ISAAC ROS ESS Stereo Depth Estimation not working with pre-processed image data
As mentioned in Optimizing ISAAC ROS ESS Depth Estimation to run efficiently with lower GPU memory utilization I am trying to run ISAAC ROS ESS Depth Estimation on multi cameras with limited 6GB of GPU memory on my robot. I was trying a workout to merge images from two cameras with known transforms between them using perspective transform. When I feed those topics to isaac_ros_ess depth estimation it does not output any disparity.
I am guessing it is to do with
[image_format_node_right]: [NitrosSubscriber] Received a message but the application receiver's pointer is not yet set.
My image_format_node_right nodes do output the mono8->rgb8 image. Additionally my preprocessed image data matches input image dimensions for light_ess model.
PFA the output log file and my launch file.
Thank you.
Output Log
O] [launch]: All log files can be found below /home/admin/.ros/log/2023-10-26-18-48-06-303030-legion-120436
[INFO] [launch]: Default logging verbosity is set to INFO
[INFO] [component_container_mt-1]: process started with pid [120447]
[INFO] [rviz2-2]: process started with pid [120449]
[INFO] [filter_pointcloud-3]: process started with pid [120451]
[rviz2-2] QStandardPaths: XDG_RUNTIME_DIR not set, defaulting to '/tmp/runtime-admin'
[rviz2-2] MESA: warning: Driver does not support the 0xa7a0 PCI ID.
[rviz2-2] libGL error: failed to create dri screen
[rviz2-2] libGL error: failed to load driver: iris
[component_container_mt-1] [INFO] [1698360486.686138507] [disparity.disparity_container]: Load Library: /workspaces/rm250_ros2/install/isaac_ros_ess/lib/libisaac_ros_ess_node.so
[component_container_mt-1] [INFO] [1698360486.698394278] [disparity.disparity_container]: Found class: rclcpp_components::NodeFactoryTemplate<nvidia::isaac_ros::dnn_stereo_depth::ESSDisparityNode>
[component_container_mt-1] [INFO] [1698360486.698414630] [disparity.disparity_container]: Instantiate class: rclcpp_components::NodeFactoryTemplate<nvidia::isaac_ros::dnn_stereo_depth::ESSDisparityNode>
[component_container_mt-1] [INFO] [1698360486.700991550] [NitrosContext]: [NitrosContext] Creating a new shared context
[component_container_mt-1] [INFO] [1698360486.701078082] [disparity]: [NitrosNode] Initializing NitrosNode
[component_container_mt-1] [INFO] [1698360486.701426305] [NitrosContext]: [NitrosContext] Loading extension: gxf/lib/std/libgxf_std.so
[component_container_mt-1] [INFO] [1698360486.704798886] [NitrosContext]: [NitrosContext] Loading extension: gxf/lib/libgxf_gxf_helpers.so
[component_container_mt-1] [INFO] [1698360486.706582936] [NitrosContext]: [NitrosContext] Loading extension: gxf/lib/libgxf_sight.so
[component_container_mt-1] [INFO] [1698360486.708523695] [NitrosContext]: [NitrosContext] Loading extension: gxf/lib/libgxf_atlas.so
[component_container_mt-1] [INFO] [1698360486.710927260] [NitrosContext]: [NitrosContext] Loading application: '/workspaces/rm250_ros2/install/isaac_ros_nitros/share/isaac_ros_nitros/config/type_adapter_nitros_context_graph.yaml'
[component_container_mt-1] [INFO] [1698360486.711282999] [NitrosContext]: [NitrosContext] Initializing application...
[component_container_mt-1] [INFO] [1698360486.713905470] [NitrosContext]: [NitrosContext] Running application...
[component_container_mt-1] 2023-10-26 18:48:06.713 WARN  gxf/std/program.cpp@514: No system specified. Nothing to do
[component_container_mt-1] [INFO] [1698360486.714395461] [disparity]: [NitrosNode] Starting NitrosNode
[component_container_mt-1] [INFO] [1698360486.714405246] [disparity]: [NitrosNode] Loading built-in preset extension specs
[component_container_mt-1] [INFO] [1698360486.715309259] [disparity]: [NitrosNode] Loading built-in extension specs
[component_container_mt-1] [INFO] [1698360486.715315864] [disparity]: [NitrosNode] Loading preset extension specs
[component_container_mt-1] [INFO] [1698360486.716027766] [disparity]: [NitrosNode] Loading extension specs
[component_container_mt-1] [INFO] [1698360486.716034940] [disparity]: [NitrosNode] Loading generator rules
[component_container_mt-1] [INFO] [1698360486.716037414] [disparity]: [NitrosNode] Loading extensions
[component_container_mt-1] [INFO] [1698360486.716145460] [disparity]: [NitrosContext] Loading extension: gxf/lib/libgxf_message_compositor.so
[component_container_mt-1] [INFO] [1698360486.716877109] [disparity]: [NitrosContext] Loading extension: gxf/lib/multimedia/libgxf_multimedia.so
[component_container_mt-1] [INFO] [1698360486.717508600] [disparity]: [NitrosContext] Loading extension: gxf/lib/cuda/libgxf_cuda.so
[component_container_mt-1] [INFO] [1698360486.718170847] [disparity]: [NitrosContext] Loading extension: gxf/lib/serialization/libgxf_serialization.so
[component_container_mt-1] [INFO] [1698360486.720228740] [disparity]: [NitrosContext] Loading extension: gxf/lib/libgxf_synchronization.so
[component_container_mt-1] [INFO] [1698360486.720970307] [disparity]: [NitrosContext] Loading extension: gxf/lib/thresholder/libgxf_thresholder.so
[component_container_mt-1] [INFO] [1698360486.721938000] [disparity]: [NitrosContext] Loading extension: gxf/lib/libgxf_isaac_messages.so
[component_container_mt-1] [INFO] [1698360486.722634151] [disparity]: [NitrosContext] Loading extension: gxf/lib/image_proc/libgxf_tensorops.so
[component_container_mt-1] [INFO] [1698360486.724919872] [disparity]: [NitrosContext] Loading extension: gxf/lib/sgm_disparity/libgxf_sgm.so
[component_container_mt-1] [INFO] [1698360486.725796824] [disparity]: [NitrosContext] Loading extension: gxf/lib/ess/libgxf_cvcore_ess.so
[component_container_mt-1] [INFO] [1698360486.738767913] [disparity]: [NitrosNode] Loading graph to the optimizer
[component_container_mt-1] [INFO] [1698360486.741180051] [disparity]: [NitrosNode] Running optimization
[component_container_mt-1] [INFO] [1698360486.817277557] [disparity]: [NitrosNode] Obtaining graph IO group info from the optimizer
[component_container_mt-1] [INFO] [1698360486.818265069] [disparity]: [NitrosNode] Creating negotiated publishers/subscribers
[component_container_mt-1] [INFO] [1698360486.824240507] [disparity]: [NitrosNode] Starting negotiation...
