Dear Sir or Madam
I have tried to run Isaac Perceptor on Isaac Sim based on the tutorial below.
https://nvidia-isaac-ros.github.io/reference_workflows/isaac_perceptor/run_perceptor_in_sim.html
I was able to confirm that it worked up to the point shown below in “Visualizing the Outputs”.
I manipulated the “2D Goal Pose” and confirmed that Nova Carter moved and colored voxels were displayed rviz.
https://nvidia-isaac-ros.github.io/reference_workflows/isaac_perceptor/run_perceptor_in_sim.html#visualizing-the-outputs
But I couldn’t get Global Navigation to work.
/map was not displayed on rviz.
Nova Carter did not move when operating the “2D Goal Pose”.
best regards,
Isaac Sim Version
4.2.0
Operating System
Ubuntu 22.04
GPU Information
- Model: NVIDIA GeForce RTX 3080
- Driver Version: 560.35.05
- CUDA Version: 12.6
Topic Description
Error Messages
perceptor_global_navigation_01.txt (166.4 KB)
Screenshots or Videos
Hello.
I hope this message finds you well.
Do you have any update?
Best regards,
Hi @kazushi-uchida
Thank you for your post. Looking at your details, it seems everything is working well.
Have you tried subscribing from the map node from the terminal if an output is coming out?
Best,
Raffaello
Hi @Raffaello
Thank you for your reply.
I subscribed to the /map topic in the following way:
- ros2 topic echo /map
- Subscribe to the /map topic in a python program and save it to a text file
I attach the resulting /map topic.
If I check the resulting text file, I will see that the /map topic has been saved correctly.
However, the /map topic cannot be displayed in rviz, and global navigation cannot be performed.
Do I need to do anything special to perform global navigation with perceptor?
Best regards,
ros2_topic_echo_map.txt (1.0 KB)
map_sub_python.txt (2.5 MB)
Hi @kazushi-uchida
It looks more like it is an rviz issue than from Isaac Perceptor.
You can try other tools, like https://foxglove.dev/
Let me know,
Raffaello
Hi @Raffaello
I tried to get the /map topic using foxglove.
But I couldn’t get the /map topic.
I couldn’t get the tf map frame either, just like the tf tree I showed in my first post.
So I can’t do the operation in the following link: “In RViz, change the fixed frame to the map frame by setting the value of Display - Global Options - Fixed Frame to map.”
Best regards,
Kazushi Uchida
