWA with an attached onrobot RG2 gripper at the ee_link. The iiwa works properly in joint position control using the following values :
robot_props["driveMode"][:7].fill(gymapi.DOF_MODE_POS)
robot_props["stiffness"][:7].fill(1100.)
robot_props["damping"][:7].fill(125.)
but the gripper is vibrating with these gains:
robot_props["driveMode"][7:].fill(gymapi.DOF_MODE_POS)
robot_props["stiffness"][7:].fill(1500.)
robot_props["damping"][7:].fill(250.)
Is there any proper way to tune the joints of the gripper to make them stable? Here is the video. What can I check to rectify this ?
Thank you.
