OS: Ubuntu 22.04 jammy
Jetpack: 6.2.1+b38
Nova Config: nova-devkit
Nova Version: 1.3.2+b4
ISAAC Version = 3.2
I am using the NOVA devkit and launching the following:
ros2 launch isaac_ros_nova_recorder nova_recorder.launch.py
However, I unfortunately get this error message:
[component_container_mt-1] [WARN] [1762788954.644298361] [NitrosCameraInfo]: [convert_to_ros_message] Failed to get the Rectified CameraModel object: Falling back to raw camera model
[component_container_mt-1] [WARN] [1762788954.644377625] [NitrosCameraInfo]: [convert_to_ros_message] Failed to get the target extrinsics delta Pose3D object: GXF_ENTITY_COMPONENT_NOT_FOUNDFalling back to extrinsics Pose3D object
- Nova pre-flight checker works perfectly, including the EEPROM checks.
- All topics (compressed images/camera info/lidar packets) seemed to be recorded correctly and are received at correct frame rate. (although rectified topics are not published of course)
Any help would be greatly appreciated.
