after run engine/build/scripts/install_dependencies.sh
Given no hashes to check 0 links for project ‘tensorflow-gpu’: discarding no candidates
ERROR: Could not find a version that satisfies the requirement tensorflow-gpu==1.15.0 (from -r engine/build/scripts/requirements.txt (line 1)) (from versions: none)
ERROR: No matching distribution found for tensorflow-gpu==1.15.0 (from -r engine/build/scripts/requirements.txt (line 1))
Exception information:
File “/home/tommy/.local/lib/python3.6/site-packages/pip/_internal/cli/base_command.py”, line 216, in _main
status = self.run(options, args)
File “/home/tommy/.local/lib/python3.6/site-packages/pip/_internal/cli/req_command.py”, line 182, in wrapper
return func(self, options, args)
File “/home/tommy/.local/lib/python3.6/site-packages/pip/_internal/commands/install.py”, line 325, in run
reqs, check_supported_wheels=not options.target_dir
File “/home/tommy/.local/lib/python3.6/site-packages/pip/_internal/resolution/legacy/resolver.py”, line 183, in resolve
discovered_reqs.extend(self._resolve_one(requirement_set, req))
File “/home/tommy/.local/lib/python3.6/site-packages/pip/_internal/resolution/legacy/resolver.py”, line 388, in _resolve_one
abstract_dist = self._get_abstract_dist_for(req_to_install)
File “/home/tommy/.local/lib/python3.6/site-packages/pip/_internal/resolution/legacy/resolver.py”, line 339, in _get_abstract_dist_for
self._populate_link(req)
File “/home/tommy/.local/lib/python3.6/site-packages/pip/_internal/resolution/legacy/resolver.py”, line 305, in _populate_link
req.link = self._find_requirement_link(req)
File “/home/tommy/.local/lib/python3.6/site-packages/pip/_internal/resolution/legacy/resolver.py”, line 270, in _find_requirement_link
best_candidate = self.finder.find_requirement(req, upgrade)
File “/home/tommy/.local/lib/python3.6/site-packages/pip/_internal/index/package_finder.py”, line 928, in find_requirement
req)
pip._internal.exceptions.DistributionNotFound: No matching distribution found for tensorflow-gpu==1.15.0 (from -r engine/build/scripts/requirements.txt (line 1))
Removed build tracker: ‘/tmp/pip-req-tracker-tyfjwno2’