[INFO] [launch_ros.actions.load_composable_nodes]: Loaded node '/disparity' in container '/disparity/disparity_container'
[component_container_mt-1] [INFO] [1698360486.825487684] [disparity.disparity_container]: Load Library: /workspaces/rm250_ros2/install/isaac_ros_image_proc/lib/libimage_format_converter_node.so
[component_container_mt-1] [INFO] [1698360486.826447497] [disparity.disparity_container]: Found class: rclcpp_components::NodeFactoryTemplate<nvidia::isaac_ros::image_proc::ImageFormatConverterNode>
[component_container_mt-1] [INFO] [1698360486.826461234] [disparity.disparity_container]: Instantiate class: rclcpp_components::NodeFactoryTemplate<nvidia::isaac_ros::image_proc::ImageFormatConverterNode>
[component_container_mt-1] [INFO] [1698360486.829471466] [image_format_node_left]: [NitrosNode] Initializing NitrosNode
[component_container_mt-1] [INFO] [1698360486.829886871] [image_format_node_left]: [ImageFormatConverterNode] Set output data format to: "nitros_image_rgb8"
[component_container_mt-1] [INFO] [1698360486.829935588] [image_format_node_left]: [NitrosNode] Starting NitrosNode
[component_container_mt-1] [INFO] [1698360486.829941314] [image_format_node_left]: [NitrosNode] Loading built-in preset extension specs
[component_container_mt-1] [INFO] [1698360486.831259067] [image_format_node_left]: [NitrosNode] Loading built-in extension specs
[component_container_mt-1] [INFO] [1698360486.831268358] [image_format_node_left]: [NitrosNode] Loading preset extension specs
[component_container_mt-1] [INFO] [1698360486.834748584] [image_format_node_left]: [NitrosNode] Loading extension specs
[component_container_mt-1] [INFO] [1698360486.834764438] [image_format_node_left]: [NitrosNode] Loading generator rules
[component_container_mt-1] [INFO] [1698360486.834923906] [image_format_node_left]: [NitrosNode] Loading extensions
[component_container_mt-1] [INFO] [1698360486.835388185] [image_format_node_left]: [NitrosNode] Loading graph to the optimizer
[component_container_mt-1] [INFO] [1698360486.836101097] [image_format_node_left]: [NitrosNode] Running optimization
[component_container_mt-1] [INFO] [1698360486.862001349] [image_format_node_left]: [NitrosNode] Obtaining graph IO group info from the optimizer
[component_container_mt-1] [INFO] [1698360486.865196314] [image_format_node_left]: [NitrosNode] Creating negotiated publishers/subscribers
[component_container_mt-1] [INFO] [1698360486.865221632] [image_format_node_left]: [NitrosPublisherSubscriberGroup] Pinning the component "sink/sink" (type="nvidia::isaac_ros::MessageRelay") to use its compatible format only: "nitros_image_rgb8"
[component_container_mt-1] [INFO] [1698360486.866502722] [image_format_node_left]: [NitrosNode] Starting negotiation...
[INFO] [launch_ros.actions.load_composable_nodes]: Loaded node '/image_format_node_left' in container '/disparity/disparity_container'
[component_container_mt-1] [INFO] [1698360486.867141099] [image_format_node_left]: Negotiating
[component_container_mt-1] [INFO] [1698360486.867655821] [disparity.disparity_container]: Found class: rclcpp_components::NodeFactoryTemplate<nvidia::isaac_ros::image_proc::ImageFormatConverterNode>
[component_container_mt-1] [INFO] [1698360486.867671836] [disparity.disparity_container]: Instantiate class: rclcpp_components::NodeFactoryTemplate<nvidia::isaac_ros::image_proc::ImageFormatConverterNode>
[rviz2-2] [INFO] [1698360486.869047637] [rviz2]: Stereo is NOT SUPPORTED
[rviz2-2] [INFO] [1698360486.869100628] [rviz2]: OpenGl version: 3.1 (GLSL 1.4)
[component_container_mt-1] [INFO] [1698360486.870464911] [image_format_node_right]: [NitrosNode] Initializing NitrosNode
[component_container_mt-1] [INFO] [1698360486.870772781] [image_format_node_right]: [ImageFormatConverterNode] Set output data format to: "nitros_image_rgb8"
[component_container_mt-1] [INFO] [1698360486.870800170] [image_format_node_right]: [NitrosNode] Starting NitrosNode
[component_container_mt-1] [INFO] [1698360486.870804166] [image_format_node_right]: [NitrosNode] Loading built-in preset extension specs
[component_container_mt-1] [INFO] [1698360486.871931880] [image_format_node_right]: [NitrosNode] Loading built-in extension specs
[component_container_mt-1] [INFO] [1698360486.871941226] [image_format_node_right]: [NitrosNode] Loading preset extension specs
[component_container_mt-1] [INFO] [1698360486.874835666] [image_format_node_right]: [NitrosNode] Loading extension specs
[component_container_mt-1] [INFO] [1698360486.874857961] [image_format_node_right]: [NitrosNode] Loading generator rules
[component_container_mt-1] [INFO] [1698360486.875005735] [image_format_node_right]: [NitrosNode] Loading extensions
[component_container_mt-1] [INFO] [1698360486.875392304] [image_format_node_right]: [NitrosNode] Loading graph to the optimizer
[component_container_mt-1] [INFO] [1698360486.876079233] [image_format_node_right]: [NitrosNode] Running optimization
[component_container_mt-1] [INFO] [1698360486.881866848] [disparity]: [NitrosSubscriber] Received a message but the application receiver's pointer is not yet set.
[component_container_mt-1] [INFO] [1698360486.888436936] [disparity]: [NitrosSubscriber] Received a message but the application receiver's pointer is not yet set.
