ISAAC ros failure to sudo apt-get update --fix-missing
Im trying to use isaac ros Nvblox and I followed the tutorial below
But when I run sudo apt-get update --fix-missing
I got the following error
Hit:1 http://packages.ros.org/ros2/ubuntu jammy InRelease
Hit:2 https://deb.nodesource.com/node_18.x nodistro InRelease
Hit:3 https://dl.yarnpkg.com/debian stable InRelease
Hit:5 https://ppa.launchpadcontent.net/mosquitto-dev/mosquitto-ppa/ubuntu jammy InRelease
Hit:6 https://repo.download.nvidia.com/jetson/common r36.4 InRelease
Hit:7 http://ports.ubuntu.com/ubuntu-ports jammy InRelease
Get:8 http://ports.ubuntu.com/ubuntu-ports jammy-updates InRelease [128 kB]
Hit:9 https://developer.download.nvidia.com/compute/cuda/repos/ubuntu2204/arm64  InRelease
Get:4 https://isaac.download.nvidia.cn/isaac-ros/release-3 jammy InRelease [12.7 kB]
Hit:10 http://ports.ubuntu.com/ubuntu-ports jammy-backports InRelease
Get:11 http://ports.ubuntu.com/ubuntu-ports jammy-security InRelease [129 kB]
Hit:12 https://repo.download.nvidia.com/jetson/t234 r36.4 InRelease
Fetched 270 kB in 12s (22.0 kB/s)
Reading package lists... Done
W: https://dl.yarnpkg.com/debian/dists/stable/InRelease: Key is stored in legacy trusted.gpg keyring (/etc/apt/trusted.gpg), see the DEPRECATION section in apt-key(8) for details.
W: https://repo.download.nvidia.com/jetson/common/dists/r36.4/InRelease: Key is stored in legacy trusted.gpg keyring (/etc/apt/trusted.gpg), see the DEPRECATION section in apt-key(8) for details.
W: https://isaac.download.nvidia.com/isaac-ros/release-3/dists/jammy/InRelease: Key is stored in legacy trusted.gpg keyring (/etc/apt/trusted.gpg), see the DEPRECATION section in apt-key(8) for details.
W: Skipping acquire of configured file 'universe/binary-arm64/Packages' as repository 'https://isaac.download.nvidia.com/isaac-ros/release-3 jammy InRelease' doesn't have the component 'universe' (component misspelt in sources.list?)
W: https://repo.download.nvidia.com/jetson/t234/dists/r36.4/InRelease: Key is stored in legacy trusted.gpg keyring (/etc/apt/trusted.gpg), see the DEPRECATION section in apt-key(8) for details.
Then I tried rosdep update && rosdep install -i -r --from-paths ${ISAAC_ROS_WS}/src/isaac_ros_nvblox/ --rosdistro humble -y
And I got the following error
reading in sources list data from /etc/ros/rosdep/sources.list.d
Hit file:///etc/ros/rosdep/sources.list.d/nvidia-isaac.yaml
Hit https://raw.githubusercontent.com/ros/rosdistro/master/rosdep/osx-homebrew.yaml
Hit https://raw.githubusercontent.com/ros/rosdistro/master/rosdep/base.yaml
Hit https://raw.githubusercontent.com/ros/rosdistro/master/rosdep/python.yaml
Hit https://raw.githubusercontent.com/ros/rosdistro/master/rosdep/ruby.yaml
Hit https://raw.githubusercontent.com/ros/rosdistro/master/releases/fuerte.yaml
Query rosdistro index https://raw.githubusercontent.com/ros/rosdistro/master/index-v4.yaml
Skip end-of-life distro "ardent"
Skip end-of-life distro "bouncy"
Skip end-of-life distro "crystal"
Skip end-of-life distro "dashing"
Skip end-of-life distro "eloquent"
Skip end-of-life distro "foxy"
Skip end-of-life distro "galactic"
Skip end-of-life distro "groovy"
Add distro "humble"
Skip end-of-life distro "hydro"
Skip end-of-life distro "indigo"
Skip end-of-life distro "iron"
Skip end-of-life distro "jade"
Add distro "jazzy"
Add distro "kilted"
Skip end-of-life distro "kinetic"
Skip end-of-life distro "lunar"
Skip end-of-life distro "melodic"
Add distro "noetic"
Add distro "rolling"
updated cache in /home/admin/.ros/rosdep/sources.cache
executing command [sudo -H apt-get install -y ros-humble-isaac-ros-peoplenet-models-install]
Building dependency tree... Done
Reading state information... Done
The following additional packages will be installed:
  ros-humble-gxf-isaac-detectnet ros-humble-isaac-ros-detectnet
  ros-humble-isaac-ros-nitros-detection2-d-array-type
The following NEW packages will be installed:
0 upgraded, 4 newly installed, 0 to remove and 76 not upgraded.
Need to get 329 kB of archives.
After this operation, 2,173 kB of additional disk space will be used.
