Isaac SDK Simulation launch fails with Could not copy memory Error 38
Problem:
running Simulation that will eventually connect to Unity: bazel run //apps/navsim:navsim_navigate
exits with error: algorithm_cuda.cpp@55: Could not copy memory. Error: 38
My Configuration:
Ubuntu 18.04.3 LTS” on a PC with Isaac SDK 2019.3.
Kernel 4.15.0-43-generic
NVIDIA driver 430
Geforce 1050 Ti
cuda_10.0.130_410.48
cudnn-10.2-linux-x64-v7.6.5.32
TensorRT-6.0.1.5.Ubuntu-18.04.x86_64-gnu.cuda-10.0.cudnn7.6.tar.gz
tensorflow 1.15.0
Solution:
use a newer kernel
for example kernel 4.15.0-88-generic works
Terminal Output:
…Loaded module packages/…
…Creating node map…
2020-03-18 12:51:22.274 DEBUG engine/alice/backend/codelet_backend.cpp@287: Starting job for codelet ‘map/unity_initializer’
2020-03-18 12:51:22.280 PANIC engine/core/buffers/algorithm_cuda.cpp@55: Could not copy memory. Error: 38