[rviz2-2] [INFO] [1698360486.901193330] [rviz2]: Stereo is NOT SUPPORTED
[component_container_mt-1] [INFO] [1698360486.902925185] [image_format_node_right]: [NitrosNode] Obtaining graph IO group info from the optimizer
[component_container_mt-1] [INFO] [1698360486.907158879] [image_format_node_right]: [NitrosNode] Creating negotiated publishers/subscribers
[component_container_mt-1] [INFO] [1698360486.907192934] [image_format_node_right]: [NitrosPublisherSubscriberGroup] Pinning the component "sink/sink" (type="nvidia::isaac_ros::MessageRelay") to use its compatible format only: "nitros_image_rgb8"
[component_container_mt-1] [INFO] [1698360486.908481962] [image_format_node_right]: [NitrosNode] Starting negotiation...
[INFO] [launch_ros.actions.load_composable_nodes]: Loaded node '/image_format_node_right' in container '/disparity/disparity_container'
[component_container_mt-1] [INFO] [1698360486.909727276] [disparity.disparity_container]: Load Library: /workspaces/rm250_ros2/install/isaac_ros_stereo_image_proc/lib/libpoint_cloud_node.so
[component_container_mt-1] [INFO] [1698360486.911896603] [disparity.disparity_container]: Found class: rclcpp_components::NodeFactoryTemplate<nvidia::isaac_ros::stereo_image_proc::PointCloudNode>
[component_container_mt-1] [INFO] [1698360486.911908127] [disparity.disparity_container]: Instantiate class: rclcpp_components::NodeFactoryTemplate<nvidia::isaac_ros::stereo_image_proc::PointCloudNode>
[component_container_mt-1] [INFO] [1698360486.914215340] [pointcloud_node]: [NitrosNode] Initializing NitrosNode
[component_container_mt-1] [INFO] [1698360486.914579901] [pointcloud_node]: [NitrosNode] Starting NitrosNode
[component_container_mt-1] [INFO] [1698360486.914587509] [pointcloud_node]: [NitrosNode] Loading built-in preset extension specs
[component_container_mt-1] [INFO] [1698360486.915516634] [pointcloud_node]: [NitrosNode] Loading built-in extension specs
[component_container_mt-1] [INFO] [1698360486.915525154] [pointcloud_node]: [NitrosNode] Loading preset extension specs
[component_container_mt-1] [INFO] [1698360486.915922206] [pointcloud_node]: [NitrosNode] Loading extension specs
[component_container_mt-1] [INFO] [1698360486.915926975] [pointcloud_node]: [NitrosNode] Loading generator rules
[component_container_mt-1] [INFO] [1698360486.915929836] [pointcloud_node]: [NitrosNode] Loading extensions
[component_container_mt-1] [INFO] [1698360486.916422990] [pointcloud_node]: [NitrosContext] Loading extension: gxf/lib/libgxf_point_cloud.so
[component_container_mt-1] [INFO] [1698360486.942386548] [image_format_node_left]: [NitrosSubscriber] Received a message but the application receiver's pointer is not yet set.
[component_container_mt-1] [INFO] [1698360486.942743794] [NitrosContext]: [NitrosContext] Loading extension: gxf/lib/libgxf_isaac_ros_messages.so
[component_container_mt-1] [INFO] [1698360486.943906161] [pointcloud_node]: [NitrosNode] Loading graph to the optimizer
[component_container_mt-1] [INFO] [1698360486.945310810] [pointcloud_node]: [NitrosNode] Running optimization
[component_container_mt-1] [INFO] [1698360486.961416239] [pointcloud_node]: [NitrosNode] Obtaining graph IO group info from the optimizer
[component_container_mt-1] [INFO] [1698360486.961744638] [pointcloud_node]: [NitrosNode] Creating negotiated publishers/subscribers
[component_container_mt-1] [INFO] [1698360486.965177237] [pointcloud_node]: [NitrosNode] Starting negotiation...
[component_container_mt-1] [INFO] [1698360486.965437038] [image_format_node_left]: Negotiating
[INFO] [launch_ros.actions.load_composable_nodes]: Loaded node '/pointcloud_node' in container '/disparity/disparity_container'
[component_container_mt-1] [INFO] [1698360486.965460043] [disparity]: Negotiating
[component_container_mt-1] [INFO] [1698360486.965496203] [disparity]: Could not negotiate
[component_container_mt-1] [INFO] [1698360486.965642319] [image_format_node_left]: Negotiating
[component_container_mt-1] [INFO] [1698360486.966877761] [disparity.disparity_container]: Load Library: /opt/ros/humble/lib/libstatic_transform_broadcaster_node.so
[component_container_mt-1] [INFO] [1698360486.968097537] [disparity.disparity_container]: Found class: rclcpp_components::NodeFactoryTemplate<tf2_ros::StaticTransformBroadcasterNode>
[component_container_mt-1] [INFO] [1698360486.968114086] [disparity.disparity_container]: Instantiate class: rclcpp_components::NodeFactoryTemplate<tf2_ros::StaticTransformBroadcasterNode>
[INFO] [launch_ros.actions.load_composable_nodes]: Loaded node '/static_transform_publisher_1' in container '/disparity/disparity_container'
[component_container_mt-1] [INFO] [1698360486.973712429] [disparity.disparity_container]: Found class: rclcpp_components::NodeFactoryTemplate<tf2_ros::StaticTransformBroadcasterNode>
[component_container_mt-1] [INFO] [1698360486.973743118] [disparity.disparity_container]: Instantiate class: rclcpp_components::NodeFactoryTemplate<tf2_ros::StaticTransformBroadcasterNode>
[INFO] [launch_ros.actions.load_composable_nodes]: Loaded node '/static_transform_publisher_2' in container '/disparity/disparity_container'
[component_container_mt-1] [INFO] [1698360486.978762051] [image_format_node_right]: Negotiating
[component_container_mt-1] [INFO] [1698360486.978820794] [disparity.disparity_container]: Found class: rclcpp_components::NodeFactoryTemplate<tf2_ros::StaticTransformBroadcasterNode>
[component_container_mt-1] [INFO] [1698360486.978843066] [disparity.disparity_container]: Instantiate class: rclcpp_components::NodeFactoryTemplate<tf2_ros::StaticTransformBroadcasterNode>
[component_container_mt-1] [INFO] [1698360486.978960187] [image_format_node_right]: Negotiating
[INFO] [launch_ros.actions.load_composable_nodes]: Loaded node '/static_transform_publisher_3' in container '/disparity/disparity_container'
[component_container_mt-1] [INFO] [1698360486.988608002] [image_format_node_right]: [NitrosSubscriber] Received a message but the application receiver's pointer is not yet set.
