Isaac SDK sample run error(
I dowloaded isaac sdk 2020.2 and tried to bazel run the sample in 'bazel run //apps/navsim:navsim_navigate
', but there was an error.
it throws the problem:
Analyzing: target //apps/navsim:navsim_navigate (0 packages loaded, 0 targets configured)
    Fetching @cuda_x86_64; fetching
    Fetching https://developer.nvidia.com/isaac/download/third_party/cuda-10-2-cudnn-8-0-3-x86_64-tar-bz2; 19,668,983B
INFO: Repository cuda_x86_64 instantiated at:
  no stack (--record_rule_instantiation_callstack not enabled)
Repository rule http_archive defined at:
  /home/idim/.cache/bazel/_bazel_idim/bad3f79404444403ee036d62dd2299d2/external/bazel_tools/tools/build_defs/repo/http.bzl:336:16: in <toplevel>
ERROR: An error occurred during the fetch of repository 'cuda_x86_64':
   java.io.IOException: thread interrupted
ERROR: build interrupted
INFO: Elapsed time: 3.414s
INFO: 0 processes.
FAILED: Build did NOT complete successfully (0 packages loaded, 0 targets configured)
Here is my workstation spec and version:
GPU : RTX2080ti
CUDA : 10.2
Nvidia graphic card driver :440
bazel : 3.1.0
IsaacSim Unity3D game mode also run well with ‘./sample.x86_64 --scene small_warehouse -logFile -’.
How can I fix this problem?
The log seems to indicate that Bazel was fetching Cuda 10.2 libraries to build and was interrupted somehow (network connectivity, disk space exhausted, errant keystroke?). Is this consistently happening on retries?
You may want to check that you’ve run the install_dependencies.sh script first.
Next, you could try clearing Bazel’s cache bazel clean --expunge and building again.
I downloaded cuda deb file(ver 10.2) and waited about 3min, and it worked.
However, I’ve faced another error like this :
2021-01-09 01:43:47.243 ERROR external/com_nvidia_isaac_engine/engine/alice/backend/modules.cpp@295: packages/perception/libperception_module.so: /home/idim/.cache/bazel/_bazel_idim/bad3f79404444403ee036d62dd2299d2/execroot/com_nvidia_isaac_sdk/bazel-out/k8-opt/bin/apps/navsim/navsim_navigate.runfiles/com_nvidia_isaac_sdk//packages/perception/libperception_module.so: undefined symbol: IsaacGatherComponentInfo
2021-01-09 01:43:47.243 PANIC external/com_nvidia_isaac_engine/engine/alice/backend/modules.cpp@297: Could not load all required modules for application
|                            Isaac application terminated unexpectedly                             |
#01 /home/idim/.cache/bazel/_bazel_idim/bad3f79404444403ee036d62dd2299d2/execroot/com_nvidia_isaac_sdk/bazel-out/k8-opt/bin/apps/navsim/navsim_navigate.runfiles/com_nvidia_isaac_sdk/packages/pyalice/bindings.so(+0x16c81a) [0x7f749d1a881a]
#02 google_breakpad::ExceptionHandler::GenerateDump(google_breakpad::ExceptionHandler::CrashContext*) /home/idim/.cache/bazel/_bazel_idim/bad3f79404444403ee036d62dd2299d2/execroot/com_nvidia_isaac_sdk/bazel-out/k8-opt/bin/apps/navsim/navsim_navigate.runfiles/com_nvidia_isaac_sdk/packages/pyalice/bindings.so(_ZN15google_breakpad16ExceptionHandler12GenerateDumpEPNS0_12CrashContextE+0x3f0) [0x7f749d24a9b0]
#03 google_breakpad::ExceptionHandler::SignalHandler(int, siginfo_t*, void*) /home/idim/.cache/bazel/_bazel_idim/bad3f79404444403ee036d62dd2299d2/execroot/com_nvidia_isaac_sdk/bazel-out/k8-opt/bin/apps/navsim/navsim_navigate.runfiles/com_nvidia_isaac_sdk/packages/pyalice/bindings.so(_ZN15google_breakpad16ExceptionHandler13SignalHandlerEiP9siginfo_tPv+0xc0) [0x7f749d24ad20]
#04 /lib/x86_64-linux-gnu/libc.so.6(+0x3f040) [0x7f74cb815040]
#05 /lib/x86_64-linux-gnu/libc.so.6(gsignal+0xc7) [0x7f74cb814fb7]
#06 /lib/x86_64-linux-gnu/libc.so.6(abort+0x141) [0x7f74cb816921]
#07 isaac::alice::ModuleManager::loadModules(std::vector<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::allocator<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > > > const&) /home/idim/.cache/bazel/_bazel_idim/bad3f79404444403ee036d62dd2299d2/execroot/com_nvidia_isaac_sdk/bazel-out/k8-opt/bin/apps/navsim/navsim_navigate.runfiles/com_nvidia_isaac_sdk/packages/pyalice/bindings.so(_ZN5isaac5alice13ModuleManager11loadModulesERKSt6vectorINSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEEESaIS8_EE+0x80e) [0x7f749d1b456e]
