Isaac ROS Container Permissions Issue
I am attempting to run Isaac ROS VSLAM on a Jetson Orin NX 16GB board using Isaac ROS version 3.1. However, when trying to run the package, I received numerous errors about a missing GPU. After much detective work, I have narrowed down the problem to this: the container does not have the proper permissions to access the GPU. I am sure of this, because the nvidia-smi command results in “Unable to determine the device handle for GPU0002:00:00.0: Unknown Error”, while sudo nvidia-smi results in the expected summary:
| NVIDIA-SMI 540.3.0 Driver Version: N/A CUDA Version: 12.2 |
| GPU Name Persistence-M | Bus-Id Disp.A | Volatile Uncorr. ECC |
| | | MIG M. |
| 0 Orin (nvgpu) N/A | N/A N/A | N/A |
| N/A N/A N/A N/A / N/A | Not Supported | N/A N/A |
| | | N/A |
| Processes: |
| ID ID Usage |
| No running processes found |
My running hypothesis is that the Isaac ROS Dockerfile.user script is overriding permissions or providing incorrect permissions to the container. I noticed that the run_dev.sh script already makes the container privileged, so I am not sure what to try, as I don’t see any glaring errors in the Dockerfile.user script.
Please let me know if you have experienced this issue and if so, how you fixed it! Thank you in advance!
Hi @kalena.mccloskey
Thank you for your post.
Usually, this happens due to mismatched version of installed toolchain.
You might want to flash your Jetson NX with Jetpack 6.0 using SDK Manager. Then go through System Requirements and Setup in Getting Started. One reminder is not to upgrade JetPack as 36.4. That is for Jetpack 6.2 and Isaac ROS 3.2.
Once you are set up, check out the Repositories and Packages to start running Isaac ROS packages!
Let me know,
Best,
Ahung