[component_container_mt-1] [INFO] [1698360486.988759787] [disparity]: [NitrosSubscriber] Received a message but the application receiver's pointer is not yet set.
[component_container_mt-1] [INFO] [1698360486.988761929] [pointcloud_node]: [NitrosSubscriber] Received a message but the application receiver's pointer is not yet set.
[component_container_mt-1] [INFO] [1698360487.015327235] [pointcloud_node]: [NitrosSubscriber] Received a message but the application receiver's pointer is not yet set.
[component_container_mt-1] [INFO] [1698360487.015508296] [disparity]: [NitrosSubscriber] Received a message but the application receiver's pointer is not yet set.
[component_container_mt-1] [INFO] [1698360487.015510891] [image_format_node_left]: [NitrosSubscriber] Received a message but the application receiver's pointer is not yet set.
[component_container_mt-1] [INFO] [1698360487.055224730] [pointcloud_node]: [NitrosSubscriber] Received a message but the application receiver's pointer is not yet set.
[component_container_mt-1] [INFO] [1698360487.055375431] [disparity]: [NitrosSubscriber] Received a message but the application receiver's pointer is not yet set.
[component_container_mt-1] [INFO] [1698360487.055514727] [image_format_node_right]: [NitrosSubscriber] Received a message but the application receiver's pointer is not yet set.
[component_container_mt-1] [INFO] [1698360487.081864794] [disparity]: [NitrosSubscriber] Received a message but the application receiver's pointer is not yet set.
[component_container_mt-1] [INFO] [1698360487.082006045] [pointcloud_node]: [NitrosSubscriber] Received a message but the application receiver's pointer is not yet set.
[component_container_mt-1] [INFO] [1698360487.082151644] [image_format_node_left]: [NitrosSubscriber] Received a message but the application receiver's pointer is not yet set.
[rviz2-2] [INFO] [1698360487.087845480] [rviz2]: Stereo is NOT SUPPORTED
[component_container_mt-1] [INFO] [1698360487.115200137] [image_format_node_left]: [NitrosSubscriber] Received a message but the application receiver's pointer is not yet set.
[component_container_mt-1] [INFO] [1698360487.115230498] [pointcloud_node]: [NitrosSubscriber] Received a message but the application receiver's pointer is not yet set.
[component_container_mt-1] [INFO] [1698360487.115345893] [disparity]: [NitrosSubscriber] Received a message but the application receiver's pointer is not yet set.
[component_container_mt-1] [INFO] [1698360487.121523286] [pointcloud_node]: [NitrosSubscriber] Received a message but the application receiver's pointer is not yet set.
[component_container_mt-1] [INFO] [1698360487.121727745] [disparity]: [NitrosSubscriber] Received a message but the application receiver's pointer is not yet set.
[component_container_mt-1] [INFO] [1698360487.121795598] [image_format_node_right]: [NitrosSubscriber] Received a message but the application receiver's pointer is not yet set.
[component_container_mt-1] [INFO] [1698360487.181662944] [pointcloud_node]: [NitrosSubscriber] Received a message but the application receiver's pointer is not yet set.
[component_container_mt-1] [INFO] [1698360487.181667859] [disparity]: [NitrosSubscriber] Received a message but the application receiver's pointer is not yet set.
[component_container_mt-1] [INFO] [1698360487.181893392] [image_format_node_left]: [NitrosSubscriber] Received a message but the application receiver's pointer is not yet set.
[component_container_mt-1] [INFO] [1698360487.189018213] [disparity]: [NitrosSubscriber] Received a message but the application receiver's pointer is not yet set.
[component_container_mt-1] [INFO] [1698360487.189050847] [pointcloud_node]: [NitrosSubscriber] Received a message but the application receiver's pointer is not yet set.
[component_container_mt-1] [INFO] [1698360487.189268197] [image_format_node_right]: [NitrosSubscriber] Received a message but the application receiver's pointer is not yet set.
[component_container_mt-1] [INFO] [1698360487.249215949] [pointcloud_node]: [NitrosSubscriber] Received a message but the application receiver's pointer is not yet set.
[component_container_mt-1] [INFO] [1698360487.249219283] [disparity]: [NitrosSubscriber] Received a message but the application receiver's pointer is not yet set.
[component_container_mt-1] [INFO] [1698360487.249479313] [image_format_node_left]: [NitrosSubscriber] Received a message but the application receiver's pointer is not yet set.
[component_container_mt-1] [INFO] [1698360487.255560479] [pointcloud_node]: [NitrosSubscriber] Received a message but the application receiver's pointer is not yet set.
[component_container_mt-1] [INFO] [1698360487.255567465] [disparity]: [NitrosSubscriber] Received a message but the application receiver's pointer is not yet set.
[component_container_mt-1] [INFO] [1698360487.256036901] [image_format_node_right]: [NitrosSubscriber] Received a message but the application receiver's pointer is not yet set.
[component_container_mt-1] [INFO] [1698360487.282266163] [disparity]: [NitrosSubscriber] Received a message but the application receiver's pointer is not yet set.
[component_container_mt-1] [INFO] [1698360487.282277246] [pointcloud_node]: [NitrosSubscriber] Received a message but the application receiver's pointer is not yet set.
[component_container_mt-1] [INFO] [1698360487.282473877] [image_format_node_left]: [NitrosSubscriber] Received a message but the application receiver's pointer is not yet set.
[component_container_mt-1] [INFO] [1698360487.314941404] [pointcloud_node]: [NitrosSubscriber] Received a message but the application receiver's pointer is not yet set.
[component_container_mt-1] [INFO] [1698360487.314942705] [disparity]: [NitrosSubscriber] Received a message but the application receiver's pointer is not yet set.
[component_container_mt-1] [INFO] [1698360487.315246022] [image_format_node_left]: [NitrosSubscriber] Received a message but the application receiver's pointer is not yet set.
