I am trying to build my own Isaac Lab project via the IsaacLabExtensionTemplate repo, but it seems that the setup_python_env VSCode task only works on linux? The code is:
"tasks": [
"label": "setup_python_env",
"type": "shell",
"linux": {
"command": ...
Can you update the task to have a valid windows command? Thanks! What is the workaround in the meantime? What directory are you supposed to create custom extensions under?
