When I run the Warehouse Scene Navigation, the simulation shows up but the app fails with this error:
2019-08-05 09:51:04.355 INFO engine/alice/backend/modules.cpp@283: Loaded module 'packages/viewers/libviewers_module.so': Now has 120 components total
2019-08-05 09:51:04.356 ERROR engine/alice/backend/modules.cpp@307: ml: /home/nubot/.cache/bazel/_bazel_nubot/24cb462690d68313a57e2ec216711a4d/execroot/com_nvidia_isaac/bazel-out/k8-opt/bin/apps/carter/navsim/navsim_navigate.runfiles/com_nvidia_isaac//external/com_nvidia_isaac/packages/ml/libml_module.so: cannot open shared object file: No such file or directory
2019-08-05 09:51:04.356 PANIC engine/alice/backend/modules.cpp@309: Could not load all required modules for application
| Isaac application terminated unexpectedly |
The same error happens for the “Object Detection Training Data” example.
qianl
August 5, 2019, 10:40pm
2
Please install Isaac SDK dependencies first
bob@desktop:~/isaac$ engine/build/scripts/install_dependencies.sh
(https://docs.nvidia.com/isaac/isaac/doc/setup.html )
Thank you qianl. I had done it. I did it again but still I got the same error.
qianl
August 6, 2019, 6:13pm
4
It’s most likely due to missing depedencies of libml_module.so (or their dependencies).
Try follow the “NVIDIA GPU Driver” session here:
[url]https://docs.nvidia.com/isaac/isaac/doc/setup.html#machine-learning-optional[/url]
I have already installed the NVIDIA driver. I think libml_module has something to do with machine learning. Can anyone help me trace the issue?
qianl
August 7, 2019, 11:23pm
6
libml_module is part of Isaac SDK. navsim.subgraph.json uses a codelet in that module.
goto isaac/bazel-bin/packages/ml, run
sudo updatedb
ldd libml_module.so
and post the result here.
Thanks Qianl. I have CUDA 10.1. Could that be the problem?
This is the output:
linux-vdso.so.1 (0x00007ffe6c9f8000)
libml_module.so => /home/nubot/.cache/bazel/_bazel_nubot/24cb462690d68313a57e2ec216711a4d/execroot/com_nvidia_isaac/bazel-out/k8-opt/bin/packages/ml/./../../_solib_k8/_U_S_Spackages_Sml_Clibml_Umodule.so___Upackages_Ux86_U64_Sml/libml_module.so (0x00007f5006ffd000)
libnvinfer.so.5 => /home/nubot/.cache/bazel/_bazel_nubot/24cb462690d68313a57e2ec216711a4d/execroot/com_nvidia_isaac/bazel-out/k8-opt/bin/packages/ml/./../../_solib_k8/_U@tensorrt_Ux86_U64_S_S_Ctensorrt_Ux86_U64___Uexternal_Stensorrt_Ux86_U64_Slib_Sx86_U64-linux-gnu/libnvinfer.so.5 (0x00007f4fffb9e000)
libnvinfer_plugin.so.5 => /home/nubot/.cache/bazel/_bazel_nubot/24cb462690d68313a57e2ec216711a4d/execroot/com_nvidia_isaac/bazel-out/k8-opt/bin/packages/ml/./../../_solib_k8/_U@tensorrt_Ux86_U64_S_S_Ctensorrt_Ux86_U64___Uexternal_Stensorrt_Ux86_U64_Slib_Sx86_U64-linux-gnu/libnvinfer_plugin.so.5 (0x00007f4fff66a000)
