Isaac sdk sample run error
@MikePhysX @Planktos
When I dowloaded isaac sdk 2020.2 and tried to bazel run the sample in /apps/samples/manipulation:end_effector_control, my bazel version is 3.1.0,
flexivsu@isaac:~/isaac-sdk/sdk$ bazel run //apps/samples/manipulation:end_effector_control
it throws the problem:
flexivsu@isaac:~/isaac-sdk/sdk$ bazel run //apps/samples/stereo_dummy
INFO: Repository cuda_x86_64 instantiated at:
  no stack (--record_rule_instantiation_callstack not enabled)
Repository rule http_archive defined at:
  /home/flexivsu/.cache/bazel/_bazel_flexivsu/1c9001d13338a7e0e424b252c6ce8318/external/bazel_tools/tools/build_defs/repo/http.bzl:336:16: in <toplevel>
WARNING: Download from https://developer.nvidia.com/isaac/download/third_party/cuda-10-2-cudnn-8-0-3-x86_64-tar-bz2 failed: class com.google.devtools.build.lib.bazel.repository.downloader.UnrecoverableHttpException GET returned 502 Bad Gateway
ERROR: An error occurred during the fetch of repository 'cuda_x86_64':
   java.io.IOException: Error downloading [https://developer.nvidia.com/isaac/download/third_party/cuda-10-2-cudnn-8-0-3-x86_64-tar-bz2] to /home/flexivsu/.cache/bazel/_bazel_flexivsu/1c9001d13338a7e0e424b252c6ce8318/external/cuda_x86_64/cuda-10-2-cudnn-8-0-3-x86_64-tar-bz2.tar.bz2: GET returned 502 Bad Gateway
ERROR: /home/flexivsu/isaac-sdk/sdk/third_party/BUILD:13:1: //third_party:nppif depends on @cuda_x86_64//:nppif in repository @cuda_x86_64 which failed to fetch. no such package '@cuda_x86_64//': java.io.IOException: Error downloading [https://developer.nvidia.com/isaac/download/third_party/cuda-10-2-cudnn-8-0-3-x86_64-tar-bz2] to /home/flexivsu/.cache/bazel/_bazel_flexivsu/1c9001d13338a7e0e424b252c6ce8318/external/cuda_x86_64/cuda-10-2-cudnn-8-0-3-x86_64-tar-bz2.tar.bz2: GET returned 502 Bad Gateway
ERROR: /home/flexivsu/isaac-sdk/sdk/third_party/BUILD:13:1: //third_party:nppig depends on @cuda_x86_64//:nppig in repository @cuda_x86_64 which failed to fetch. no such package '@cuda_x86_64//': java.io.IOException: Error downloading [https://developer.nvidia.com/isaac/download/third_party/cuda-10-2-cudnn-8-0-3-x86_64-tar-bz2] to /home/flexivsu/.cache/bazel/_bazel_flexivsu/1c9001d13338a7e0e424b252c6ce8318/external/cuda_x86_64/cuda-10-2-cudnn-8-0-3-x86_64-tar-bz2.tar.bz2: GET returned 502 Bad Gateway
ERROR: /home/flexivsu/isaac-sdk/sdk/third_party/BUILD:13:1: //third_party:npps depends on @cuda_x86_64//:npps in repository @cuda_x86_64 which failed to fetch. no such package '@cuda_x86_64//': java.io.IOException: Error downloading [https://developer.nvidia.com/isaac/download/third_party/cuda-10-2-cudnn-8-0-3-x86_64-tar-bz2] to /home/flexivsu/.cache/bazel/_bazel_flexivsu/1c9001d13338a7e0e424b252c6ce8318/external/cuda_x86_64/cuda-10-2-cudnn-8-0-3-x86_64-tar-bz2.tar.bz2: GET returned 502 Bad Gateway
ERROR: /home/flexivsu/.cache/bazel/_bazel_flexivsu/1c9001d13338a7e0e424b252c6ce8318/external/com_nvidia_isaac_engine/third_party/BUILD:13:1: @com_nvidia_isaac_engine//third_party:cuda depends on @cuda_x86_64//:cuda in repository @cuda_x86_64 which failed to fetch. no such package '@cuda_x86_64//': java.io.IOException: Error downloading [https://developer.nvidia.com/isaac/download/third_party/cuda-10-2-cudnn-8-0-3-x86_64-tar-bz2] to /home/flexivsu/.cache/bazel/_bazel_flexivsu/1c9001d13338a7e0e424b252c6ce8318/external/cuda_x86_64/cuda-10-2-cudnn-8-0-3-x86_64-tar-bz2.tar.bz2: GET returned 502 Bad Gateway
