6.0.0
5.1.0
5.0.0
4.5.0
4.2.0
4.1.0
4.0.0
4.5.0
2023.1.1
2023.1.0-hotfix.1
Other (please specify):
Operating System
Ubuntu 24.04
Ubuntu 22.04
Ubuntu 20.04
Windows 11
Windows 10
GPU Information
- Model: Geforce RTX 5090D
- Driver Version: 595.71.05
Topic Description
Detailed Description
i have install isaac sim, version 6.0.0-rc.59+release.41464.5f2772bc.gl, isaac sim can work normally.
then i install isaac lab, the main branch of git repo, version is 2.3.2
the procedure of isaac lab install complete without error.
but when i test using the order,
./isaaclab.sh -p scripts/tutorials/00_sim/create_empty.py
it is failed.
(Add more steps as needed)
Error Messages
ljqy@lab-ws-02:~/IsaacLab$ ./isaaclab.sh -p scripts/tutorials/00_sim/create_empty.py
[INFO] Using python from: /home/ljqy/IsaacLab/_isaac_sim/python.sh
[WARN][AppLauncher]: There are no arguments attached to the ArgumentParser object. If you have your own arguments, please load your own arguments before calling the AppLauncher.add_app_launcher_args method. This allows the method to check the validity of the arguments and perform checks for argument names.
[INFO][AppLauncher]: Using device: cuda:0
[INFO][AppLauncher]: Loading experience file: /home/ljqy/IsaacLab/apps/isaaclab.python.kit
2026-07-22T04:37:43Z [Info] [carb] Logging to file: /home/ljqy/isaacsim/kit/logs/Kit/Isaac-Sim/5.1/kit_20260722_123743.log
[0.063s] Failed to solve some dependencies locally, syncing with extension registry…
[0.064s] [ext: omni.kit.async_engine-0.0.3] startup
[0.068s] [ext: omni.client.lib-1.1.1] startup
[0.097s] [ext: omni.kit.registry.nucleus-0.0.0] startup
[25.368s] Pulling extension: isaacsim.asset.browser-1.3.23 from the registry.
[43.390s] Extension: isaacsim.asset.browser-1.3.23 was installed.
[43.390s] Pulling extension: isaacsim.asset.importer.urdf-2.4.31 from the registry.
[640.972s] Extension: isaacsim.asset.importer.urdf-2.4.31 was installed.
[640.985s] [ext: omni.assets.plugins-0.0.0] startup
[640.988s] [ext: omni.blobkey-1.1.2] startup
[640.989s] [ext: omni.client-1.3.0] startup
[640.990s] [ext: omni.protobuf.lib-1.0.0] startup
[640.995s] [ext: omni.grpc.lib-1.0.0] startup
[641.007s] [ext: omni.metrics.core-0.0.3] startup
[641.008s] [ext: omni.datastore-0.0.0] startup
WARNING: All log messages before absl::InitializeLog() is called are written to STDERR
E0000 00:00:1784695704.000476 675719 descriptor_database.cc:633] File already exists in database: grpc/health/v1/health.proto
W0000 00:00:1784695704.000900 675719 message.cc:301] Protobuf GeneratedMessageFactory: File is already registered: grpc/health/v1/health.proto
[641.011s] [ext: omni.gpu_foundation.shadercache.vulkan-1.0.0] startup
[641.422s] [ext: omni.hsscclient-1.1.4] startup
[641.423s] [ext: omni.stats-1.0.1] startup
[641.425s] [ext: omni.ujitso.default-1.0.0] startup
[641.432s] [ext: omni.gpu_foundation-0.0.0] startup
[641.583s] [ext: carb.windowing.plugins-1.0.1] startup
[641.588s] [ext: omni.kit.renderer.init-1.0.1] startup
2026-07-22T04:48:24Z [641,904ms] [Warning] [omni.rtx] Skipping unsupported non-NVIDIA GPU: AMD Ryzen 9 9950X3D 16-Core Processor (RADV RAPHAEL_MENDOCINO)
| Driver Version: 595.71.05 | Graphics API: Vulkan
| GPU | Name | Active | LDA | GPU Memory | Vendor-ID | LUID |
| | | | | | Device-ID | UUID |
| | | | | | Bus-ID | |
| 0 | NVIDIA GeForce RTX 5090 D | Yes: 0 | | 32607 MB | 10de | 0 |
| | | | | | 2b87 | 272d38f1.. |
| | | | | | 1 | |
| 1 | AMD Ryzen 9 9950X3D 16-Core Pr.. | | | 32755 MB | 1002 | 0 |
| | | | | | 13c0 | 00000000.. |
| | | | | | 7a | |
| OS: 24.04.4 LTS (Noble Numbat) ubuntu, Version: 24.04.4, Kernel: 6.17.0-40-generic
| XServer Vendor: The X.Org Foundation, XServer Version: 12101011 (1.21.1.11)
| Processor: AMD Ryzen 9 9950X3D 16-Core Processor
| Cores: 16 | Logical Cores: 32
| Total Memory (MB): 94171 | Free Memory: 87926
| Total Page/Swap (MB): 8191 | Free Page/Swap: 8191
2026-07-22T04:48:25Z [642,094ms] [Warning] [omni.rtx] CPU performance profile is set to powersave. This profile sets the CPU to the lowest frequency reducing performance.
2026-07-22T04:48:25Z [642,102ms] [Warning] [omni.rtx] PCIe link width current (8) and maximum (16) for device 0 don’t match.
