I’m facing an issue with the keypoint_creation_config.pb.txt
file—I have no information on how to define it. Additionally, the frames_metadata.pb.txt
file, which should be inside the input_image_directory , is also missing.
The Isaac Mapping ROS run_rosbag_to_mapping_data
provided the images and metadata only in JSONL format (frames_metadata.jsonl
, frames_metadata.json
To extract the features, I need to run:
feature_extractor_main \
--input_image_directory <input_image_dir> \
--output_dir <output_keyframe_dir> \
--keypoint_creation_config configs/keypoint_creation_config.pb.txt
Is there any additional information available on this topic?
I found the pb.txt
config file, but I’m still getting an error message.
./feature_extractor_main \
--input_image_directory /workspaces/isaac_ros-dev/src/fs_25_andreaskradolfer/viras_ros_global_localization/map \
--output_dir /workspaces/isaac_ros-dev/src/fs_25_andreaskradolfer/viras_ros_global_localization/map/features \
--keypoint_creation_config /opt/ros/humble/share/isaac_mapping_ros/configs/keypoint_creation_config.pb.txt
keypoint_creation_config.pb.txt:
sift_cv_cuda_detector {
# in order to increase success rate, increase layers, suggest formulat is log(min(image_width,image_height))/log(2)-2
max_layers_per_octave: 6
# match with SIFT GPU peak_threshold, SIFT GPU use 0.02/layers, layer number use 3
contrast_threshold: 0.02
edge_threshold: 10.0
initial_sigma: 1.6
expand_input_image: false
max_num_keypoints: 4096
num_points_tolerance_fraction: 0.5
global_non_max_method: NONE
super_point_detector {
max_key_points_for_tensorrt: 4000
detector_threshold: 0.005
tensorrt_config {
model_id: 0
input_dimension {
min: 1
min: 1
min: 100
min: 100
opt: 1
opt: 1
opt: 1200
opt: 1920
max: 1
max: 1
max: 2400
max: 4000
tensorrt_config{
model_id: 1
input_dimension {
min: 1
min: 2
opt: 3200
opt: 2
max: 5500
max: 2
input_dimension {
min: 1
min: 256
min: 1
min: 1
opt: 1
opt: 256
opt: 150
opt: 240
max: 1
max: 256
max: 300
max: 500
my error:
admin@viras32:/opt/ros/humble/bin/isaac_mapping$ ./feature_extractor_main --input_image_directory /workspaces/isaac_ros-dev/src/fs_25_andreaskradolfer/viras_ros_global_localization/map --output_dir /workspaces/isaac_ros-dev/src/fs_25_andreaskradolfer/viras_ros_global_localization/map/features --keypoint_creation_config /opt/ros/humble/share/isaac_mapping_ros/configs/keypoint_creation_config.pb.txt
F0402 16:44:22.121856 13734 feature_extractor_main.cc:101] Unsupport feature type:
*** Check failure stack trace: ***
@ 0xffffbb1ed41c google::LogMessage::Fail()
@ 0xffffbb1f46d0 google::LogMessage::SendToLog()
@ 0xffffbb1ed0f4 google::LogMessage::Flush()
@ 0xffffbb1eeebc google::LogMessageFatal::~LogMessageFatal()
@ 0xaaaab28457a8 (unknown)
@ 0xffffa99473fc (unknown)
@ 0xffffa99474cc __libc_start_main
@ 0xaaaab2848c70 (unknown)
Aborted (core dumped)
dizeng
April 2, 2025, 5:12pm
3
Hi Andreas, Please provide the command line flag --feature_type sift
since you are calling the binary directly.
See create_cuvgl_map.py
for examples of how to call the binary. For ease of use, we suggest directly using the Python script.
system
Closed
April 16, 2025, 5:12pm
4