[component_container_mt-1] [INFO] [1698360487.354899560] [pointcloud_node]: [NitrosSubscriber] Received a message but the application receiver's pointer is not yet set.
[component_container_mt-1] [INFO] [1698360487.354916213] [disparity]: [NitrosSubscriber] Received a message but the application receiver's pointer is not yet set.
[component_container_mt-1] [INFO] [1698360487.355257256] [image_format_node_right]: [NitrosSubscriber] Received a message but the application receiver's pointer is not yet set.
[component_container_mt-1] [INFO] [1698360487.381503985] [disparity]: [NitrosSubscriber] Received a message but the application receiver's pointer is not yet set.
[component_container_mt-1] [INFO] [1698360487.381565061] [pointcloud_node]: [NitrosSubscriber] Received a message but the application receiver's pointer is not yet set.
[component_container_mt-1] [INFO] [1698360487.381744373] [image_format_node_left]: [NitrosSubscriber] Received a message but the application receiver's pointer is not yet set.
[component_container_mt-1] [INFO] [1698360487.421683764] [disparity]: [NitrosSubscriber] Received a message but the application receiver's pointer is not yet set.
[component_container_mt-1] [INFO] [1698360487.421697164] [pointcloud_node]: [NitrosSubscriber] Received a message but the application receiver's pointer is not yet set.
[component_container_mt-1] [INFO] [1698360487.421807331] [image_format_node_right]: [NitrosSubscriber] Received a message but the application receiver's pointer is not yet set.
[component_container_mt-1] [INFO] [1698360487.448464480] [pointcloud_node]: [NitrosSubscriber] Received a message but the application receiver's pointer is not yet set.
[component_container_mt-1] [INFO] [1698360487.448484411] [disparity]: [NitrosSubscriber] Received a message but the application receiver's pointer is not yet set.
[component_container_mt-1] [INFO] [1698360487.448686168] [image_format_node_left]: [NitrosSubscriber] Received a message but the application receiver's pointer is not yet set.
[component_container_mt-1] [INFO] [1698360487.554851765] [disparity]: [NitrosSubscriber] Received a message but the application receiver's pointer is not yet set.
[component_container_mt-1] [INFO] [1698360487.554959216] [pointcloud_node]: [NitrosSubscriber] Received a message but the application receiver's pointer is not yet set.
[component_container_mt-1] [INFO] [1698360487.555351880] [image_format_node_right]: [NitrosSubscriber] Received a message but the application receiver's pointer is not yet set.
[component_container_mt-1] [INFO] [1698360487.581559761] [disparity]: [NitrosSubscriber] Received a message but the application receiver's pointer is not yet set.
[component_container_mt-1] [INFO] [1698360487.581692259] [pointcloud_node]: [NitrosSubscriber] Received a message but the application receiver's pointer is not yet set.
[component_container_mt-1] [INFO] [1698360487.581757029] [image_format_node_left]: [NitrosSubscriber] Received a message but the application receiver's pointer is not yet set.
[component_container_mt-1] [INFO] [1698360487.621437528] [pointcloud_node]: [NitrosSubscriber] Received a message but the application receiver's pointer is not yet set.
[component_container_mt-1] [INFO] [1698360487.621440121] [disparity]: [NitrosSubscriber] Received a message but the application receiver's pointer is not yet set.
[component_container_mt-1] [INFO] [1698360487.621563405] [image_format_node_right]: [NitrosSubscriber] Received a message but the application receiver's pointer is not yet set.
[component_container_mt-1] [INFO] [1698360487.648059321] [disparity]: [NitrosSubscriber] Received a message but the application receiver's pointer is not yet set.
[component_container_mt-1] [INFO] [1698360487.648156615] [pointcloud_node]: [NitrosSubscriber] Received a message but the application receiver's pointer is not yet set.
[component_container_mt-1] [INFO] [1698360487.648204753] [image_format_node_left]: [NitrosSubscriber] Received a message but the application receiver's pointer is not yet set.
[component_container_mt-1] [INFO] [1698360487.688570287] [pointcloud_node]: [NitrosSubscriber] Received a message but the application receiver's pointer is not yet set.
[component_container_mt-1] [INFO] [1698360487.688780543] [disparity]: [NitrosSubscriber] Received a message but the application receiver's pointer is not yet set.
[component_container_mt-1] [INFO] [1698360487.689026451] [image_format_node_right]: [NitrosSubscriber] Received a message but the application receiver's pointer is not yet set.
[component_container_mt-1] [INFO] [1698360487.714937827] [disparity]: [NitrosSubscriber] Received a message but the application receiver's pointer is not yet set.
[component_container_mt-1] [INFO] [1698360487.714940095] [pointcloud_node]: [NitrosSubscriber] Received a message but the application receiver's pointer is not yet set.
[component_container_mt-1] [INFO] [1698360487.715059594] [image_format_node_left]: [NitrosSubscriber] Received a message but the application receiver's pointer is not yet set.
[component_container_mt-1] [INFO] [1698360487.755267935] [disparity]: [NitrosSubscriber] Received a message but the application receiver's pointer is not yet set.
[component_container_mt-1] [INFO] [1698360487.755484846] [pointcloud_node]: [NitrosSubscriber] Received a message but the application receiver's pointer is not yet set.
[component_container_mt-1] [INFO] [1698360487.755572114] [image_format_node_right]: [NitrosSubscriber] Received a message but the application receiver's pointer is not yet set.
[component_container_mt-1] [INFO] [1698360487.781400836] [disparity]: [NitrosSubscriber] Received a message but the application receiver's pointer is not yet set.
[component_container_mt-1] [INFO] [1698360487.781423528] [pointcloud_node]: [NitrosSubscriber] Received a message but the application receiver's pointer is not yet set.
[component_container_mt-1] [INFO] [1698360487.781530072] [image_format_node_left]: [NitrosSubscriber] Received a message but the application receiver's pointer is not yet set.
[component_container_mt-1] [INFO] [1698360487.821701023] [disparity]: [NitrosSubscriber] Received a message but the application receiver's pointer is not yet set.
[component_container_mt-1] [INFO] [1698360487.821706085] [pointcloud_node]: [NitrosSubscriber] Received a message but the application receiver's pointer is not yet set.
[component_container_mt-1] [INFO] [1698360487.821872195] [image_format_node_right]: [NitrosSubscriber] Received a message but the application receiver's pointer is not yet set.