libnvonnxparser.so.0 => /home/nubot/.cache/bazel/_bazel_nubot/24cb462690d68313a57e2ec216711a4d/execroot/com_nvidia_isaac/bazel-out/k8-opt/bin/packages/ml/./../../_solib_k8/_U@tensorrt_Ux86_U64_S_S_Ctensorrt_Ux86_U64___Uexternal_Stensorrt_Ux86_U64_Slib_Sx86_U64-linux-gnu/libnvonnxparser.so.0 (0x00007f4ffeead000)
libnvonnxparser_runtime.so.0 => /home/nubot/.cache/bazel/_bazel_nubot/24cb462690d68313a57e2ec216711a4d/execroot/com_nvidia_isaac/bazel-out/k8-opt/bin/packages/ml/./../../_solib_k8/_U@tensorrt_Ux86_U64_S_S_Ctensorrt_Ux86_U64___Uexternal_Stensorrt_Ux86_U64_Slib_Sx86_U64-linux-gnu/libnvonnxparser_runtime.so.0 (0x00007f4ffe8ff000)
libnvparsers.so.5 => /home/nubot/.cache/bazel/_bazel_nubot/24cb462690d68313a57e2ec216711a4d/execroot/com_nvidia_isaac/bazel-out/k8-opt/bin/packages/ml/./../../_solib_k8/_U@tensorrt_Ux86_U64_S_S_Ctensorrt_Ux86_U64___Uexternal_Stensorrt_Ux86_U64_Slib_Sx86_U64-linux-gnu/libnvparsers.so.5 (0x00007f4ffe3e1000)
libcudnn.so.7 => /home/nubot/.cache/bazel/_bazel_nubot/24cb462690d68313a57e2ec216711a4d/execroot/com_nvidia_isaac/bazel-out/k8-opt/bin/packages/ml/./../../_solib_k8/_U@cuda_Ux86_U64_S_S_Ccudnn___Uexternal_Scuda_Ux86_U64_Susr_Slib_Sx86_U64-linux-gnu/libcudnn.so.7 (0x00007f4fe95ba000)
libcudart.so.10.0 => /home/nubot/.cache/bazel/_bazel_nubot/24cb462690d68313a57e2ec216711a4d/execroot/com_nvidia_isaac/bazel-out/k8-opt/bin/packages/ml/./../../_solib_k8/_U@cuda_Ux86_U64_S_S_Ccudart___Uexternal_Scuda_Ux86_U64_Susr_Slocal_Scuda-10.0_Slib64/libcudart.so.10.0 (0x00007f4fe9340000)
libcublas.so.10.0 => /home/nubot/.cache/bazel/_bazel_nubot/24cb462690d68313a57e2ec216711a4d/execroot/com_nvidia_isaac/bazel-out/k8-opt/bin/packages/ml/./../../_solib_k8/_U@cuda_Ux86_U64_S_S_Ccublas___Uexternal_Scuda_Ux86_U64_Susr_Slocal_Scuda-10.0_Slib64/libcublas.so.10.0 (0x00007f4fe4daa000)
libstdc++.so.6 => /usr/lib/x86_64-linux-gnu/libstdc++.so.6 (0x00007f4fe49ca000)
libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 (0x00007f4fe462c000)
libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007f4fe423b000)
libnppial.so.10.0 => /home/nubot/.cache/bazel/_bazel_nubot/24cb462690d68313a57e2ec216711a4d/execroot/com_nvidia_isaac/bazel-out/k8-opt/bin/packages/ml/./../../_solib_k8/_U_S_Spackages_Sml_Clibml_Umodule.so___Upackages_Ux86_U64_Sml/../../_solib_k8/_U@cuda_Ux86_U64_S_S_Cnppial___Uexternal_Scuda_Ux86_U64_Susr_Slocal_Scuda-10.0_Slib64/libnppial.so.10.0 (0x00007f4fe3625000)
libnppidei.so.10.0 => /home/nubot/.cache/bazel/_bazel_nubot/24cb462690d68313a57e2ec216711a4d/execroot/com_nvidia_isaac/bazel-out/k8-opt/bin/packages/ml/./../../_solib_k8/_U_S_Spackages_Sml_Clibml_Umodule.so___Upackages_Ux86_U64_Sml/../../_solib_k8/_U@cuda_Ux86_U64_S_S_Cnppidei___Uexternal_Scuda_Ux86_U64_Susr_Slocal_Scuda-10.0_Slib64/libnppidei.so.10.0 (0x00007f4fe2d1a000)
