I’m really new to this field I try to install Isaac sdk 2020.2 on my computer which runs ubuntu 18.04. According to the document 2020.2, I should install dependencies on the desktop following the command bob@desktop:~/isaac/engine/$ ./engine/build/scripts/install_dependencies.sh. However, I could not find install_dependencies.sh. Could anyone let me know how to install sdk or how I should start? Thank you.
The script is in <ISAAC_SDK-2020.2>/engine/engine/build/scripts/install_dependencies.sh
. The path in the setup document appears to be right (your working directory is <ISAAC_SDK-2020.2>/engine
, so perhaps you missed a directory level?
The install_dependencies.sh
installs of the required system libraries so you can build Isaac SDK apps. You can use the <ISAAC_SDK-2020.2>/engine/engine/build/build/create_image.sh
to create a Docker image in which it executes install_dependencies.sh
and develop within the container as well.
Hi, this may be slightly silly but in the Getting Started page, would you mind making this more clear? I feel like a fool searching for solutions for this for several days when it was that obvious.
e.g.
to:
bob@desktop:cd ./isaac/engine
