I am trying to use Livox Lidar Mid-360 as the Lidar input to the Isaac ROS Map Localization. I am publishing the standard sensor_msgs::msg::PointCloud2 which the isaac_ros_pointcloud_utils subscribed to. However, I got the following output
[component_container_mt-1] [INFO] [1719874595.506810742] [pointcloud_to_flatscan]: [NitrosNode] Node was started
[component_container_mt-1] [ERROR] [1719874626.688948635] [NitrosPointCloud]: [convert_to_custom] cudaMemcpy failed for copying data from sensor_msgs::msg::PointCloud2 to NitrosPointCloud: cudaErrorInvalidValue (invalid argument)
[component_container_mt-1] terminate called after throwing an instance of 'std::runtime_error'
[component_container_mt-1] what(): [convert_to_custom] cudaMemcpy failed for copying data from sensor_msgs::msg::PointCloud2 to NitrosPointCloud: cudaErrorInvalidValue (invalid argument)
[ERROR] [component_container_mt-1]: process has died [pid 359160, exit code -6, cmd '/opt/ros/humble/lib/rclcpp_components/component_container_mt --ros-args -r __node:=pointcloud_to_flatscan_container -r __ns:=/'].
Thank you for your response. I am able to use the rviz2 and visualize both the Lidar and the Localizer solely on their own, but when I tried to launch publish the Lidar data and subscribe using ros2 launch isaac_ros_pointcloud_utils isaac_ros_pointcloud_to_flatscan.launch.py, the error shows up. A information of the topic is shown here:
in which there is a publisher and subscription to this pointcloud topic. If I am not doing this correctly, it will be extremely helpful if you could provide some instructions! Thank you!!
Thank you for your post. It is helpful to figure out the reason for this crash. Which NVIDIA Jetson are you using?
It looks like there is not enough space on your Jetson, but I don’t have enough information to confirm my hypothesis.
You can utilize Isaac ROS nvblox to create a new map for Isaac ROS map localization. If you already have a map, you can convert it to a bitmap and add a yml file with all related configurations.
You can use this documentation like a reference map_server - ROS Wiki