[component_container_mt-1] [INFO] [1698360487.824571172] [disparity]: [NitrosNode] Starting post negotiation setup
[component_container_mt-1] [INFO] [1698360487.824590545] [disparity]: [NitrosNode] Getting data format negotiation results
[component_container_mt-1] [INFO] [1698360487.824599936] [disparity]: [NitrosPublisher] Negotiation ended with no results
[component_container_mt-1] [INFO] [1698360487.824605113] [disparity]: [NitrosPublisher] Use only the compatible publisher: topic_name="/disparity", data_format="nitros_disparity_image_32FC1"
[component_container_mt-1] [INFO] [1698360487.824611381] [disparity]: [NitrosSubscriber] Use the negotiated data format: "nitros_image_rgb8"
[component_container_mt-1] [INFO] [1698360487.824617805] [disparity]: [NitrosSubscriber] Use the negotiated data format: "nitros_image_rgb8"
[component_container_mt-1] [INFO] [1698360487.824621574] [disparity]: [NitrosSubscriber] Negotiation ended with no results
[component_container_mt-1] [INFO] [1698360487.824624992] [disparity]: [NitrosSubscriber] Use the compatible subscriber: topic_name="/transformed/infra1/camera_info", data_format="nitros_camera_info"
[component_container_mt-1] [INFO] [1698360487.824638343] [disparity]: [NitrosSubscriber] Negotiation ended with no results
[component_container_mt-1] [INFO] [1698360487.824642091] [disparity]: [NitrosSubscriber] Use the compatible subscriber: topic_name="/transformed/infra2/camera_info", data_format="nitros_camera_info"
[component_container_mt-1] [INFO] [1698360487.824683761] [disparity]: [NitrosNode] Exporting the final graph based on the negotiation results
[component_container_mt-1] [INFO] [1698360487.848234430] [pointcloud_node]: [NitrosSubscriber] Received a message but the application receiver's pointer is not yet set.
[component_container_mt-1] [INFO] [1698360487.848781018] [image_format_node_left]: [NitrosSubscriber] Received a message but the application receiver's pointer is not yet set.
[component_container_mt-1] [INFO] [1698360487.866805319] [image_format_node_left]: [NitrosNode] Starting post negotiation setup
[component_container_mt-1] [INFO] [1698360487.866851506] [image_format_node_left]: [NitrosNode] Getting data format negotiation results
[component_container_mt-1] [INFO] [1698360487.866867075] [image_format_node_left]: [NitrosPublisher] Use the negotiated data format: "nitros_image_rgb8"
[component_container_mt-1] [INFO] [1698360487.866877828] [image_format_node_left]: [NitrosSubscriber] Negotiation ended with no results
[component_container_mt-1] [INFO] [1698360487.866885086] [image_format_node_left]: [NitrosSubscriber] Use the compatible subscriber: topic_name="/transformed/infra1/image_rect_raw", data_format="nitros_image_rgb8"
[component_container_mt-1] [INFO] [1698360487.866945554] [image_format_node_left]: [NitrosNode] Exporting the final graph based on the negotiation results
[component_container_mt-1] [INFO] [1698360487.872497423] [image_format_node_left]: [NitrosNode] Wrote the final top level YAML graph to "/workspaces/rm250_ros2/install/isaac_ros_image_proc/share/isaac_ros_image_proc/EBTHOPKXNC.yaml"
[component_container_mt-1] [INFO] [1698360487.872522453] [image_format_node_left]: [NitrosNode] Calling user's pre-load-graph callback
[component_container_mt-1] [INFO] [1698360487.872525521] [image_format_node_left]: [NitrosNode] Loading application
[component_container_mt-1] [INFO] [1698360487.872528919] [image_format_node_left]: [NitrosContext] Loading application: '/workspaces/rm250_ros2/install/isaac_ros_image_proc/share/isaac_ros_image_proc/EBTHOPKXNC.yaml'
[component_container_mt-1] [INFO] [1698360487.873534810] [image_format_node_left]: [NitrosNode] Linking Nitros pub/sub to the loaded application
[component_container_mt-1] [INFO] [1698360487.873577986] [image_format_node_left]: [NitrosNode] Calling user's post-load-graph callback
[component_container_mt-1] [INFO] [1698360487.873581966] [image_format_node_left]: [ImageFormatConverterNode] postLoadGraphCallback().
[component_container_mt-1] [INFO] [1698360487.873593520] [image_format_node_left]: [NitrosContext] Initializing application...
[component_container_mt-1] [INFO] [1698360487.883581395] [image_format_node_left]: [NitrosContext] Running application...
[component_container_mt-1] [INFO] [1698360487.883638843] [image_format_node_left]: [NitrosNode] Starting a heartbeat timer (eid=443)
[component_container_mt-1] [INFO] [1698360487.888678462] [disparity]: [NitrosNode] Wrote the final top level YAML graph to "/workspaces/rm250_ros2/install/isaac_ros_ess/share/isaac_ros_ess/JTETKUUUTW.yaml"
[component_container_mt-1] [INFO] [1698360487.888704199] [disparity]: [NitrosNode] Calling user's pre-load-graph callback
[component_container_mt-1] [INFO] [1698360487.888708196] [disparity]: [NitrosNode] Loading application
[component_container_mt-1] [INFO] [1698360487.888711684] [disparity]: [NitrosContext] Loading application: '/workspaces/rm250_ros2/install/isaac_ros_ess/share/isaac_ros_ess/JTETKUUUTW.yaml'
[component_container_mt-1] [INFO] [1698360487.888891506] [pointcloud_node]: [NitrosSubscriber] Received a message but the application receiver's pointer is not yet set.
[component_container_mt-1] [INFO] [1698360487.889149560] [image_format_node_right]: [NitrosSubscriber] Received a message but the application receiver's pointer is not yet set.
[component_container_mt-1] 2023-10-26 18:48:07.891 WARN  gxf/std/yaml_file_loader.cpp@1058: Using unregistered parameter 'left_image_input' in component ''.
[component_container_mt-1] 2023-10-26 18:48:07.891 WARN  gxf/std/yaml_file_loader.cpp@1058: Using unregistered parameter 'right_image_input' in component ''.
[component_container_mt-1] 2023-10-26 18:48:07.891 WARN  gxf/std/yaml_file_loader.cpp@1058: Using unregistered parameter 'left_cam_input' in component ''.
