Hello.
I am following the “Running Inference in Simulation” Jetbot sample application in Jupyter Notebook with Isaac SDK 2021.1 + Isaac Sim on an Ubuntu 18.04 workstation. I keep running into the following error when attempting to use the inference model:
"TRT ERROR: ../rtSafe/cuda/caskUtils.cpp (98) - Assertion Error in trtSmToCask: 0 (Unsupported SM.)"
Here are a few more console lines from when I start the Isaac SDK app until the error:
2021-07-09 14:05:29.295 WARN external/com_nvidia_isaac_engine/engine/alice/backend/codelet_canister.cpp@229: Codelet '_engine_tcp_udp_asio_context/isaac.alice.AsioContext' was not added to scheduler because no tick method is specified.
2021-07-09 14:05:29.295 INFO packages/sight/WebsightServer.cpp@247: Sight webserver is loaded
2021-07-09 14:05:29.295 INFO packages/sight/WebsightServer.cpp@248: Please open Chrome Browser and navigate to http://<ip address>:3000
2021-07-09 14:05:29.295 WARN external/com_nvidia_isaac_engine/engine/alice/backend/codelet_canister.cpp@229: Codelet 'websight/isaac.sight.AliceSight' was not added to scheduler because no tick method is specified.
2021-07-09 14:05:29.295 WARN external/com_nvidia_isaac_engine/engine/alice/components/Codelet.cpp@53: Function deprecated. Set tick_period to the desired tick parameter
2021-07-09 14:05:29.359 WARN external/com_nvidia_isaac_engine/engine/alice/backend/codelet_canister.cpp@229: Codelet '_check_operating_system/isaac.alice.CheckOperatingSystem' was not added to scheduler because no tick method is specified.
2021-07-09 14:05:29.359 WARN external/com_nvidia_isaac_engine/engine/alice/components/Codelet.cpp@53: Function deprecated. Set tick_period to the desired tick parameter
2021-07-09 14:05:29.359 WARN packages/ml/TensorRTInference.cpp@463: Could not read from .plan (path is set to 'external/jetbot_ball_detection_resnet_model/jetbot_ball_detection_resnet18.plan'). Falling back to building the .plan from frozen model external/jetbot_ball_detection_resnet_model/jetbot_ball_detection_resnet18.etlt. Note: this process may take up to several minutes.
2021-07-09 14:05:32.248 INFO packages/sight/WebsightServer.cpp@117: Server connected / 1
2021-07-09 14:05:39.289 INFO external/com_nvidia_isaac_engine/engine/alice/backend/allocator_backend.cpp@57: Optimized memory CPU allocator.
2021-07-09 14:05:39.289 INFO external/com_nvidia_isaac_engine/engine/alice/backend/allocator_backend.cpp@66: Optimized memory CUDA allocator.
[I 14:06:31.611 NotebookApp] Saving file at /jetbot_notebook.ipynb
2021-07-09 14:07:10.991 WARN packages/ml/TensorRTInference.cpp@174: TRT WARNING: Half2 support requested on hardware without native FP16 support, performance will be negatively affected.
2021-07-09 14:09:28.756 ERROR packages/ml/TensorRTInference.cpp@171: TRT ERROR: ../rtSafe/cuda/caskUtils.cpp (98) - Assertion Error in trtSmToCask: 0 (Unsupported SM.)
2021-07-09 14:09:28.756 PANIC packages/ml/TensorRTInference.cpp@258: Failed to build TensorRT engine from external/jetbot_ball_detection_resnet_model/jetbot_ball_detection_resnet18.etlt.
| Isaac application terminated unexpectedly |
Running nvidia-smi
on the workstation, I can see that the card is recognized:
| NVIDIA-SMI 470.42.01 Driver Version: 470.42.01 CUDA Version: 11.4 |
| | | MIG M. |
| 0 NVIDIA RTX A6000 On | 00000000:01:00.0 On | Off |
| 61% 84C P2 203W / 300W | 4190MiB / 48662MiB | 75% Default |
| | | N/A |
Running nvcc --version
I can see that the correct CUDA version is linked:
Copyright (c) 2005-2019 NVIDIA Corporation
Built on Wed_Oct_23_19:24:38_PDT_2019
Cuda compilation tools, release 10.2, V10.2.89
And, running python3 .../isaac/engine/engine/build/scripts/version_checker.py
script gives that all dependencies are properly fulfilled (I think the TRT v7.1.5 is a typo since Isaac SDK uses TRT v7.1.3 and there is no TRT v7.1.5):
|Package |Recommended Version |Current Version |
|OS |Ubuntu 18.04.2 LTS |Ubuntu 18.04.5 LTS |
|Bazel |3.1.0 |3.1.0 |
|GPU_Driver |>=440 |470.42.01 |
|Cuda |10.2.x |10.2.89 |
|Cudnn |8.0.3.x |8.0.3.33 |
|TensorRt |7.1.5 |7.1.3 |
|TensorFlow |1.15.0 |1.15.0 |
|pycapnp |>=0.6.3 |0.6.4 |
|librosa |>=0.6.3 |0.8.0 |
|SoundFile |>=0.10.2 |0.10.3.post1 |
|Python2 |2.7.x |2.7.17 |
|Python3 |3.6.x |3.6.9 |
Am I missing something here?
It’s odd to me that TRT says I do not have hardware with native FP16 support although the driver recognizes the RTX6000 card. I can run the previous example “Remote control Jetbot using Virtual Gamepad” perfectly fine but running the perception model keeps giving me that error.
I also tried to run this in the Isaac SDK Docker container and I’m running into the same problem, but I noticed the container didn’t have TRT when I ran the version checker.
Does anyone have any idea what could be going on? Or can anyone provide recommendations for what TRT version to use, as I suspect that it’s the TRT that is the issue. Thanks in advance!