#08 isaac::alice::Application::createMore(isaac::alice::ApplicationJsonLoader const&) /home/idim/.cache/bazel/_bazel_idim/bad3f79404444403ee036d62dd2299d2/execroot/com_nvidia_isaac_sdk/bazel-out/k8-opt/bin/apps/navsim/navsim_navigate.runfiles/com_nvidia_isaac_sdk/packages/pyalice/bindings.so(_ZN5isaac5alice11Application10createMoreERKNS0_21ApplicationJsonLoaderE+0x67) [0x7f749d16a967]
#09 isaac::alice::Application::createApplication(isaac::alice::ApplicationJsonLoader const&) /home/idim/.cache/bazel/_bazel_idim/bad3f79404444403ee036d62dd2299d2/execroot/com_nvidia_isaac_sdk/bazel-out/k8-opt/bin/apps/navsim/navsim_navigate.runfiles/com_nvidia_isaac_sdk/packages/pyalice/bindings.so(_ZN5isaac5alice11Application17createApplicationERKNS0_21ApplicationJsonLoaderE+0x289) [0x7f749d16d309]
#10 isaac::alice::Application::Application(isaac::alice::ApplicationJsonLoader const&) /home/idim/.cache/bazel/_bazel_idim/bad3f79404444403ee036d62dd2299d2/execroot/com_nvidia_isaac_sdk/bazel-out/k8-opt/bin/apps/navsim/navsim_navigate.runfiles/com_nvidia_isaac_sdk/packages/pyalice/bindings.so(_ZN5isaac5alice11ApplicationC1ERKNS0_21ApplicationJsonLoaderE+0x15f) [0x7f749d16d65f]
#11 isaac::alice::PybindApplication::PybindApplication(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&) /home/idim/.cache/bazel/_bazel_idim/bad3f79404444403ee036d62dd2299d2/execroot/com_nvidia_isaac_sdk/bazel-out/k8-opt/bin/apps/navsim/navsim_navigate.runfiles/com_nvidia_isaac_sdk/packages/pyalice/bindings.so(_ZN5isaac5alice17PybindApplicationC1ERKNSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEEES9_S9_+0x21c) [0x7f749d13743c]
#12 /home/idim/.cache/bazel/_bazel_idim/bad3f79404444403ee036d62dd2299d2/execroot/com_nvidia_isaac_sdk/bazel-out/k8-opt/bin/apps/navsim/navsim_navigate.runfiles/com_nvidia_isaac_sdk/packages/pyalice/bindings.so(+0xfb876) [0x7f749d137876]
#13 /home/idim/.cache/bazel/_bazel_idim/bad3f79404444403ee036d62dd2299d2/execroot/com_nvidia_isaac_sdk/bazel-out/k8-opt/bin/apps/navsim/navsim_navigate.runfiles/com_nvidia_isaac_sdk/packages/pyalice/bindings.so(+0xe93f4) [0x7f749d1253f4]
#14 /usr/bin/python3(_PyCFunction_FastCallDict+0x35c) [0x566bbc]
#15 /usr/bin/python3() [0x594a71]
#16 /usr/bin/python3() [0x54a035]
#17 /usr/bin/python3() [0x5515c1]
#18 /usr/bin/python3(_PyObject_FastCallKeywords+0x19c) [0x5a9dac]
#19 /usr/bin/python3() [0x50a433]
#20 /usr/bin/python3(_PyEval_EvalFrameDefault+0x444) [0x50beb4]
#21 /usr/bin/python3() [0x507be4]
#22 /usr/bin/python3(_PyFunction_FastCallDict+0x2e2) [0x508ec2]
#23 /usr/bin/python3() [0x594a01]
#24 /usr/bin/python3() [0x549e8f]
#25 /usr/bin/python3() [0x5515c1]
#26 /usr/bin/python3(_PyObject_FastCallKeywords+0x19c) [0x5a9dac]
#27 /usr/bin/python3() [0x50a433]
#28 /usr/bin/python3(_PyEval_EvalFrameDefault+0x1226) [0x50cc96]
#29 /usr/bin/python3() [0x507be4]
#30 /usr/bin/python3(PyEval_EvalCode+0x23) [0x50ad03]
#31 /usr/bin/python3() [0x634e72]
#32 /usr/bin/python3(PyRun_FileExFlags+0x97) [0x634f27]
#33 /usr/bin/python3(PyRun_SimpleFileExFlags+0x17f) [0x6386df]
#34 /usr/bin/python3(Py_Main+0x591) [0x639281]
#35 /usr/bin/python3(main+0xe0) [0x4b0dc0]
#36 /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xe7) [0x7f74cb7f7bf7]
#37 /usr/bin/python3(_start+0x2a) [0x5b259a]
Minidump written to: /tmp/872b0127-cfa4-45d2-72442cb8-9bf43326.dmp
I already installed the dependency with ‘engine/build/scripts/install_dependencies.sh’
How can I fix this error ?
I solved this problem with this code:
-laptop:~/isaac/sdk$ export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/usr/local/cuda-10.2/lib64
-laptop:~/isaac/sdk$ echo ‘export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/usr/local/cuda-10.2/lib64’ >> ~/.bashrc
Tnx !