[component_container_mt-1] 2023-10-26 18:48:07.891 WARN  gxf/std/yaml_file_loader.cpp@1058: Using unregistered parameter 'right_cam_input' in component ''.
[component_container_mt-1] 2023-10-26 18:48:07.891 WARN  gxf/std/yaml_file_loader.cpp@1058: Using unregistered parameter 'left_image_output' in component ''.
[component_container_mt-1] 2023-10-26 18:48:07.891 WARN  gxf/std/yaml_file_loader.cpp@1058: Using unregistered parameter 'right_image_output' in component ''.
[component_container_mt-1] 2023-10-26 18:48:07.891 WARN  gxf/std/yaml_file_loader.cpp@1058: Using unregistered parameter 'left_cam_output' in component ''.
[component_container_mt-1] 2023-10-26 18:48:07.891 WARN  gxf/std/yaml_file_loader.cpp@1058: Using unregistered parameter 'right_cam_output' in component ''.
[component_container_mt-1] 2023-10-26 18:48:07.891 WARN  gxf/std/yaml_file_loader.cpp@1058: Using unregistered parameter 'output_adapter' in component ''.
[component_container_mt-1] [INFO] [1698360487.892251217] [disparity]: [NitrosNode] Linking Nitros pub/sub to the loaded application
[component_container_mt-1] [INFO] [1698360487.892334469] [disparity]: [NitrosNode] Calling user's post-load-graph callback
[component_container_mt-1] [INFO] [1698360487.892403916] [disparity]: [ESSDisparityNode] Setting engine_file_path: /workspaces/rm250_ros2/resources/ess_light.engine.
[component_container_mt-1] [INFO] [1698360487.892409010] [disparity]: [NitrosContext] Initializing application...
[component_container_mt-1] [INFO] [1698360487.897466215] [disparity]: [NitrosContext] Running application...
[component_container_mt-1] [INFO] [1698360487.897650593] [disparity]: [NitrosNode] Starting a heartbeat timer (eid=479)
[component_container_mt-1] [INFO] [1698360487.908880931] [image_format_node_right]: [NitrosNode] Starting post negotiation setup
[component_container_mt-1] [INFO] [1698360487.908916551] [image_format_node_right]: [NitrosNode] Getting data format negotiation results
[component_container_mt-1] [INFO] [1698360487.908929160] [image_format_node_right]: [NitrosPublisher] Use the negotiated data format: "nitros_image_rgb8"
[component_container_mt-1] [INFO] [1698360487.908940824] [image_format_node_right]: [NitrosSubscriber] Negotiation ended with no results
[component_container_mt-1] [INFO] [1698360487.908949032] [image_format_node_right]: [NitrosSubscriber] Use the compatible subscriber: topic_name="/transformed/infra2/image_rect_raw", data_format="nitros_image_rgb8"
[component_container_mt-1] [INFO] [1698360487.908985370] [image_format_node_right]: [NitrosNode] Exporting the final graph based on the negotiation results
[component_container_mt-1] [INFO] [1698360487.914849321] [pointcloud_node]: [NitrosSubscriber] Received a message but the application receiver's pointer is not yet set.
[component_container_mt-1] [INFO] [1698360487.919051567] [image_format_node_right]: [NitrosNode] Wrote the final top level YAML graph to "/workspaces/rm250_ros2/install/isaac_ros_image_proc/share/isaac_ros_image_proc/JBPEKOCDDV.yaml"
[component_container_mt-1] [INFO] [1698360487.919088432] [image_format_node_right]: [NitrosNode] Calling user's pre-load-graph callback
[component_container_mt-1] [INFO] [1698360487.919097015] [image_format_node_right]: [NitrosNode] Loading application
[component_container_mt-1] [INFO] [1698360487.919116962] [image_format_node_right]: [NitrosContext] Loading application: '/workspaces/rm250_ros2/install/isaac_ros_image_proc/share/isaac_ros_image_proc/JBPEKOCDDV.yaml'
[component_container_mt-1] [INFO] [1698360487.920028678] [image_format_node_right]: [NitrosNode] Linking Nitros pub/sub to the loaded application
[component_container_mt-1] [INFO] [1698360487.920077987] [image_format_node_right]: [NitrosNode] Calling user's post-load-graph callback
[component_container_mt-1] [INFO] [1698360487.920087813] [image_format_node_right]: [ImageFormatConverterNode] postLoadGraphCallback().
[component_container_mt-1] [INFO] [1698360487.920098129] [image_format_node_right]: [NitrosContext] Initializing application...
[component_container_mt-1] [INFO] [1698360487.921916292] [pointcloud_node]: [NitrosSubscriber] Received a message but the application receiver's pointer is not yet set.
[component_container_mt-1] [INFO] [1698360487.926863570] [image_format_node_right]: [NitrosContext] Running application...
[component_container_mt-1] [INFO] [1698360487.926939282] [image_format_node_right]: [NitrosNode] Starting a heartbeat timer (eid=585)
[component_container_mt-1] [INFO] [1698360487.957823599] [pointcloud_node]: [NitrosSubscriber] Received a message but the application receiver's pointer is not yet set.