Get:1 https://isaac.download.nvidia.cn/isaac-ros/release-3 jammy/release-3.0 arm64 ros-humble-isaac-ros-nitros-detection2-d-array-type arm64 3.2.5-0jammy [40.7 kB]
Err:1 https://isaac.download.nvidia.cn/isaac-ros/release-3 jammy/release-3.0 arm64 ros-humble-isaac-ros-nitros-detection2-d-array-type arm64 3.2.5-0jammy
  File has unexpected size (40452 != 40686). Mirror sync in progress? [IP: 111.51.158.56 443]
  Hashes of expected file:
   - SHA256:397218656969017d0919a47870aace670d7ee9df001f91983923b9cdf71902e7
   - SHA1:b1a1500491a3265e5ba120d8011ee8b3c6567741 [weak]
   - Filesize:40686 [weak]
Get:2 https://isaac.download.nvidia.cn/isaac-ros/release-3 jammy/release-3.0 arm64 ros-humble-gxf-isaac-detectnet arm64 3.2.5-0jammy [65.6 kB]
Get:3 https://isaac.download.nvidia.cn/isaac-ros/release-3 jammy/release-3.0 arm64 ros-humble-isaac-ros-detectnet arm64 3.2.5-0jammy [214 kB]
Get:4 https://isaac.download.nvidia.cn/isaac-ros/release-3 jammy/release-3.0 arm64 ros-humble-isaac-ros-peoplenet-models-install arm64 3.2.5-0jammy [8,690 B]
Fetched 288 kB in 13s (21.4 kB/s)
E: Failed to fetch https://isaac.download.nvidia.cn/isaac-ros/release-3/pool/release-3.2/ros-humble-isaac-ros-nitros-detection2-d-array-type-arm64.deb  File has unexpected size (40452 != 40686). Mirror sync in progress? [IP: 111.51.158.56 443]
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
executing command [sudo -H apt-get install -y ros-humble-isaac-ros-visual-slam]
0 upgraded, 1 newly installed, 0 to remove and 76 not upgraded.
Need to get 2,402 kB of archives.
After this operation, 8,165 kB of additional disk space will be used.
Get:1 https://isaac.download.nvidia.cn/isaac-ros/release-3 jammy/release-3.0 arm64 ros-humble-isaac-ros-visual-slam arm64 3.2.6-0jammy [2,402 kB]
Fetched 2,402 kB in 7s (349 kB/s)
debconf: unable to initialize frontend: Dialog
debconf: (No usable dialog-like program is installed, so the dialog based frontend cannot be used. at /usr/share/perl5/Debconf/FrontEnd/Dialog.pm line 78, <> line 1.)
debconf: falling back to frontend: Readline
Selecting previously unselected package ros-humble-isaac-ros-visual-slam.
(Reading database ... 173550 files and directories currently installed.)
Preparing to unpack .../ros-humble-isaac-ros-visual-slam_3.2.6-0jammy_arm64.deb ...
Unpacking ros-humble-isaac-ros-visual-slam (3.2.6-0jammy) ...
Setting up ros-humble-isaac-ros-visual-slam (3.2.6-0jammy) ...
executing command [sudo -H apt-get install -y ros-humble-isaac-ros-detectnet]
0 upgraded, 3 newly installed, 0 to remove and 76 not upgraded.
Need to get 320 kB of archives.
After this operation, 2,116 kB of additional disk space will be used.
Fetched 320 kB in 7s (43.6 kB/s)
debconf: (No usable dialog-like program is installed, so the dialog based frontend cannot be used. at /usr/share/perl5/Debconf/FrontEnd/Dialog.pm line 78, <> line 3.)
Selecting previously unselected package ros-humble-isaac-ros-nitros-detection2-d-array-type.
(Reading database ... 173612 files and directories currently installed.)
Preparing to unpack .../ros-humble-isaac-ros-nitros-detection2-d-array-type_3.2.5-0jammy_arm64.deb ...
Unpacking ros-humble-isaac-ros-nitros-detection2-d-array-type (3.2.5-0jammy) ...
Selecting previously unselected package ros-humble-gxf-isaac-detectnet.
Preparing to unpack .../ros-humble-gxf-isaac-detectnet_3.2.5-0jammy_arm64.deb ...
Unpacking ros-humble-gxf-isaac-detectnet (3.2.5-0jammy) ...
Selecting previously unselected package ros-humble-isaac-ros-detectnet.
Preparing to unpack .../ros-humble-isaac-ros-detectnet_3.2.5-0jammy_arm64.deb ...
Unpacking ros-humble-isaac-ros-detectnet (3.2.5-0jammy) ...
Setting up ros-humble-isaac-ros-nitros-detection2-d-array-type (3.2.5-0jammy) ...
Setting up ros-humble-gxf-isaac-detectnet (3.2.5-0jammy) ...
Setting up ros-humble-isaac-ros-detectnet (3.2.5-0jammy) ...
ERROR: the following rosdeps failed to install
  apt: command [sudo -H apt-get install -y ros-humble-isaac-ros-peoplenet-models-install] failed
  apt: Failed to detect successful installation of [ros-humble-isaac-ros-peoplenet-models-install]
Any help is greatly appreciated,I stucked for two days
Hi @1098924007
Thank you for your post.
Could you check if your CDN is set correctly based on your location?
Best,
Ahung