2026-07-22T04:48:25Z [642,102ms] [Warning] [omni.rtx] IOMMU is enabled.
[642.231s] [ext: omni.kit.pipapi-0.0.0] startup
[642.233s] [ext: omni.kit.pip_archive-0.0.0] startup
[642.233s] [ext: isaacsim.pip.newton-0.6.0] startup
[642.233s] [ext: omni.pip.compute-1.9.0] startup
[642.234s] [ext: omni.isaac.core_archive-5.3.0] startup
[642.234s] [ext: omni.kit.telemetry-0.5.2] startup
[642.252s] [ext: omni.kit.loop-isaac-1.6.0] startup
[642.254s] [ext: omni.kit.test-2.0.7] startup
[642.299s] [ext: omni.materialx.libs-1.0.9] startup
[642.310s] [ext: omni.gpucompute.plugins-0.0.0] startup
[642.311s] [ext: omni.usd.config-1.0.7] startup
[642.315s] [ext: omni.usd.libs-1.0.3] startup
[642.453s] [ext: omni.iray.libs-0.0.1] startup
[642.490s] [ext: omni.mdl-57.0.3] startup
[642.557s] [ext: omni.mdl.neuraylib-0.2.20] startup
[642.561s] [ext: omni.kit.usd.mdl-1.1.9] startup
[642.694s] [ext: omni.appwindow-1.2.2] startup
[642.698s] [ext: omni.kit.renderer.core-1.2.2] startup
[642.819s] [ext: omni.kit.renderer.capture-2.0.1] startup
[642.822s] [ext: omni.kit.renderer.imgui-2.0.6] startup
[642.860s] [ext: omni.ui-3.1.3] startup
[642.874s] [ext: omni.kit.mainwindow-1.0.3] startup
[642.875s] [ext: carb.audio-0.1.0] startup
[642.879s] [ext: omni.uiaudio-1.0.0] startup
[642.880s] [ext: omni.kit.uiapp-0.0.0] startup
[642.880s] [ext: omni.usd.schema.metrics.assembler-110.1.0] startup
[642.883s] [ext: isaacsim.robot.schema-6.3.6] startup
[642.887s] [ext: omni.usd.schema.anim-0.0.1] startup
[642.906s] [ext: omni.usd.schema.audio-0.0.1] startup
[642.909s] [ext: omni.usd.schema.geospatial-0.0.1] startup
[642.912s] [ext: omni.usd.schema.semantics-0.0.0] startup
[642.915s] [ext: omni.activity.core-1.0.3] startup
[642.916s] [ext: omni.cubric-0.1.0] startup
[642.917s] [ext: omni.graph.exec-0.9.6] startup
[642.918s] [ext: omni.usd_resolver-1.0.0] startup
[642.922s] [ext: omni.usd.core-1.8.3] startup
[642.928s] [ext: omni.hydra.scene_delegate-0.3.5] startup
[642.931s] [ext: usdrt.scenegraph-7.6.3] startup
[642.968s] [ext: omni.hydra.usdrt_delegate-7.5.2] startup
[642.975s] [ext: omni.kit.actions.core-1.0.0] startup
[642.978s] [ext: omni.kit.audiodeviceenum-1.0.2] startup
[642.979s] [ext: omni.kit.commands-1.5.0] startup
[642.983s] [ext: omni.kit.exec.core-0.13.5] startup
[642.985s] [ext: omni.kit.usd_undo-0.1.8] startup
[642.985s] [ext: omni.kit.window.popup_dialog-2.0.25] startup
[642.989s] [ext: omni.kit.widget.nucleus_connector-2.3.1] startup
[642.992s] [ext: omni.timeline-1.1.0] startup
[642.994s] [ext: omni.usd-1.15.2] startup
[643.030s] [ext: isaacsim.robot_motion.schema-0.2.0] startup
[643.032s] [ext: omni.kit.asset_converter-5.1.4] startup
[643.052s] [ext: omni.pip.cloud-1.5.3] startup
[643.054s] [ext: omni.usd.schema.mujoco-1.1.0] startup
[643.055s] [ext: omni.usd.schema.newton-1.2.0] startup
[643.056s] [ext: omni.usd.schema.omni_lens_distortion-1.0.0] startup
[643.057s] [ext: omni.usd.schema.omni_projectors-1.0.0] startup
[643.057s] [ext: omni.usd.schema.omni_sensors-0.0.0] startup
[643.066s] [ext: omni.usd.schema.omnigraph-1.0.1] startup
[643.072s] [ext: omni.usd.schema.omniscripting-1.0.1] startup
[643.076s] [ext: omni.usd.schema.physical_lighting-0.1.0] startup
[643.079s] [ext: omni.usd.schema.physx-110.1.11] startup
[643.115s] [ext: omni.usd.schema.render_settings.rtx-1.0.2] startup
[643.119s] [ext: omni.usd.schema.usd_particle_field-1.0.0] startup
[643.120s] [ext: omni.kit.clipboard-1.1.1] startup
[643.121s] [ext: omni.kit.menu.core-1.2.0] startup
[643.121s] [ext: omni.kit.usd.layers-2.6.1] startup
[643.129s] [ext: omni.kit.widget.context_menu-1.4.0] startup
[643.131s] [ext: omni.kit.context_menu-1.9.0] startup
[643.132s] [ext: omni.kit.helper.file_utils-0.1.10] startup
[643.133s] [ext: omni.kit.hotkeys.core-1.3.12] startup
[643.136s] [ext: omni.kit.menu.utils-2.2.3] startup
[643.139s] [ext: omni.kit.notification_manager-1.0.11] startup
[643.141s] [ext: omni.kit.stage_template.core-1.1.22] startup
[643.141s] [ext: omni.kit.widget.path_field-2.0.13] startup
