I managed to install Isaac Sim and Isaac lab using these instructions Installation using Isaac Sim pip — Isaac Lab documentation (thanks to the team for uploading all the packages!) However, I am unable to verify the installation by running the empty world example Verifying the Installation — Isaac Lab documentation
The mini kit window from running the isaacsim command starts fine but I am met with the following error when attempting to start the empty world:
2024-06-12 08:48:41 [3,912ms] [Error] [omni.ext.plugin] Failed to resolve extension dependencies. Failure hints:
[isaaclab.python-1.0.0] dependency: 'omni.physx.bundle' = { version='^' } can't be satisfied. Available versions:
(none found)
Synced registries:
- kit/default : found 379 packages
- kit/sdk : found 299 packages
- kit/community : found 342 packages
2024-06-12 08:48:41 [3,912ms] [Error] [omni.kit.app.plugin] Exiting app because of dependency solver failure...
Also gave a missing module error:
ModuleNotFoundError: No module named 'omni.kit.usd'
Any help would be greatly appreciated!
