Isaac_ros_visual_slam ros2 action cannot use
I follow the following picture step,but the output in my jetson orin nano is “The passed action type is invalid”
And I use “ros2 action list”,there is empty,can someone help me to solve this?
Hi @anderson900724
Thank you for your post, can you please share also the output from your Jetson Nano?
Best,
Raffaello
The output like this,I use the rviz2 that i create myself.
I’m using the Realsense d435i.
I follow this turtorial.
Where can I set the " enable_localization_n_mapping = true ."
hi @Raffaello I forget to use reply. I’m so sorry about that.