ERROR: /home/flexivsu/isaac-sdk/sdk/third_party/BUILD:13:1: //third_party:nppitc depends on @cuda_x86_64//:nppitc in repository @cuda_x86_64 which failed to fetch. no such package '@cuda_x86_64//': java.io.IOException: Error downloading [https://developer.nvidia.com/isaac/download/third_party/cuda-10-2-cudnn-8-0-3-x86_64-tar-bz2] to /home/flexivsu/.cache/bazel/_bazel_flexivsu/1c9001d13338a7e0e424b252c6ce8318/external/cuda_x86_64/cuda-10-2-cudnn-8-0-3-x86_64-tar-bz2.tar.bz2: GET returned 502 Bad Gateway
ERROR: /home/flexivsu/isaac-sdk/sdk/third_party/BUILD:13:1: //third_party:nppidei depends on @cuda_x86_64//:nppidei in repository @cuda_x86_64 which failed to fetch. no such package '@cuda_x86_64//': java.io.IOException: Error downloading [https://developer.nvidia.com/isaac/download/third_party/cuda-10-2-cudnn-8-0-3-x86_64-tar-bz2] to /home/flexivsu/.cache/bazel/_bazel_flexivsu/1c9001d13338a7e0e424b252c6ce8318/external/cuda_x86_64/cuda-10-2-cudnn-8-0-3-x86_64-tar-bz2.tar.bz2: GET returned 502 Bad Gateway
ERROR: /home/flexivsu/isaac-sdk/sdk/third_party/BUILD:13:1: //third_party:cudart depends on @cuda_x86_64//:cudart in repository @cuda_x86_64 which failed to fetch. no such package '@cuda_x86_64//': java.io.IOException: Error downloading [https://developer.nvidia.com/isaac/download/third_party/cuda-10-2-cudnn-8-0-3-x86_64-tar-bz2] to /home/flexivsu/.cache/bazel/_bazel_flexivsu/1c9001d13338a7e0e424b252c6ce8318/external/cuda_x86_64/cuda-10-2-cudnn-8-0-3-x86_64-tar-bz2.tar.bz2: GET returned 502 Bad Gateway
ERROR: /home/flexivsu/.cache/bazel/_bazel_flexivsu/1c9001d13338a7e0e424b252c6ce8318/external/com_nvidia_isaac_engine/third_party/BUILD:13:1: @com_nvidia_isaac_engine//third_party:cudart depends on @cuda_x86_64//:cudart in repository @cuda_x86_64 which failed to fetch. no such package '@cuda_x86_64//': java.io.IOException: Error downloading [https://developer.nvidia.com/isaac/download/third_party/cuda-10-2-cudnn-8-0-3-x86_64-tar-bz2] to /home/flexivsu/.cache/bazel/_bazel_flexivsu/1c9001d13338a7e0e424b252c6ce8318/external/cuda_x86_64/cuda-10-2-cudnn-8-0-3-x86_64-tar-bz2.tar.bz2: GET returned 502 Bad Gateway
ERROR: /home/flexivsu/isaac-sdk/sdk/third_party/BUILD:13:1: //third_party:nppial depends on @cuda_x86_64//:nppial in repository @cuda_x86_64 which failed to fetch. no such package '@cuda_x86_64//': java.io.IOException: Error downloading [https://developer.nvidia.com/isaac/download/third_party/cuda-10-2-cudnn-8-0-3-x86_64-tar-bz2] to /home/flexivsu/.cache/bazel/_bazel_flexivsu/1c9001d13338a7e0e424b252c6ce8318/external/cuda_x86_64/cuda-10-2-cudnn-8-0-3-x86_64-tar-bz2.tar.bz2: GET returned 502 Bad Gateway
ERROR: /home/flexivsu/isaac-sdk/sdk/third_party/BUILD:13:1: //third_party:nppc depends on @cuda_x86_64//:nppc in repository @cuda_x86_64 which failed to fetch. no such package '@cuda_x86_64//': java.io.IOException: Error downloading [https://developer.nvidia.com/isaac/download/third_party/cuda-10-2-cudnn-8-0-3-x86_64-tar-bz2] to /home/flexivsu/.cache/bazel/_bazel_flexivsu/1c9001d13338a7e0e424b252c6ce8318/external/cuda_x86_64/cuda-10-2-cudnn-8-0-3-x86_64-tar-bz2.tar.bz2: GET returned 502 Bad Gateway
DEBUG: Rule 'isaac_assets' indicated that a canonical reproducible form can be obtained by modifying arguments sha256 = "032d56b65d17acf360cab1145e57cdeb0a0d2e25814624a90d44766e624e40f1"
DEBUG: Repository isaac_assets instantiated at:
WARNING: errors encountered while analyzing target '//apps/samples/stereo_dummy:stereo_dummy': it will not be built
INFO: Analyzed target //apps/samples/stereo_dummy:stereo_dummy (0 packages loaded, 0 targets configured).
INFO: Found 0 targets...
ERROR: command succeeded, but there were loading phase errors
INFO: Elapsed time: 31.427s, Critical Path: 0.00s
INFO: 0 processes.
FAILED: Build did NOT complete successfully
I downloaded cuda file and replaced isaac_http_archive with isaac_new_local_repository.
