Hi, I am currently testing this example from the Isaac ROS Mission Client documentation:
I am using Mission Dispatch to send a mission to carter01 in Isaac Sim, but the robot does not move.
Environment
Ubuntu 22.04
Isaac ROS version: 3.2
isaac sim 4.5
Mission Dispatch behavior
Mission Dispatch successfully creates the robot and sends the mission:
[Isaac Mission Dispatch] | INFO: [carter01] Received a new mission [simple_mission_example]
[Isaac Mission Dispatch] | INFO: [carter01] Created robot
[Isaac Mission Dispatch] | INFO: [carter01] Mission state: PENDING -> RUNNING
[Isaac Mission Dispatch] | INFO: [carter01] Sending mission route node goto_pickup
After some time, it reports:
[Isaac Mission Dispatch] | INFO: [carter01] Robot Offline
[Isaac Mission Dispatch] | INFO: [carter01] [Mission ID - simple_mission_example] Mission state: RUNNING -> FAILED
[Isaac Mission Dispatch] | INFO: [carter01] [Mission ID - simple_mission_example] Mission failed at 2026-02-20 14:02:21.294507
[Isaac Mission Dispatch] | INFO: [carter01] [Mission ID - simple_mission_example] Failure reason: Mission timed out
[Isaac Mission Dispatch] | INFO: [carter01] [Mission ID - simple_mission_example] Mission duration: 0:05:00.116421
[Isaac Mission Dispatch] | INFO: [carter01] Robot state: RobotStateV1.ON_TASK -> RobotStateV1.IDLE
Mission Client launch
On the Mission Client machine, I run:
ros2 launch isaac_ros_vda5050_nav2_client_bringup isaac_ros_vda5050_nav2_client.launch.py init_pose_x:=-2.0 init_pose_yaw:=3.14159
The launch starts successfully without errors.
Mission Client receives mission
When assigning the mission via API, the Mission Client shows:
[mqtt_to_ros_bridge_node-15] [INFO] [1771595841.178770886] [mqtt_ros_bridge_node]: From uagv/v2/RobotCompany/carter01/instantActions: b'{"headerId": 0, "timestamp": "2026-02-20T13:57:21.176975", "version": "2.0.0", "manufacturer": "", "serialNumber": "", "instantActions": [{"actionType": "factsheetRequest", "actionId": "instantaction-n0", "blockingType": "HARD", "actionParameters": [], "actionDescription": ""}]}'
[mqtt_to_ros_bridge_node-15] [INFO] [1771595841.219978427] [mqtt_ros_bridge_node]: From uagv/v2/RobotCompany/carter01/order: b'{"headerId": 1, "timestamp": "2026-02-20T13:57:21.193071", "version": "2.0.0", "manufacturer": "", "serialNumber": "", "orderId": "simple_mission_example-n0", "orderUpdateId": 0, "nodes": [{"nodeId": "simple_mission_example-n0-s0", "sequenceId": 0, "released": true, "nodePosition": {"x": 0.0, "y": 0.0, "theta": 0.0, "mapId": "", "mapDescription": "", "allowedDeviationXY": 0.0, "allowedDeviationTheta": 0.0}, "actions": [], "nodeDescription": ""}, {"nodeId": "simple_mission_example-n0-s2", "sequenceId": 2, "released": true, "nodePosition": {"x": 1.5, "y": 1.5, "theta": 0.0, "mapId": "map", "mapDescription": "", "allowedDeviationXY": 0.1, "allowedDeviationTheta": 0.0}, "actions": [], "nodeDescription": ""}, {"nodeId": "simple_mission_example-n0-s4", "sequenceId": 4, "released": true, "nodePosition": {"x": 3.3, "y": 2.1, "theta": 0.0, "mapId": "map", "mapDescription": "", "allowedDeviationXY": 0.1, "allowedDeviationTheta": 0.0}, "actions": [], "nodeDescription": ""}], "edges": [{"edgeId": "simple_mission_example-e1", "sequenceId": 1, "edgeDescription": "", "released": true, "startNodeId": "simple_mission_example-n0-s0", "endNodeId": "simple_mission_example-n0-s2", "actions": []}, {"edgeId": "simple_mission_example-e3", "sequenceId": 3, "edgeDescription": "", "released": true, "startNodeId": "simple_mission_example-n0-s2", "endNodeId": "simple_mission_example-n0-s4", "actions": []}]}'
Isaac Sim console occasionally shows:
2026-02-20 14:21:41 [3,752,416ms] [Warning] [omni.graph.core.plugin] /World/Nova_Carter_ROS/differential_drive/differential_controller_01: [/World/Nova_Carter_ROS/differential_drive] invalid dt 0.000000, cannot check for acceleration limits, skipping current step
I followed the tutorial steps and configured the Sample Scene in Isaac Sim under (ROS2 → Isaac ROS → Sample Scene)
There were no error messages when running the launch commands. However, the Nova_Carter_ROS robot in the Isaac Sim scene does not move after the mission is assigned. It seems that the mission is being received correctly, but the robot does not respond to the commands.
Thank you for your help.