[643.142s] [ext: omni.kit.widget.browser_bar-2.0.10] startup
[643.143s] [ext: omni.kit.widget.filebrowser-2.13.4] startup
[643.146s] [ext: omni.kit.widget.options_menu-1.1.6] startup
[643.148s] [ext: omni.kit.widget.filter-1.1.5] startup
[643.149s] [ext: omni.kit.widget.options_button-1.0.3] startup
[643.149s] [ext: omni.kit.widget.prompt-1.0.7] startup
[643.150s] [ext: omni.kit.widget.searchfield-1.1.8] startup
[643.151s] [ext: omni.ui.scene-2.0.1] startup
[643.157s] [ext: omni.kit.window.filepicker-2.15.5] startup
[643.168s] [ext: omni.kit.window.file_exporter-1.0.36] startup
[643.169s] [ext: omni.kit.widget.stage-4.3.0] startup
[643.177s] [ext: omni.kit.window.content_browser_registry-0.0.6] startup
[643.178s] [ext: omni.kit.window.drop_support-1.0.8] startup
[643.178s] [ext: omni.kit.window.file_importer-1.1.21] startup
[643.179s] [ext: omni.kit.window.file-2.0.10] startup
[643.181s] [ext: omni.kit.window.content_browser-3.1.8] startup
[643.189s] [ext: omni.kit.widget.layers-1.9.2] startup
[643.199s] [ext: isaaclab-0.54.4] startup
[643.612s] [ext: isaaclab_contrib-0.0.2] startup
[643.612s] [ext: omni.inspect-1.0.2] startup
[643.614s] [ext: omni.graph.core-3.1.2] startup
[643.620s] [ext: isaacsim.core.deprecation_manager-0.4.2] startup
[643.621s] [ext: isaacsim.core.version-2.1.0] startup
[643.622s] [ext: isaacsim.app.about-2.3.0] startup
[643.628s] [ext: isaacsim.storage.native-1.9.2] startup
[643.630s] [ext: omni.convexdecomposition-110.1.11] startup
[643.632s] [ext: omni.hydra.rtx.shadercache.vulkan-1.0.0] startup
[643.634s] [ext: omni.index.libs-387500.3473.0] startup
[643.634s] [ext: omni.index-1.0.1] startup
[643.635s] [ext: omni.ujitso.client-0.0.0] startup
[643.635s] [ext: omni.usd.schema.playback-1.0.0] startup
[643.638s] [ext: omni.volume-0.5.2] startup
[643.649s] [ext: omni.hydra.rtx-1.0.3] startup
2026-07-22T04:48:26Z [643,642ms] [Warning] [omni.log] Source: omni.hydra was already registered.
[643.724s] [ext: omni.debugdraw-0.1.4] startup
[643.727s] [ext: omni.hydra.engine.stats-1.0.5] startup
[643.729s] [ext: omni.kit.hydra_texture-1.6.0] startup
[643.732s] [ext: omni.kit.manipulator.selector-1.1.4] startup
[643.733s] [ext: omni.kit.widget.searchable_combobox-1.0.7] startup
[643.734s] [ext: omni.kit.widget.settings-2.0.0] startup
[643.736s] [ext: omni.kit.window.preferences-1.8.3] startup
[643.739s] [ext: omni.kit.manipulator.transform-107.0.0] startup
[643.743s] [ext: omni.kit.material.library-3.1.2] startup
[643.749s] [ext: omni.kit.raycast.query-1.2.0] startup
[643.753s] [ext: omni.kit.viewport.legacy_gizmos-1.0.24] startup
[643.755s] [ext: omni.kit.viewport.registry-104.0.6] startup
[643.755s] [ext: omni.kit.viewport.scene_camera_model-1.0.7] startup
[643.758s] [ext: omni.kit.widget.viewport-109.2.0] startup
[643.762s] [ext: omni.kit.viewport.window-109.0.2] startup
[643.778s] [ext: omni.kit.viewport.utility-2.0.1] startup
[643.778s] [ext: omni.kit.widget.toolbar-2.1.0] startup
[643.783s] [ext: omni.kit.manipulator.tool.snap-1.5.14] startup
[643.786s] [ext: omni.kit.manipulator.viewport-107.0.1] startup
[643.787s] [ext: omni.kit.viewport.manipulator.transform-107.0.4] startup
[643.788s] [ext: omni.kit.manipulator.prim.core-108.0.2] startup
[643.793s] [ext: omni.kit.manipulator.prim.usd-107.0.3] startup
[643.794s] [ext: omni.kit.manipulator.prim-108.0.0] startup
[643.794s] [ext: omni.kit.manipulator.selection-109.0.1] startup
[643.806s] [ext: omni.kit.property.adapter.core-1.1.1] startup
[643.808s] [ext: omni.kit.property.adapter.usd-1.0.5] startup
[643.809s] [ext: omni.kit.widget.highlight_label-1.0.3] startup
[643.809s] [ext: omni.kit.window.property-1.15.1] startup
[643.959s] [ext: omni.kit.property.usd-4.8.1] startup
[643.968s] [ext: omni.kit.viewport.actions-107.0.2] startup
[643.971s] [ext: omni.kit.viewport.menubar.core-107.2.2] startup
[643.982s] [ext: omni.kit.viewport.menubar.display-107.1.3] startup
[643.983s] [ext: omni.physics-110.1.11] startup
[643.988s] [ext: omni.physx.gpu-110.1.11] startup
[643.989s] [ext: omni.physx.foundation-110.1.11] startup
