Dont know how this is possible, but i used the save_map action after i created a kind of bigger map.
Unfortunatly I choose for destination my workspaces folder. In that was the isaac_ros-dev folder.
It succeeded saving the map, but completly wiped the issac_ros-dev folder, also not a map. 0 Bytes.
Container was still running, but i was on battery and had to stop it. So currently all is gone. All migrated ros packages within there which took my days to get to run on ros2, docker files, etc…
I don´t think I can get this stuff back. Be carefull with the destination for save_map action and always BackUp!