libnppif.so.10.0 => /home/nubot/.cache/bazel/_bazel_nubot/24cb462690d68313a57e2ec216711a4d/execroot/com_nvidia_isaac/bazel-out/k8-opt/bin/packages/ml/./../../_solib_k8/_U_S_Spackages_Sml_Clibml_Umodule.so___Upackages_Ux86_U64_Sml/../../_solib_k8/_U@cuda_Ux86_U64_S_S_Cnppif___Uexternal_Scuda_Ux86_U64_Susr_Slocal_Scuda-10.0_Slib64/libnppif.so.10.0 (0x00007f4fdfe0a000)
libnppig.so.10.0 => /home/nubot/.cache/bazel/_bazel_nubot/24cb462690d68313a57e2ec216711a4d/execroot/com_nvidia_isaac/bazel-out/k8-opt/bin/packages/ml/./../../_solib_k8/_U_S_Spackages_Sml_Clibml_Umodule.so___Upackages_Ux86_U64_Sml/../../_solib_k8/_U@cuda_Ux86_U64_S_S_Cnppig___Uexternal_Scuda_Ux86_U64_Susr_Slocal_Scuda-10.0_Slib64/libnppig.so.10.0 (0x00007f4fde423000)
libnpps.so.10.0 => /home/nubot/.cache/bazel/_bazel_nubot/24cb462690d68313a57e2ec216711a4d/execroot/com_nvidia_isaac/bazel-out/k8-opt/bin/packages/ml/./../../_solib_k8/_U_S_Spackages_Sml_Clibml_Umodule.so___Upackages_Ux86_U64_Sml/../../_solib_k8/_U@cuda_Ux86_U64_S_S_Cnpps___Uexternal_Scuda_Ux86_U64_Susr_Slocal_Scuda-10.0_Slib64/libnpps.so.10.0 (0x00007f4fdd9f1000)
libnppc.so.10.0 => /home/nubot/.cache/bazel/_bazel_nubot/24cb462690d68313a57e2ec216711a4d/execroot/com_nvidia_isaac/bazel-out/k8-opt/bin/packages/ml/./../../_solib_k8/_U_S_Spackages_Sml_Clibml_Umodule.so___Upackages_Ux86_U64_Sml/../../_solib_k8/_U@cuda_Ux86_U64_S_S_Cnppc___Uexternal_Scuda_Ux86_U64_Susr_Slocal_Scuda-10.0_Slib64/libnppc.so.10.0 (0x00007f4fdd769000)
libcurand.so.10.0 => not found
libcusolver.so.10.0 => not found
libcuda.so.1 => /usr/lib/x86_64-linux-gnu/libcuda.so.1 (0x00007f4fdc5f9000)
libdl.so.2 => /lib/x86_64-linux-gnu/libdl.so.2 (0x00007f4fdc3f5000)
libgcc_s.so.1 => /lib/x86_64-linux-gnu/libgcc_s.so.1 (0x00007f4fdc1dd000)
libpthread.so.0 => /lib/x86_64-linux-gnu/libpthread.so.0 (0x00007f4fdbfbe000)
/lib64/ld-linux-x86-64.so.2 (0x00007f500746d000)
librt.so.1 => /lib/x86_64-linux-gnu/librt.so.1 (0x00007f4fdbdb6000)
libnvidia-fatbinaryloader.so.430.40 => /usr/lib/x86_64-linux-gnu/libnvidia-fatbinaryloader.so.430.40 (0x00007f4fdbb68000)
qianl
August 8, 2019, 5:07pm
8
these are the missing pieces, so yes you’ll need CUDA 10.0 (this is the CUDA version used in Jetpack 4.2.1, so we keep it for consistency)
libcurand.so.10.0 => /usr/local/cuda-10.0/targets/x86_64-linux/lib/libcurand.so.10.0 (0x00007faa4f059000)
libcusolver.so.10.0 => /usr/local/cuda-10.0/targets/x86_64-linux/lib/libcusolver.so.10.0 (0x00007faa46971000)
you can just install CUDA 10.0 alongside CUDA 10.1
I tried to install CUDA 10.0 from the NVIDIA website (the current default is 10.1) but I didn’t have much success until I found the solution:
sudo apt-get install cuda-10-0
Source: [url]https://devtalk.nvidia.com/default/topic/1050914/cuda-setup-and-installation/cuda-remove-10-1-and-install-10-0-ubuntu-18-04/[/url]
shrinv
February 18, 2020, 10:59pm
11
Just a quick note that a fresh install of Isaac 2019.3 on Ubuntu 18.04 LTS does allow this example to work