[643.992s] [ext: omni.usdphysics-110.1.11] startup
[643.994s] [ext: omni.physx.cooking-110.1.11] startup
[643.997s] [ext: omni.physx-110.1.11] startup
[644.011s] [ext: omni.physics.physx-110.1.11] startup
[644.012s] [ext: omni.physics.stageupdate-110.1.11] startup
[644.015s] [ext: omni.physics.tensors-110.1.11] startup
[644.019s] [ext: omni.physx.commands-110.1.11] startup
[644.022s] [ext: omni.usdphysics.ui-110.1.11] startup
[644.039s] [ext: omni.physx.ui-110.1.11] startup
[644.058s] [ext: omni.usd.metrics.assembler-110.1.2] startup
[644.061s] [ext: omni.usd.metrics.assembler.physics-110.1.11] startup
[644.062s] [ext: omni.warp.core-1.13.0] startup
[644.063s] [ext: isaacsim.core.utils-4.1.6] startup
[644.065s] [ext: omni.kit.widget.zoombar-1.0.7] startup
[644.066s] [ext: omni.kit.browser.core-2.3.18] startup
[644.069s] [ext: omni.kit.browser.folder.core-2.0.2] startup
[644.073s] [ext: omni.kit.widget.stage_icons-1.0.8] startup
[644.074s] [ext: omni.kit.window.stage-2.6.1] startup
[644.076s] [ext: omni.kit.menu.stage-1.2.7] startup
[644.077s] [ext: omni.kit.usd.collect-3.0.5] startup
[644.079s] [ext: omni.kit.tool.collect-2.2.19] startup
[644.080s] [ext: isaacsim.asset.browser-1.3.23] startup
[644.127s] [ext: isaacsim.asset.transformer-1.2.3] startup
[644.130s] [ext: omni.scene.optimizer.core-110.1.0] startup
[644.179s] [ext: isaacsim.asset.importer.utils-1.8.0] startup
[644.182s] [ext: isaacsim.asset.transformer.rules-1.7.8] startup
[644.190s] [ext: omni.usdex.libs-2.2.2] startup
[644.200s] [ext: isaacsim.asset.importer.mjcf-3.10.0] startup
[644.202s] [ext: omni.graph.tools-1.81.0] startup
[644.220s] [ext: omni.graph-1.142.5] startup
[644.252s] [ext: omni.graph.action_core-1.1.9] startup
[644.255s] [ext: omni.graph.action_nodes_core-2.10.2] startup
[644.260s] [ext: omni.graph.action_nodes-2.10.3] startup
[644.280s] [ext: omni.graph.action-2.10.2] startup
[644.282s] [ext: omni.graph.visualization.nodes-2.1.4] startup
[644.296s] [ext: omni.kit.usdz_export-1.1.0] startup
[644.298s] [ext: omni.kit.tool.asset_importer-5.2.0] startup
[644.303s] [ext: omni.kit.widget.text_editor-1.1.1] startup
[644.305s] [ext: omni.kit.window.extensions-1.5.7] startup
[644.311s] [ext: isaacsim.examples.browser-0.3.1] startup
[644.313s] [ext: isaacsim.gui.components-1.8.4] startup
[644.318s] [ext: isaacsim.asset.importer.urdf-2.4.31] startup
2026-07-22T04:48:27Z [644,272ms] [Error] [carb] [Plugin: libisaacsim.asset.importer.urdf.plugin.so] Could not load the dynamic library from /home/ljqy/.local/share/ov/data/exts/v2/isaacsim.asset.importer.urdf-2.4.31+109.0.1.lx64.r.cp312/bin/libisaacsim.asset.importer.urdf.plugin.so. Error: /home/ljqy/.local/share/ov/data/exts/v2/isaacsim.asset.importer.urdf-2.4.31+109.0.1.lx64.r.cp312/bin/libisaacsim.asset.importer.urdf.plugin.so: undefined symbol: _ZN34pxrInternal_v0_25_2__pxrReserved__16UsdPhysicsTokensE (Additional information may be available by running the process with the LD_DEBUG environment variable set)
2026-07-22T04:48:27Z [644,272ms] [Warning] [carb] Potential plugin preload failed: /home/ljqy/.local/share/ov/data/exts/v2/isaacsim.asset.importer.urdf-2.4.31+109.0.1.lx64.r.cp312/bin/libisaacsim.asset.importer.urdf.plugin.so
2026-07-22T04:48:27Z [644,272ms] [Error] [omni.ext.plugin] [ext: isaacsim.asset.importer.urdf-2.4.31] failed to load native plugin: /home/ljqy/.local/share/ov/data/exts/v2/isaacsim.asset.importer.urdf-2.4.31+109.0.1.lx64.r.cp312/bin/libisaacsim.asset.importer.urdf.plugin.so
2026-07-22T04:48:27Z [644,292ms] [Error] [carb.scripting-python.plugin] RuntimeError: Failed to acquire interface: isaacsim::asset::importer::urdf::Urdf (pluginName: nullptr)
At:
/home/ljqy/isaacsim/kit/data/Kit/Isaac-Sim/5.1/exts/3/isaacsim.asset.importer.urdf-2.4.31+109.0.1.lx64.r.cp312/isaacsim/asset/importer/urdf/impl/extension.py(123): init
/home/ljqy/isaacsim/kit/data/Kit/Isaac-Sim/5.1/exts/3/isaacsim.asset.importer.urdf-2.4.31+109.0.1.lx64.r.cp312/isaacsim/asset/importer/urdf/impl/extension.py(92): getinstance
