mat-h
#1
I’d like to share the USB Camera trial result from below link;
I try to use USB-camera like below with “isaac_ros_image_segmentation”
ros2 run image_publisher image_publisher_node /dev/video0 --ros-args -r image_raw:=image
I hope this will help.
Best regards,
You can use this launch file to run inference and either use the v4l2 package or image publisher to access the camera.
mat-h
#3
Thank you very much for your kindness.
I really appreciate your help.
I’d like to check the behavior with your guide.
Best regards,
