Isaac SDK on Xavier NX
I recently acquired a Xavier NX Dev Kit (P3668-0001), and have been struggling to run examples from the Isaac SDK (2020.1) on the device. From what I can gather on the JetPack download page and the SDK Manager, only JetPack 4.4 is compatible with the NX. However, I notice that the Isaac SDK only includes the packages_jetpack43 directory, and it seems that there’s no way to deploy to a target with JetPack 4.4. If I attempt to deploy and run the examples anyway, I get the following error message on the NX:
2020-06-22 11:25:20.305 ERROR engine/alice/components/Codelet.cpp@229: Component ‘_check_operating_system/isaac.alice.CheckOperatingSystem’ of type ‘isaac::alice::CheckOperatingSystem’ reported FAILURE:
‘/etc/nv_tegra_release’ does not start with ‘# R32 (release), REVISION: 3.1’. Please flash L4T using Jetpack 4.3.
2020-06-22 11:25:20.305 ERROR engine/alice/backend/event_manager.cpp@42: Stopping node ‘_check_operating_system’ because it reached status ‘FAILURE’
Is there a workaround to using Isaac on the Xavier NX at this point?
The current release Isaac SDK 2020.1 is compatible with JetPack 4.3. The next release will support JetPack 4.4
Hi do you have a roadmap for the next Isaac release ?
August we will release SDK with JetPack 4.4 support
Hi! May I know when we can expect the next release of Isaac with JetPack 4.4 support? I am eagerly awaiting to use Isaac on my Xavier NX.
Try the JetPack 4.4 Developer Preview, which has support for the NX.