/home/ljqy/isaacsim/kit/data/Kit/Isaac-Sim/5.1/exts/3/isaacsim.asset.importer.urdf-2.4.31+109.0.1.lx64.r.cp312/isaacsim/asset/importer/urdf/impl/extension.py(102): on_startup
/home/ljqy/IsaacLab/_isaac_sim/kit/kernel/py/omni/ext/_impl/_internal.py(187): _startup_ext
/home/ljqy/IsaacLab/_isaac_sim/kit/kernel/py/omni/ext/_impl/_internal.py(251): startup
/home/ljqy/IsaacLab/_isaac_sim/kit/kernel/py/omni/ext/_impl/_internal.py(366): startup_extension
PythonExtension.cpp::startup()(2):
/home/ljqy/IsaacLab/_isaac_sim/exts/isaacsim.simulation_app/isaacsim/simulation_app/simulation_app.py(574): _start_app
/home/ljqy/IsaacLab/_isaac_sim/exts/isaacsim.simulation_app/isaacsim/simulation_app/simulation_app.py(287): init
/home/ljqy/IsaacLab/source/isaaclab/isaaclab/app/app_launcher.py(823): _create_app
/home/ljqy/IsaacLab/source/isaaclab/isaaclab/app/app_launcher.py(131): init
/home/ljqy/IsaacLab/scripts/tutorials/00_sim/create_empty.py(29):
2026-07-22T04:48:27Z [644,292ms] [Error] [omni.ext.plugin] [ext: isaacsim.asset.importer.urdf-2.4.31] Failed to startup python extension.
File “/home/ljqy/isaacsim/extscache/omni.graph-1.142.5+6312fa25.lx64.r.cp312/omni/graph/core/_impl/_registration/extension_management.py”, line 155, in extension_management_factory
main_module = sys.modules[module_name]
KeyError: ‘isaacsim.asset.importer.urdf’
During handling of the above exception, another exception occurred:
File “/home/ljqy/isaacsim/extscache/omni.graph-1.142.5+6312fa25.lx64.r.cp312/omni/graph/core/_impl/extension.py”, line 166, in on_after_ext_enabled
new_registration = og.PythonNodeRegistration(ext_name, module_name, ext_path, autonode_config)
File “/home/ljqy/isaacsim/extscache/omni.graph-1.142.5+6312fa25.lx64.r.cp312/omni/graph/core/_impl/registration.py”, line 42, in init
self.__deregistration_methods = register_python_ogn(ext_name, module_name, str(ext_path))
File “/home/ljqy/IsaacLab/_isaac_sim/kit/kernel/py/carb/profiler/init.py”, line 107, in wrapper
r = f(*args, **kwds)
File “/home/ljqy/isaacsim/extscache/omni.graph-1.142.5+6312fa25.lx64.r.cp312/omni/graph/core/_impl/_registration/register_python_ogn.py”, line 78, in register_python_ogn
ext_contents = extension_management_factory(ext_name, module_name, Path(ext_path_name))
File “/home/ljqy/isaacsim/extscache/omni.graph-1.142.5+6312fa25.lx64.r.cp312/omni/graph/core/_impl/_registration/extension_management.py”, line 158, in extension_management_factory
main_module = import_module(module_name)
File “/home/ljqy/IsaacLab/_isaac_sim/kit/python/lib/python3.12/importlib/init.py”, line 90, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File “”, line 1387, in _gcd_import
File “”, line 1360, in _find_and_load
File “”, line 1331, in _find_and_load_unlocked
File “”, line 935, in _load_unlocked
File “”, line 999, in exec_module
File “”, line 488, in _call_with_frames_removed
File “/home/ljqy/isaacsim/kit/data/Kit/Isaac-Sim/5.1/exts/3/isaacsim.asset.importer.urdf-2.4.31+109.0.1.lx64.r.cp312/isaacsim/asset/importer/urdf/init.py”, line 17, in
from .impl.extension import *
File “/home/ljqy/isaacsim/kit/data/Kit/Isaac-Sim/5.1/exts/3/isaacsim.asset.importer.urdf-2.4.31+109.0.1.lx64.r.cp312/isaacsim/asset/importer/urdf/impl/extension.py”, line 31, in
from isaacsim.asset.importer.urdf.impl.ui import (
File “/home/ljqy/isaacsim/kit/data/Kit/Isaac-Sim/5.1/exts/3/isaacsim.asset.importer.urdf-2.4.31+109.0.1.lx64.r.cp312/isaacsim/asset/importer/urdf/impl/ui/init.py”, line 17, in
from .style import *
File “/home/ljqy/isaacsim/kit/data/Kit/Isaac-Sim/5.1/exts/3/isaacsim.asset.importer.urdf-2.4.31+109.0.1.lx64.r.cp312/isaacsim/asset/importer/urdf/impl/ui/style.py”, line 711, in
EXTENSION_FOLDER_PATH = pathlib.Path(
File “/home/ljqy/IsaacLab/_isaac_sim/kit/python/lib/python3.12/pathlib.py”, line 1162, in init
super().init(*args)
File “/home/ljqy/IsaacLab/_isaac_sim/kit/python/lib/python3.12/pathlib.py”, line 373, in init
raise TypeError(
TypeError: argument should be a str or an os.PathLike object where fspath returns a str, not ‘NoneType’
[644.487s] [ext: omni.kit.primitive.mesh-1.1.0] startup
