I tried the Isaac perceptor tutorial with isaac sim
https://nvidia-isaac-ros.github.io/reference_workflows/isaac_perceptor/run_perceptor_in_sim.html
Prerequisites and installing debian packages and assets(inside Isaac ROS Docker container) but “ros2 run” commands shows fail
Commands tried
# Run Isaac ros container
cd ${ISAAC_ROS_WS}/src/isaac_ros_common && \
./scripts/run_dev.sh
cd /workspaces/isaac_ros-dev
vcs import --recursive --workers 1 --delay 5.0 src < src/nova_carter/nova_carter.repos
# Inside the Isaac ROS container
sudo apt update
sudo apt-get install -y ros-humble-nova-carter-bringup
source /opt/ros/humble/setup.bash
sudo apt-get install -y ros-humble-isaac-ros-peoplesemseg-models-install ros-humble-isaac-ros-ess-models-install
### Failed from below ###
ros2 run isaac_ros_ess_models_install install_ess_models.sh --eula
ros2 run isaac_ros_peoplesemseg_models_install install_peoplesemsegnet_vanilla.sh --eula
ros2 run isaac_ros_peoplesemseg_models_install install_peoplesemsegnet_shuffleseg.sh --eula
Shown error message (three ros2 run commands shows same error)
[05/13/2025-08:55:10] [E] Error[1]: IBuilder::buildSerializedNetwork: Error Code 1: Internal Error (Unsupported SM: 0xc00)
[05/13/2025-08:55:10] [E] Engine could not be created from network
[05/13/2025-08:55:10] [E] Building engine failed
[05/13/2025-08:55:10] [E] Failed to create engine from model or file.
[05/13/2025-08:55:10] [E] Engine set up failed
&&&& FAILED TensorRT.trtexec [TensorRT v100300] # /usr/src/tensorrt/bin/trtexec --maxShapes=input_1:0:1x3x544x960 --minShapes=input_1:0:1x3x544x960 --optShapes=input_1:0:1x3x544x960 --onnx=/workspaces/isaac_ros-dev/isaac_ros_assets/models/peoplesemsegnet/deployable_quantized_vanilla_unet_onnx_v2.0/model.onnx --saveEngine=/workspaces/isaac_ros-dev/isaac_ros_assets/models/peoplesemsegnet/deployable_quantized_vanilla_unet_onnx_v2.0/1/model.plan --fp16 --skipInference
My system environment is below
OS: Ubuntu 22.04
GPU: RTX5090 *1
NVIDIA Driver Version: 570.144
CUDA version: 11.5, but in isaac ros container it shows 12.6
Isaac sim version: tried 4.2, 4.5 with ROS2 humble enabled
How can I solve this?
Thanks for your help.
