Isaac Lab Deformable Body
Hi all, thanks for the great work with Isaac Lab!
Previously, I had an OIGE simulation based on the Franka Deformable example. I’m trying to migrate this to Isaac Lab to be able to use other training frameworks and also, if I understood correctly, to use Manager Based environments so that I can separate scene creation from the training (and hopefully be able to use trained policies as part of more complex scenes).
The problem is that I cannot get the deformable body to work on Isaac Lab. I’m getting these errors:
2024-06-08 13:44:20 [8,977ms] [Error] [omni.physx.plugin] Replication of this type is not supported: 1638400, prim path: /World/envs/env_0/MyDeformableBody/DeformableMaterial
2024-06-08 13:44:20 [8,977ms] [Error] [omni.physx.plugin] Replication of this type is not supported: 1769472, prim path: /World/envs/env_0/MyDeformableBody/Cylinder
Also, in OIGE, I could do this in the set_up_scene:
from pxr import Gf, UsdPhysics, PhysxSchema
  physicsScenePath = "/physicsScene"
        scene = UsdPhysics.Scene.Get(self.stage, physicsScenePath)
        if not scene:
            scene = UsdPhysics.Scene.Define(self.stage, physicsScenePath)
        physxSceneAPI = PhysxSchema.PhysxSceneAPI.Apply(scene.GetPrim())
        physxSceneAPI.GetGpuMaxSoftBodyContactsAttr().Set(2048576)  # Setting the GPU Max Soft Body Contacts attribute
And now I get:
Module pxr.UsdPhysics has no Scene members
Anything I’m missing? Any pointers?
I have encountered with the same issues. Have you found the solution for that? Thank you.
This PR (Adds APIs for spawning deformable meshes by Mayankm96 · Pull Request #613 · isaac-sim/IsaacLab · GitHub) seems to add deformables to IsaacLab but I have not tested it.
Thank you for your interest in Isaac Lab. To ensure efficient support and collaboration, please submit your topic to its GitHub repo following the instructions provided on Isaac Lab’s Contributing Guidelines regarding discussions, submitting issues, feature requests, and contributing to the project.
We appreciate your understanding and look forward to assisting you.