[644.494s] [ext: omni.kit.stage_templates-2.0.2] startup
[644.497s] [ext: isaacsim.core.experimental.utils-0.17.1] startup
[644.498s] [ext: omni.physx.tensors-110.1.11] startup
[644.503s] [ext: isaacsim.core.simulation_manager-1.15.4] startup
2026-07-22T04:48:27Z [644,468ms] [Warning] [isaacsim.core.simulation_manager.plugin] USD stage is not available; stage-opened subscription is deferred
[644.517s] [ext: isaacsim.core.prims-0.11.6] startup
[645.220s] [ext: isaacsim.core.api-5.2.12] startup
[645.232s] [ext: isaacsim.core.cloner-1.7.2] startup
[645.234s] [ext: isaacsim.test.docstring-1.3.1] startup
[645.237s] [ext: isaacsim.core.experimental.prims-1.8.8] startup
[645.257s] [ext: isaacsim.core.experimental.primdata-0.3.2] startup
[645.260s] [ext: isaacsim.core.experimental.materials-0.7.0] startup
[645.264s] [ext: isaacsim.core.experimental.objects-0.8.0] startup
[645.317s] [ext: isaacsim.core.rendering_manager-0.4.2] startup
[645.333s] [ext: omni.graph.image.core-0.6.1] startup
[645.334s] [ext: omni.graph.image.nodes-1.3.1] startup
[645.336s] [ext: omni.graph.nodes_core-2.10.3] startup
[645.353s] [ext: omni.graph.nodes-2.11.1] startup
[645.364s] [ext: omni.graph.scriptnode-2.10.2] startup
[645.372s] [ext: omni.syntheticdata-0.6.15] startup
[645.396s] [ext: omni.replicator.nv-1.1.1] startup
[645.402s] [ext: omni.videoencoding-0.2.1] startup
[645.405s] [ext: omni.replicator.core-1.13.25] startup
2026-07-22T04:48:28Z [645,370ms] [Warning] [pxr.Semantics] pxr.Semantics is deprecated - please use Semantics instead
2026-07-22T04:48:28Z [645,648ms] [Warning] [omni.replicator.core.scripts.extension] No material configuration file, adding configuration to material settings directly.
[645.814s] [ext: isaacsim.core.nodes-5.10.4] startup
[645.842s] [ext: isaacsim.core.throttling-2.3.3] startup
[645.844s] [ext: isaacsim.examples.base-1.3.1] startup
[645.845s] [ext: omni.kit.selection-0.1.6] startup
[645.847s] [ext: isaacsim.gui.menu-2.10.5] startup
[645.854s] [ext: isaacsim.gui.property-1.6.2] startup
[645.861s] [ext: omni.behavior.scripting.core-110.1.0] startup
[645.864s] [ext: isaacsim.replicator.behavior-1.5.3] startup
[645.865s] [ext: isaacsim.robot.surface_gripper-3.6.1] startup
[645.876s] [ext: isaacsim.robot.manipulators-3.4.4] startup
[645.886s] [ext: isaacsim.robot.policy.examples-5.2.11] startup
[645.904s] [ext: isaacsim.robot.wheeled_robots-5.2.3] startup
[645.925s] [ext: omni.kit.numpy.common-0.1.3] startup
[645.927s] [ext: isaacsim.sensors.camera-1.7.8] startup
[646.002s] [ext: omni.sensors.net-1.0.1] startup
[646.006s] [ext: omni.sensors.nv.common-3.0.0] startup
[646.087s] [ext: omni.sensors.nv.materials-2.0.0] startup
[646.093s] [ext: omni.sensors.nv.acoustic-3.0.0] startup
[646.098s] [ext: omni.sensors.nv.ids-2.0.1] startup
[646.101s] [ext: omni.sensors.nv.lidar-3.0.0] startup
[646.108s] [ext: omni.sensors.nv.radar-3.0.0] startup
[646.113s] [ext: isaacsim.sensors.experimental.rtx-1.4.3] startup
[646.344s] [ext: isaacsim.sensors.physics-1.1.7] startup
[646.356s] [ext: isaacsim.util.debug_draw-3.2.2] startup
[646.363s] [ext: isaacsim.sensors.physx-2.5.4] startup
[646.371s] [ext: isaacsim.sensors.rtx-15.17.0] startup
[646.382s] [ext: isaacsim.simulation_app-2.18.3] startup
[646.383s] [ext: omni.anim.curve.core-1.6.0] startup
[646.393s] [ext: omni.asset_validator.core-1.19.3] startup
[646.455s] [ext: omni.graph.ui_nodes-2.10.5] startup
[646.480s] [ext: omni.hydra.scene_api-0.1.3] startup
[646.484s] [ext: omni.kit.manipulator.camera-110.0.0] startup
[646.487s] [ext: omni.kit.menu.create-2.0.2] startup
[646.488s] [ext: omni.kit.property.audio-1.0.16] startup
[646.492s] [ext: omni.kit.property.camera-1.0.14] startup
[646.494s] [ext: omni.kit.property.geometry-2.1.2] startup
[646.497s] [ext: omni.kit.property.light-1.0.14] startup
2026-07-22T04:48:29Z [646,477ms] [Warning] [omni.usd] Encountered USD Warnings but USD Diagnostics are currently muted. To view USD Warnings, please set the ‘/persistent/app/usd/muteUsdDiagnostics’ setting to false in Preferences page.