[component_container_mt-1] [INFO] [1698360487.965473204] [pointcloud_node]: [NitrosNode] Starting post negotiation setup
[component_container_mt-1] [INFO] [1698360487.965518211] [pointcloud_node]: [NitrosNode] Getting data format negotiation results
[component_container_mt-1] [INFO] [1698360487.965529152] [pointcloud_node]: [NitrosPublisher] Negotiation ended with no results
[component_container_mt-1] [INFO] [1698360487.965538414] [pointcloud_node]: [NitrosPublisher] Use only the compatible publisher: topic_name="/points2", data_format="nitros_point_cloud"
[component_container_mt-1] [INFO] [1698360487.965547211] [pointcloud_node]: [NitrosSubscriber] Negotiation ended with no results
[component_container_mt-1] [INFO] [1698360487.965554385] [pointcloud_node]: [NitrosSubscriber] Use the compatible subscriber: topic_name="/disparity", data_format="nitros_disparity_image_32FC1"
[component_container_mt-1] [INFO] [1698360487.965562176] [pointcloud_node]: [NitrosSubscriber] Negotiation ended with no results
[component_container_mt-1] [INFO] [1698360487.965568513] [pointcloud_node]: [NitrosSubscriber] Use the compatible subscriber: topic_name="/infra1/image_rect_raw", data_format="nitros_image_bgr8"
[component_container_mt-1] [INFO] [1698360487.965575517] [pointcloud_node]: [NitrosSubscriber] Negotiation ended with no results
[component_container_mt-1] [INFO] [1698360487.965582224] [pointcloud_node]: [NitrosSubscriber] Use the compatible subscriber: topic_name="/transformed/infra1/camera_info", data_format="nitros_camera_info"
[component_container_mt-1] [INFO] [1698360487.965597525] [pointcloud_node]: [NitrosSubscriber] Negotiation ended with no results
[component_container_mt-1] [INFO] [1698360487.965603980] [pointcloud_node]: [NitrosSubscriber] Use the compatible subscriber: topic_name="/transformed/infra2/camera_info", data_format="nitros_camera_info"
[component_container_mt-1] [INFO] [1698360487.965627210] [pointcloud_node]: [NitrosNode] Exporting the final graph based on the negotiation results
[component_container_mt-1] [INFO] [1698360487.994532107] [pointcloud_node]: [NitrosNode] Wrote the final top level YAML graph to "/workspaces/rm250_ros2/install/isaac_ros_stereo_image_proc/share/isaac_ros_stereo_image_proc/AXFMYWYCFH.yaml"
[component_container_mt-1] [INFO] [1698360487.994571515] [pointcloud_node]: [NitrosNode] Calling user's pre-load-graph callback
[component_container_mt-1] [INFO] [1698360487.994579381] [pointcloud_node]: [PointCloudNode] preLoadGraphCallback().
[component_container_mt-1] [INFO] [1698360487.994597477] [pointcloud_node]: [NitrosNode] Loading application
[component_container_mt-1] [INFO] [1698360487.994601249] [pointcloud_node]: [NitrosContext] Loading application: '/workspaces/rm250_ros2/install/isaac_ros_stereo_image_proc/share/isaac_ros_stereo_image_proc/AXFMYWYCFH.yaml'
[component_container_mt-1] [INFO] [1698360487.996383230] [pointcloud_node]: [NitrosNode] Linking Nitros pub/sub to the loaded application
[component_container_mt-1] [INFO] [1698360487.996436607] [pointcloud_node]: [NitrosNode] Calling user's post-load-graph callback
[component_container_mt-1] [INFO] [1698360487.996464079] [pointcloud_node]: [NitrosContext] Initializing application...
[component_container_mt-1] [INFO] [1698360488.001088666] [pointcloud_node]: [NitrosContext] Running application...
[component_container_mt-1] [INFO] [1698360488.001256600] [pointcloud_node]: [NitrosNode] Starting a heartbeat timer (eid=645)
Launch file:
import os
from ament_index_python.packages import get_package_share_directory
import launch
from launch.actions import DeclareLaunchArgument
from launch.substitutions import LaunchConfiguration
from launch_ros.actions import ComposableNodeContainer, Node
from launch_ros.descriptions import ComposableNode
def generate_launch_description():
    launch_args = [
        DeclareLaunchArgument(
            'engine_file_path',
            default_value='/workspaces/rm250_ros2/resources/ess_light.engine',
            description='The absolute path to the ESS engine plan.'),
            'threshold',
            default_value='0.0',
            description='Threshold value ranges between 0.0 and 1.0 '
                        'for filtering disparity with confidence.'),
    engine_file_path = LaunchConfiguration('engine_file_path')
    threshold = LaunchConfiguration('threshold')
    disparity_node = ComposableNode(
        name='disparity',
        package='isaac_ros_ess',
        plugin='nvidia::isaac_ros::dnn_stereo_depth::ESSDisparityNode',
        parameters=[{'engine_file_path': engine_file_path,
                     'threshold': threshold}],
        remappings=[
            ('left/camera_info', '/transformed/infra1/camera_info'),
            ('left/image_rect', 'infra1/image_rect_raw'),
            ('right/camera_info', '/transformed/infra2/camera_info'),
            ('right/image_rect', 'infra2/image_rect_raw')
    image_format_converter_node_left = ComposableNode(
        package='isaac_ros_image_proc',
        plugin='nvidia::isaac_ros::image_proc::ImageFormatConverterNode',
        name='image_format_node_left',
        parameters=[{
                'encoding_desired': 'rgb8',
        remappings=[
            ('image_raw', '/transformed/infra1/image_rect_raw'),
            ('image', 'infra1/image_rect_raw')]
    image_format_converter_node_right = ComposableNode(
        name='image_format_node_right',
        parameters=[{
        remappings=[
            ('image_raw', '/transformed/infra2/image_rect_raw'),
            ('image', 'infra2/image_rect_raw')]
    pointcloud_node = ComposableNode(
        name='pointcloud_node',
        package='isaac_ros_stereo_image_proc',
        plugin='nvidia::isaac_ros::stereo_image_proc::PointCloudNode',
        parameters=[{
                'use_color': True,
                'unit_scaling': 1.0
        remappings=[('left/image_rect_color', 'infra1/image_rect_raw'),
                    ('right/camera_info', '/transformed/infra2/camera_info')]
    node_descriptions = [disparity_node,
                        image_format_converter_node_left,
                        image_format_converter_node_right,
                        pointcloud_node]
    container = ComposableNodeContainer(
        name='disparity_container',
        namespace='disparity',
        package='rclcpp_components',
        executable='component_container_mt',
        composable_node_descriptions=node_descriptions,
        output='screen',
        arguments=['--ros-args', '--log-level', 'info']
    rviz_config_path = os.path.join(get_package_share_directory(
        'vision_pipeline'), 'rviz', 'isaac_ros_ess_realsense.rviz')
    rviz = Node(
        package='rviz2',
        executable='rviz2',
        arguments=['-d', rviz_config_path],
        output='screen')
    pointcloud_filter = Node(
        package="vision_pipeline",
        executable="filter_pointcloud",
        output="log"
    return (launch.LaunchDescription(launch_args + [container, rviz, pointcloud_filter]))
Hi @vishrut1 ,
Welcome here, and I apologize for this delay.
I think you need to run two disparity nodes, one for each camera since you are using two realsense (looking at the other post linked).
Also, remap all topics from both cameras.
Let me know if I help you.
Best,
Raffaello
