While installing dependencies on the Desktop using dependencies script , i am getting this error , requirement.txt file in /engine/build
ERROR: Could not find a version that satisfies the requirement tensorflow-gpu==1.15.0 (from -r engine/build/scripts/requirements.txt (line 1)) (from versions: 2.2.0rc1, 2.2.0rc2, 2.2.0rc3, 2.2.0rc4, 2.2.0, 2.2.1, 2.3.0rc0, 2.3.0rc1, 2.3.0rc2, 2.3.0, 2.3.1)
ERROR: No matching distribution found for tensorflow-gpu==1.15.0 (from -r engine/build/scripts/requirements.txt (line 1))
Does this have anything to do with my CUDA version ? Any leads wil be appreciated.
@Ish
You are using the wrong Python version.
As you can read here: https://www.tensorflow.org/install/pip, tensorflow(-gpu)<=1.15.0 only run on Python 3.5-3.7. And Python 3.8 requires tensorflow>=2.2.0.
So my best guess is, you are using Python 3.8 and not 3.7.
If your systems requires Python 3.8, try using a virtual environment for Python.