[646.529s] [ext: omni.kit.property.material-1.14.2] startup
[646.535s] [ext: omni.kit.property.render-1.2.2] startup
[646.537s] [ext: omni.kit.property.transform-1.6.9] startup
[646.540s] [ext: omni.kit.property.bundle-1.5.1] startup
[646.541s] [ext: omni.kit.property.physics-110.1.11] startup
[646.552s] [ext: omni.kit.stagerecorder.core-110.0.9] startup
[646.556s] [ext: omni.kit.stagerecorder.ui-110.0.0] startup
[646.560s] [ext: omni.kit.stagerecorder.bundle-110.0.0] startup
[646.560s] [ext: omni.kit.ui.actions-1.0.5] startup
[646.561s] [ext: omni.ui_query-1.1.10] startup
[646.562s] [ext: omni.kit.ui_test-1.4.4] startup
[646.564s] [ext: omni.kit.viewport.menubar.camera-107.0.10] startup
[646.569s] [ext: omni.kit.viewport.menubar.lighting-107.3.2] startup
[646.572s] [ext: omni.kit.viewport.menubar.render-107.0.10] startup
[646.574s] [ext: omni.kit.viewport.menubar.settings-110.0.1] startup
[646.577s] [ext: omni.kit.window.console-1.1.8] startup
[646.581s] [ext: omni.kit.window.script_editor-2.0.7] startup
[646.584s] [ext: omni.kit.window.status_bar-0.1.11] startup
[646.587s] [ext: omni.kit.window.toolbar-3.0.3] startup
[646.589s] [ext: omni.ocio-0.1.1] startup
[646.590s] [ext: omni.physics.isaacsimready-110.1.11] startup
[646.595s] [ext: omni.physics.physx.ui-110.1.11] startup
[646.615s] [ext: omni.physics.ui-110.1.11] startup
[646.618s] [ext: omni.physx.asset_validator-110.1.11] startup
[646.623s] [ext: omni.physx.demos-110.1.11] startup
[646.638s] [ext: omni.physx.vehicle-110.1.11] startup
[646.654s] [ext: omni.physx.camera-110.1.11] startup
[646.666s] [ext: omni.physx.cct-110.1.11] startup
[646.685s] [ext: omni.physx.graph-110.1.11] startup
[646.710s] [ext: omni.physx.supportui-110.1.11] startup
[646.721s] [ext: omni.physx.bundle-110.1.11] startup
[646.721s] [ext: omni.replicator.replicator_yaml-2.0.12] startup
[646.729s] [ext: omni.rtx.window.settings-0.8.0] startup
[646.734s] [ext: omni.rtx.settings.core-0.7.0] startup
[646.736s] [ext: omni.usd.metrics.assembler.ui-110.1.1] startup
[646.743s] [ext: semantics.schema.editor-2.0.2] startup
[646.746s] [ext: semantics.schema.property-2.0.1] startup
[646.747s] [ext: isaaclab_assets-0.2.4] startup
2026-07-22T04:48:29Z [646,840ms] [Error] [omni.ext._impl.custom_importer] Failed to import python module isaaclab_assets. Error: No module named ‘omni.physics.tensors.impl’. Traceback:
File “/home/ljqy/IsaacLab/_isaac_sim/kit/kernel/py/omni/ext/_impl/custom_importer.py”, line 107, in import_module
return importlib.import_module(name)
File “/home/ljqy/IsaacLab/source/isaaclab_assets/isaaclab_assets/init.py”, line 23, in
from .robots import *
File “/home/ljqy/IsaacLab/source/isaaclab_assets/isaaclab_assets/robots/init.py”, line 10, in
from .agibot import *
File “/home/ljqy/IsaacLab/source/isaaclab_assets/isaaclab_assets/robots/agibot.py”, line 17, in
from isaaclab.assets.articulation import ArticulationCfg
File “/home/ljqy/IsaacLab/source/isaaclab/isaaclab/assets/init.py”, line 41, in
from .articulation import Articulation, ArticulationCfg, ArticulationData
File “/home/ljqy/IsaacLab/source/isaaclab/isaaclab/assets/articulation/init.py”, line 8, in
File “/home/ljqy/IsaacLab/source/isaaclab/isaaclab/assets/articulation/articulation.py”, line 19, in
import omni.physics.tensors.impl.api as physx
ModuleNotFoundError: No module named ‘omni.physics.tensors.impl’
2026-07-22T04:48:29Z [646,840ms] [Error] [carb.scripting-python.plugin] Exception: Extension python module: ‘isaaclab_assets’ in ‘/home/ljqy/IsaacLab/source/isaaclab_assets’ failed to load.
At:
/home/ljqy/IsaacLab/_isaac_sim/kit/kernel/py/omni/ext/_impl/_internal.py(240): startup
2026-07-22T04:48:29Z [646,840ms] [Error] [omni.ext.plugin] [ext: isaaclab_assets-0.2.4] Failed to startup python extension.
[647.147s] [ext: isaaclab_tasks-0.11.16] startup
2026-07-22T04:48:30Z [647,171ms] [Error] [omni.ext._impl.custom_importer] Failed to import python module isaaclab_tasks. Error: No module named ‘omni.physics.tensors.impl’. Traceback:
File “/home/ljqy/IsaacLab/source/isaaclab_tasks/isaaclab_tasks/init.py”, line 33, in
from .utils import import_packages
File “/home/ljqy/IsaacLab/source/isaaclab_tasks/isaaclab_tasks/utils/init.py”, line 9, in
from .parse_cfg import get_checkpoint_path, load_cfg_from_registry, parse_env_cfg
File “/home/ljqy/IsaacLab/source/isaaclab_tasks/isaaclab_tasks/utils/parse_cfg.py”, line 17, in
from isaaclab.envs import DirectRLEnvCfg, ManagerBasedRLEnvCfg
File “/home/ljqy/IsaacLab/source/isaaclab/isaaclab/envs/init.py”, line 45, in
from . import mdp, ui
File “/home/ljqy/IsaacLab/source/isaaclab/isaaclab/envs/mdp/init.py”, line 18, in
from .actions import * # noqa: F401, F403
File “/home/ljqy/IsaacLab/source/isaaclab/isaaclab/envs/mdp/actions/init.py”, line 8, in
from .actions_cfg import *
File “/home/ljqy/IsaacLab/source/isaaclab/isaaclab/envs/mdp/actions/actions_cfg.py”, line 12, in
from . import (
File “/home/ljqy/IsaacLab/source/isaaclab/isaaclab/envs/mdp/actions/binary_joint_actions.py”, line 15, in
2026-07-22T04:48:30Z [647,171ms] [Error] [carb.scripting-python.plugin] Exception: Extension python module: ‘isaaclab_tasks’ in ‘/home/ljqy/IsaacLab/source/isaaclab_tasks’ failed to load.
At:
2026-07-22T04:48:30Z [647,171ms] [Error] [omni.ext.plugin] [ext: isaaclab_tasks-0.11.16] Failed to startup python extension.
[647.481s] [ext: isaaclab_mimic-1.0.16] startup
[647.485s] [ext: isaaclab_rl-0.5.2] startup
[647.486s] [ext: omni.kit.menu.common-2.0.2] startup
[647.487s] [ext: isaaclab.python-2.3.2] startup
[647.489s] Simulation App Starting
Warning: Possible version incompatibility. Attempting to load omni::fabric::IStageReaderWriter with version v0.16 against v0.14.
2026-07-22T04:48:31Z [648,336ms] [Warning] [rtx.hydra] RenderDelegate : Warning /rtx/hydra/readTransformsFromFabricInRenderDelegate and geometry streaming are enabled together but this can cause issues with dynamic objects not streaming correctly due to problems in the transform update.
[648.641s] Simulation App Startup Complete
[648.652s] app ready
2026-07-22T04:48:31Z [648,848ms] [Warning] [omni.kit.menu.utils.layout] Multiple matching items found for layout “Physics”. Found Create, Window. Change <<class ‘omni.kit.menu.utils.layout.MenuLayout.SubMenu’> name:Physics> to use specific source. Using “source=“Create/Physics””
[INFO][IsaacLab]: Logging to file: /tmp/isaaclab/logs/isaaclab_2026-07-22_12-48-31.log
[648.929s] [ext: omni.physx.fabric-110.1.11] startup
12:48:32 [simulation_context.py] WARNING: The enable_external_forces_every_iteration parameter in the PhysxCfg is set to False. If you are experiencing noisy velocities, consider enabling this flag. You may need to slightly increase the number of velocity iterations (setting it to 1 or 2 rather than 0), together with this flag, to improve the accuracy of velocity updates.
File “/home/ljqy/IsaacLab/scripts/tutorials/00_sim/create_empty.py”, line 59, in
main()
File “/home/ljqy/IsaacLab/scripts/tutorials/00_sim/create_empty.py”, line 42, in main
sim = SimulationContext(sim_cfg)
File “/home/ljqy/IsaacLab/source/isaaclab/isaaclab/sim/simulation_context.py”, line 300, in init
super().init(
File “/home/ljqy/isaacsim/extsDeprecated/isaacsim.core.api/isaacsim/core/api/simulation_context/simulation_context.py”, line 156, in init
self._init_stage(
File “/home/ljqy/IsaacLab/source/isaaclab/isaaclab/sim/simulation_context.py”, line 657, in _init_stage
self._set_additional_physx_params()
File “/home/ljqy/IsaacLab/source/isaaclab/isaaclab/sim/simulation_context.py”, line 874, in _set_additional_physx_params
bind_physics_material(self.cfg.physics_prim_path, material_path)
File “/home/ljqy/IsaacLab/source/isaaclab/isaaclab/sim/utils/prims.py”, line 644, in wrapper
success = func(child_prim_path, *args, **kwargs)
File “/home/ljqy/IsaacLab/source/isaaclab/isaaclab/sim/utils/prims.py”, line 871, in bind_physics_material
has_deformable_body = prim.HasAPI(PhysxSchema.PhysxDeformableBodyAPI)
AttributeError: module ‘pxr.PhysxSchema’ has no attribute ‘PhysxDeformableBodyAPI’
2026-07-22T04:48:32Z [649,252ms] [Warning] [simulation_app.simulation_app] SimulationApp.close() was not called explicitly. Shutting down automatically
[649.358s] Simulation App Shutting Down
Screenshots or Videos
(If applicable, add screenshots or links to videos that demonstrate the issue)
Additional Information
What I’ve Tried
(Describe any troubleshooting steps you’ve already taken)
Related Issues
(If you’re aware of any related issues or forum posts, please link them here)
Additional Context
(Add any other context about the problem here)
